Raspberry Pi 4
6 years 10 months ago #153570 by Bertho
Replied by Bertho on topic Raspberry Pi 4
Author of the driver here...
The SPI1 port has not been tested on a RPi4 afaik. The hardware internals should be mostly the same and compatible, but the new BCM chip adds several more ports, which may interfere (the BCM hardware doc is abysmal).
Can you test a bit? You probably know this, but anyway... the GPIO numbers and the pin-header positions do not match.
Specified as NAME=GPIONR(PINNR)
- SPI0: MOSI=10(19), MISO=9(21), SCLK=11(23), CE0=8(24), CE1=7(26)
- SPI1: MOSI=20(38), MISO=19(35), SCLK=21(40), CE0=18(12), CE1=17(11), CE2=16(36)
If SPI1/CE2 does not work, can you test SPI1/CE1 and SPI1/CE0 too? Please start with a rather slow SPI frequency to rule out timing problems. The frequency defaults to ~32MHz and I heard a rumor that the frequency might be off on the RPi4. If you start with something like 5MHz (spiclk_rate=5000), then it may be easier to get it going.
6 years 10 months ago #153573 by gtt38
Replied by gtt38 on topic Raspberry Pi 4
I'm on it ;-)
[img
[img
I'm not using a "real" 7i90, it's a XC6SLX9 flashed with a HM2 firmware but it's perfectly working with SPI0 so i don't know why it's not working on SPI1
I enabled SPI1 of course with adding "dtoverlay=spi1-3cs" in /boot/config.txt to enable 3 more spi ports but i didn't try CE1 and CE0 and and didn't try specific speed.
i just tried this but nothing :
"loadrt hm2_rpspi spi_probe=16 spiclk_rate=25000 spiclk_rate_rd=12500"
6 years 10 months ago #153578 by Bertho
Please do not enable any kernel drivers. The hm2_rpspi driver addresses the hardware directly and configures all the necessary internal registers. Having multiple drivers competing over the hardware results in unpredictable behaviour.
At the moment, the hm2_rpspi driver ignores most kernel information about the hardware from the device-tree (that is work in progress) and mostly assumes it knows where to find all the peripherals in the memory map. This could potentially be a problem for port SPI1, but the hardware is supposed to be compatible. The only change was the base-address, which was fixed in the last hm2_rpspi update.
6 years 10 months ago #153580 by gtt38
SPI 0 and 1 have the kernel driver enabled and it's working good on SPI0. I should try to disable both of them.
6 years 10 months ago - 6 years 10 months ago #153594 by gtt38
When i'm on SPI0 i have this :
pi@raspberrypi:~ $ halrun halcmd: loadrt hostmot2 Note: Using POSIX realtime hm2: loading Mesa HostMot2 driver version 0.15 halcmd: loadrt hm2_rpspi spi_probe=1 spiclk_rate=5000 hm2/hm2_7i90.0: 72 I/O Pins used: hm2/hm2_7i90.0: IO Pin 000 (P1-01): PWMGen #0, pin Out0 (PWM or Up) (Output) hm2/hm2_7i90.0: IO Pin 001 (P1-03): PWMGen #0, pin Out1 (Dir or Down) (Outpu t) hm2/hm2_7i90.0: IO Pin 002 (P1-05): PWMGen #1, pin Out0 (PWM or Up) (Output) hm2/hm2_7i90.0: IO Pin 003 (P1-07): PWMGen #1, pin Out1 (Dir or Down) (Outpu t) hm2/hm2_7i90.0: IO Pin 004 (P1-09): PWMGen #2, pin Out0 (PWM or Up) (Output) hm2/hm2_7i90.0: IO Pin 005 (P1-11): PWMGen #2, pin Out1 (Dir or Down) (Outpu t) hm2/hm2_7i90.0: IO Pin 006 (P1-13): PWMGen #3, pin Out0 (PWM or Up) (Output) hm2/hm2_7i90.0: IO Pin 007 (P1-15): PWMGen #3, pin Out1 (Dir or Down) (Outpu t) hm2/hm2_7i90.0: IO Pin 008 (P1-17): IOPort hm2/hm2_7i90.0: IO Pin 009 (P1-19): IOPort hm2/hm2_7i90.0: IO Pin 010 (P1-21): IOPort hm2/hm2_7i90.0: IO Pin 011 (P1-23): IOPort hm2/hm2_7i90.0: IO Pin 012 (P1-25): IOPort hm2/hm2_7i90.0: IO Pin 013 (P1-27): IOPort hm2/hm2_7i90.0: IO Pin 014 (P1-29): IOPort hm2/hm2_7i90.0: IO Pin 015 (P1-31): IOPort hm2/hm2_7i90.0: IO Pin 016 (P1-33): IOPort hm2/hm2_7i90.0: IO Pin 017 (P1-35): IOPort hm2/hm2_7i90.0: IO Pin 018 (P1-37): IOPort hm2/hm2_7i90.0: IO Pin 019 (P1-39): IOPort hm2/hm2_7i90.0: IO Pin 020 (P1-41): IOPort hm2/hm2_7i90.0: IO Pin 021 (P1-43): IOPort hm2/hm2_7i90.0: IO Pin 022 (P1-45): IOPort hm2/hm2_7i90.0: IO Pin 023 (P1-47): IOPort hm2/hm2_7i90.0: IO Pin 024 (P2-01): PWMGen #4, pin Out0 (PWM or Up) (Output) hm2/hm2_7i90.0: IO Pin 025 (P2-03): PWMGen #4, pin Out1 (Dir or Down) (Outpu t) hm2/hm2_7i90.0: IO Pin 026 (P2-05): PWMGen #5, pin Out0 (PWM or Up) (Output) hm2/hm2_7i90.0: IO Pin 027 (P2-07): PWMGen #5, pin Out1 (Dir or Down) (Outpu t) hm2/hm2_7i90.0: IO Pin 028 (P2-09): PWMGen #6, pin Out0 (PWM or Up) (Output) hm2/hm2_7i90.0: IO Pin 029 (P2-11): PWMGen #6, pin Out1 (Dir or Down) (Outpu t) hm2/hm2_7i90.0: IO Pin 030 (P2-13): PWMGen #7, pin Out0 (PWM or Up) (Output) hm2/hm2_7i90.0: IO Pin 031 (P2-15): PWMGen #7, pin Out1 (Dir or Down) (Outpu t) hm2/hm2_7i90.0: IO Pin 032 (P2-17): IOPort hm2/hm2_7i90.0: IO Pin 033 (P2-19): IOPort hm2/hm2_7i90.0: IO Pin 034 (P2-21): IOPort hm2/hm2_7i90.0: IO Pin 035 (P2-23): IOPort hm2/hm2_7i90.0: IO Pin 036 (P2-25): IOPort hm2/hm2_7i90.0: IO Pin 037 (P2-27): IOPort hm2/hm2_7i90.0: IO Pin 038 (P2-29): IOPort hm2/hm2_7i90.0: IO Pin 039 (P2-31): IOPort hm2/hm2_7i90.0: IO Pin 040 (P2-33): IOPort hm2/hm2_7i90.0: IO Pin 041 (P2-35): IOPort hm2/hm2_7i90.0: IO Pin 042 (P2-37): IOPort hm2/hm2_7i90.0: IO Pin 043 (P2-39): IOPort hm2/hm2_7i90.0: IO Pin 044 (P2-41): IOPort hm2/hm2_7i90.0: IO Pin 045 (P2-43): IOPort hm2/hm2_7i90.0: IO Pin 046 (P2-45): IOPort hm2/hm2_7i90.0: IO Pin 047 (P2-47): IOPort hm2/hm2_7i90.0: IO Pin 048 (P3-01): IOPort hm2/hm2_7i90.0: IO Pin 049 (P3-03): IOPort hm2/hm2_7i90.0: IO Pin 050 (P3-05): IOPort hm2/hm2_7i90.0: IO Pin 051 (P3-07): IOPort hm2/hm2_7i90.0: IO Pin 052 (P3-09): IOPort hm2/hm2_7i90.0: IO Pin 053 (P3-11): IOPort hm2/hm2_7i90.0: IO Pin 054 (P3-13): IOPort hm2/hm2_7i90.0: IO Pin 055 (P3-15): IOPort hm2/hm2_7i90.0: IO Pin 056 (P3-17): IOPort hm2/hm2_7i90.0: IO Pin 057 (P3-19): IOPort hm2/hm2_7i90.0: IO Pin 058 (P3-21): IOPort hm2/hm2_7i90.0: IO Pin 059 (P3-23): IOPort hm2/hm2_7i90.0: IO Pin 060 (P3-25): IOPort hm2/hm2_7i90.0: IO Pin 061 (P3-27): IOPort hm2/hm2_7i90.0: IO Pin 062 (P3-29): IOPort hm2/hm2_7i90.0: IO Pin 063 (P3-31): IOPort hm2/hm2_7i90.0: IO Pin 064 (P3-33): IOPort hm2/hm2_7i90.0: IO Pin 065 (P3-35): IOPort hm2/hm2_7i90.0: IO Pin 066 (P3-37): IOPort hm2/hm2_7i90.0: IO Pin 067 (P3-39): IOPort hm2/hm2_7i90.0: IO Pin 068 (P3-41): IOPort hm2/hm2_7i90.0: IO Pin 069 (P3-43): IOPort hm2/hm2_7i90.0: IO Pin 070 (P3-45): IOPort hm2/hm2_7i90.0: IO Pin 071 (P3-47): IOPort hm2/hm2_7i90.0: registered
if i'm trying on SPI1/CE2 the same board :
pi@raspberrypi:~ $ halrun halcmd: loadrt hostmot2 Note: Using POSIX realtime hm2: loading Mesa HostMot2 driver version 0.15 halcmd: loadrt hm2_rpspi spi_probe=16 spiclk_rate=5000 hm2_rpspi: SPI1/CE2 Invalid cookie, read: 00000000 00000000 00000000, expected: 55aacafe 54534f48 32544f4d hm2_rpspi: SPI1/CE2 No drive seen on MISO line (kept at pull-down level). No board connected or bad connection? hm2_rpspi: rtapi_app_main: No such device (-19) <stdin>:2: waitpid failed /usr/bin/rtapi_app hm2_rpspi <stdin>:2: /usr/bin/rtapi_app exited without becoming ready <stdin>:2: insmod for hm2_rpspi failed, returned -1 halcmd:
same for CE0 or CE1 with 5 Mhz
with SPI debug :
pi@raspberrypi:~ $ halrun halcmd: loadrt hostmot2 Note: Using POSIX realtime hm2: loading Mesa HostMot2 driver version 0.15 halcmd: loadrt hm2_rpspi spi_probe=16 spi_debug=5 spiclk_rate=5000 hm2_rpspi: Platform: Raspberry Pi 4 Model B Rev 1.1 hm2_rpspi: Base address 0xfe000000 size 0x01800000 hm2_rpspi: Mapped peripherals from 0xfe000000 (size 0x01800000) to gpio:0x0xb4c97000, spi:0x0xb4c9b000, aux:0x0xb4cac000 hm2_rpspi: SPI1/CE2 clock rate: 5000000/5000000 Hz, VPU clock rate: 500000000 Hz hm2_rpspi: SPI1/CE2 write clock rate calculated: 5000000 Hz (clkdiv=100) hm2_rpspi: SPI1/CE2 read clock rate calculated: 5000000 Hz (clkdiv=100) hm2_rpspi: SPI1/CE2 Invalid cookie, read: 00000000 00000000 00000000, expected: 55aacafe 54534f48 32544f4d hm2_rpspi: SPI1/CE2 No drive seen on MISO line (kept at pull-down level). No board connected or bad connection? hm2_rpspi: rtapi_app_main: No such device (-19) <stdin>:2: waitpid failed /usr/bin/rtapi_app hm2_rpspi <stdin>:2: /usr/bin/rtapi_app exited without becoming ready <stdin>:2: insmod for hm2_rpspi failed, returned -1
Last edit: 6 years 10 months ago by gtt38.
6 years 10 months ago #153597 by gtt38
i tested CE0 or CE1 on SPI1 with 5Mhz, i hope it could help you to debug :
CE0 :
pi@raspberrypi:~ $ halrun halcmd: loadrt hostmot2 Note: Using POSIX realtime hm2: loading Mesa HostMot2 driver version 0.15 halcmd: loadrt hm2_rpspi spi_probe=4 spi_debug=5 spiclk_rate=5000 hm2_rpspi: Platform: Raspberry Pi 4 Model B Rev 1.1 hm2_rpspi: Base address 0xfe000000 size 0x01800000 hm2_rpspi: Mapped peripherals from 0xfe000000 (size 0x01800000) to gpio:0x0xb4c86000, spi:0x0xb4c8a000, aux:0x0xb4c9b000 hm2_rpspi: SPI1/CE0 clock rate: 5000000/5000000 Hz, VPU clock rate: 500000000 Hz hm2_rpspi: SPI1/CE0 write clock rate calculated: 5000000 Hz (clkdiv=100) hm2_rpspi: SPI1/CE0 read clock rate calculated: 5000000 Hz (clkdiv=100) hm2_rpspi: SPI1/CE0 Invalid cookie, read: 00000000 00000000 00000000, expected: 55aacafe 54534f48 32544f4d hm2_rpspi: SPI1/CE0 No drive seen on MISO line (kept at pull-down level). No board connected or bad connection? hm2_rpspi: rtapi_app_main: No such device (-19) <stdin>:2: waitpid failed /usr/bin/rtapi_app hm2_rpspi <stdin>:2: /usr/bin/rtapi_app exited without becoming ready <stdin>:2: insmod for hm2_rpspi failed, returned -1 halcmd:
CE1:
pi@raspberrypi:~ $ halrun halcmd: loadrt hostmot2 Note: Using POSIX realtime hm2: loading Mesa HostMot2 driver version 0.15 halcmd: loadrt hm2_rpspi spi_probe=8 spi_debug=5 spiclk_rate=5000 hm2_rpspi: Platform: Raspberry Pi 4 Model B Rev 1.1 hm2_rpspi: Base address 0xfe000000 size 0x01800000 hm2_rpspi: Mapped peripherals from 0xfe000000 (size 0x01800000) to gpio:0x0xb4cf4000, spi:0x0xb4cf8000, aux:0x0xb4d09000 hm2_rpspi: SPI1/CE1 clock rate: 5000000/5000000 Hz, VPU clock rate: 500000000 Hz hm2_rpspi: SPI1/CE1 write clock rate calculated: 5000000 Hz (clkdiv=100) hm2_rpspi: SPI1/CE1 read clock rate calculated: 5000000 Hz (clkdiv=100) hm2_rpspi: SPI1/CE1 Invalid cookie, read: 00000000 00000000 00000000, expected: 55aacafe 54534f48 32544f4d hm2_rpspi: SPI1/CE1 No drive seen on MISO line (kept at pull-down level). No board connected or bad connection? hm2_rpspi: rtapi_app_main: No such device (-19) <stdin>:2: waitpid failed /usr/bin/rtapi_app hm2_rpspi <stdin>:2: /usr/bin/rtapi_app exited without becoming ready <stdin>:2: insmod for hm2_rpspi failed, returned -1 halcmd:
@Bertho : I can run some test for you if you need to modify your driver.
Time to create page: 1.162 seconds
