That clock rate I see above is likely too fast, just for S&G try 25,000,000. you can go slower yet, but if your cabling is very short and correctly terminated (120 ohms at the rpi4 end of the cable), and mine is only an inch long, it should work. I assume you are switching the target card when trying a different card than a 7i90HD?
Bertho may have better advice, but I am using SPI0 into a 7i90HD on a 2 gig
rpi4b at a write speed of 31,whatever, I think 31,250,000 and a read speed of 25,000,000. I can write at 40 something, but that was not the default I found in the hm2_rpspi.ko source code I have.
But, I am not positive I am using Bertho's latest code as I had to edit the source to slow it read down to at 25 megabits.
Specifying it on the hm2 command line I couldn't make work.
And it doesn't look like it worked above either.
So I am surprised to see 50 megabits above, because that is not whats in the code of the debs you got from my site. If you, gtt38, are running my debs, please elaborate.
Bertho, can you again fwd me the latest driver so I can rebuild the debs? I don't believe I am on the same page as gtt38. Include if it not too unhandy, the sha512 checksum please.
Thanks.
Cheers, Gene Heskett
"There are four boxes to be used in defense of liberty:
soap, ballot, jury, and ammo. Please use in that order."
-Ed Howdershelt (Author)
Genes Web page <
geneslinuxbox.net:6309/gene
