You didn't look in the right place. Add /lathe-stf to the link in my sig, which should get you a directory containing linixcnc4rpi4, click on that and you'll find a build but not stripped kernel, and the debs that are running linuxcnc on my rpi4 and have been for a couple months. The debs ae ready to install and supposedly have Bertho's latest rpspi. driver. I couldn't make the read and write speed commands work, and my lashup will not read from a 7i90HD any faster that 25 megabits, so the code is hard built for a 31 megabit write and a 25 megabit read. Untested with the other two cards.
That kernel contains the newer much faster video drivers and will make 60 fps glxgears on a full 1920x1080 screen, which is about 58 fps faster than the older kernel can do.
Sorry the kernel is about 2.5 gigabytes but its fully built, just follow Big Johns instructions to install what you need from it.
I don't have upload bw to spare, so its slow. And I've blocked about 40 of the nets less well trained bots from mirroring my site.
Cheers, Gene Heskett
"There are four boxes to be used in defense of liberty:
soap, ballot, jury, and ammo. Please use in that order."
-Ed Howdershelt (Author)
Genes Web page <
geneslinuxbox.net:6309/gene
