- Thank you received: 7491
Hardware latency tests, used PC's
I use Mate on almost all PC's and laptops, and XCFE on the older PC's and laptops.BeagleBrainz wrote: I'm using a J3355 and reckon Mint with MATE is too much of a resource hog, when there's Debian with XFCE available.
I'm really astonished by the number of people that want to use Mint & MATE, especially when Debian has a couple of lighter weight Desktop environment options.
And i use Debian on production machines that are used only for machining, Mate on ones that also do CAD/CAM. Just a preference.
Debian is also a bit lighter on resources even with Mate, do not know why, but it is.
- JohnnyCNC
- Thank you received: 115
First, why are you compiling kernels, there are already two of the 4.nn.n variety ready made and they both work nicely.
The H61M boards from Asus and Asrock mentioned above are 17X22.5Cm in dimensions, so very close to ITX, Asrock has a parallel port header, Asus does not, Asrock works with 2'nd and 3'd generation I3 and i5 processors, tested with an i5 2500 quad core works nicely. Most probably Asus would work too.
This was a few months back and I was doing it mostly for the educational benefit. I am currently playing with the pre-made kernels and Debian Buster. I just loaded installed it with Mate but still have to install LinuxCNC.
- BeagleBrainz
- Visitor
For running a Machine Debian is the way to go, I've been messing around with the LXQT desktop and kinda of liking it. Once the leg comes good and I can get in the shed I'll put it through it's paces on the mill.
-8GB RAM, 60GB SSD, i5 processor,
--default BIOS
--BIOS settings changed to disable everything, like speed step, hyperthreading, virtualisation, serial, modem, etc
Using it to run the machine with a Mesa 7i92, had 1 warning about latency while with default BIOS settings, no warnings when BIOS modified for the second day. Even when there was a warning the machine continued to work so no loss of connection occurred.
Overall very nice to work and use with Linux Mint 19.3 and RT-Preempt kernel.
The bad thing is on ebay there is only one on sale at 340$ ! I found 2 locally at 250Euro each without discount, but since i have some big discount on some of these, i might get them cheaper. Online here they cost 375 Euro a piece.
More on this later, i will have this till Monday to play with.
Removing and inserting the power adapter also does not cause any warnings or issues.
