Raspberry Pi 4
- COlger81
- Thank you received: 6
- COlger81
- Thank you received: 4654
I was able to get it installed but latency on servo thread was 50,000,000 and GTK was not loading so i could not get gmoccapy to load.
Which Raspbian image were you using?
- Thank you received: 5321
The limitation is at 96 I/O maximum it could be very low for some specific applications, maybe we could find a way to reach 128 or 256 user I/O using some new FPGA like ARTIX 35K or 100K, or creating 2x HM2 firmware in a single FPGA if there is enough cells. it could be very easy and with a double SPI communication (SPI0 and SPI1) 2x96 = 192 I/O
Current IDROM format limits I/O to 144 pins not 96, raising this to 1024 or so would really only mean increasing the IDROM size and changing a few constants. This is independent of FPGA type.
- COlger81
what does:
uname -a
report?
- COlger81
maybe 200 if you run a browser/videos, How did you test latency?
I usually use
latency-histogram --nobase --sbinsize 1000
- COlger81
- gtt38
The 3x20 has 144 I/O you're right. I have a XC6SLX25 with 189 user I/O, i should try a 144 I/O config and maybe try more...
I have few pb with IDROMconst, maybe you could help me. I added this line to this file with a random number, but it's not working, my board is unreconized :
constant BoardNameSLX25 : std_logic_vector(31 downto 0) := x"12384339"; -- Generic SLX25i have to find the link into the linuxcnc source where the different boards are listed, maybe in rpspi.c
