Raspberry Pi 4
6 years 10 months ago #152403 by RyanG
Replied by RyanG on topic Raspberry Pi 4
phillc54 wrote: If you intend to use a parallel port then you should use stepconf rather than pncconf
Okay, since it isn't working do I need to get a different image?
6 years 10 months ago #152404 by RyanG
Gene1934 wrote: Whats your ipv4 address, I'll make sure iptables isn't blocking you, I've had quite a battle with the bots and since they change addresses nearly everyday, I've taken to using the CIDR /24 format when I block one. Not all are bad, I don't mind the indexers, but quite a few try to mirror it, and will come back the next day for a fresh copy. Do that enough times, and I'm DDOS'd for upload bandwidth. Its only a 10 megabit circuit, so about 350k/sec upload and my pipe is full.
So give me your address and I'll make sure it will clear.
Here you go: 10.72.13.141.
Thank you!
6 years 10 months ago #152410 by Gene1934
Replied by Gene1934 on topic Raspberry Pi 4
Nope, not on the block list. Should be good to go then. Add /lathe-stf to address bar and you should then see a linuxcnc4rpi4 directory to click on.
Cheers, Gene Heskett
"There are four boxes to be used in defense of liberty:
soap, ballot, jury, and ammo. Please use in that order."
-Ed Howdershelt (Author)
Genes Web page < geneslinuxbox.net:6309/gene >
6 years 10 months ago #152411 by RyanG
Gene1934 wrote: Nope, not on the block list. Should be good to go then. Add /lathe-stf to address bar and you should then see a linuxcnc4rpi4 directory to click on.
Okay. I will try again at home. I am at work and the firewall is most likely giving me issues.
6 years 10 months ago #152413 by Gene1934
That will likely change your outside address again.
email me at gheskett@shentel.net with the new one and I'll recheck, I have about 30 256 byte wide blocks in place.
6 years 10 months ago #153366 by CNCFred
Replied by CNCFred on topic Raspberry Pi 4
Hope this is still rpi4 thread.
I managed to get the Kernel 4.19y-rt running...
How do I get Linuxcnc now?
Copied it from the github...
But making it fails completely.
How to...
Autogen.sh exists but can't be executed...
I guess it needs to be made?
Any link appreciated....
Time to create page: 0.469 seconds
