Recommended PC configuration: CPU and Motherboard (Q1 2020)
  • Moderator
  • Moderator
19 Feb 2020 16:47 #157872 by tommylight
Thank you, but shipping that to Kosovo would get me in trouble with customs, i got fed up with them.
If i import a full truck of stuff i have to pay 29 + 3% of the total value and that is very nice, but if i import 2 Proma THC150 from Poland with the total price of 536 Euro (several years back) i ended up paying over 400 Euro in taxes and stuff! That is over 70%!
The way i have to do this is ask a friend in Germany or any other EU country to ship it to them, then they ship it to me.
That implies the friend has a company registered there as well as here.
To many hoops to jump.
19 Feb 2020 18:31 - 19 Feb 2020 18:32 #157884 by Mike_Eitel
Hi piter
Where in Switzerland are ou
Greeting from 8224
Last edit: 19 Feb 2020 18:32 by Mike_Eitel.
20 Feb 2020 09:29 #157962 by piter
And I was complaining about Switzerland..
Mike: greetings from Zurich
20 Feb 2020 14:09 #158006 by piter
Ok, I’m ready to buy it, but...I would just like one more confirmation: there really is no reason/advantage in getting a newer pc (the one i’m looking at is from 2013)? For example, will it support the latest versions of the OS/LinuxCNC/other required software?
  • Moderator
  • Moderator
20 Feb 2020 15:47 #158014 by tommylight
I just ordered 4 of the Core2Duo PC's with parallel port, at 25 Euro a piece !
Will report back later when i get them and do some tests.
20 Feb 2020 16:08 #158019 by Todd Zuercher
??? (it's been a few years since I last had anything to do with buying a new PC) The resource demands required for Linuxcnc are not all that high. And generally Linux often works better (installs with the least hassle) on a PC design that is a few years old anyway (so that any needed newish hardware drivers have had a chance to be sorted out).
My first Linuxcnc machine was set up 9 years ago using an old intel P4 computer with 1g memory that we had laying around (let's just say that it has some ISA card slots). It is still running the current version of Linuxcnc every day in a factory setting (albeit on the old Ubuntu 10.04 OS). The last new hardware I have used with Linuxcnc was an intel Celeron from a few years ago.
20 Feb 2020 16:13 #158021 by piter
Thanks, that’s exactly what I wanted to hear!
20 Feb 2020 17:01 #158029 by PCW
One caution about older PCs is that they may not be compatible with VTK
as the on board graphic hardware does not support the OpenGL features needed
This is needed for things like the new QtPyVCP GUI
Core Duo vintage PCs do not have the required graphics hardware for example
(you can work around this by adding a video card)
  • Moderator
  • Moderator
20 Feb 2020 18:18 #158038 by tommylight
Did not know that and never noticed as i use Axis gui.
Thank you.
20 Feb 2020 19:24 #158048 by Todd Zuercher
Thank you.
Axis uses OpenGL and will not work without it.
Time to create page: 0.664 seconds
