- Thank you received: 234
LinuxCNC + Orange Pi (allwincnc)
- Bari
6 years 5 months ago #168512
by Bari
Replied by Bari on topic LinuxCNC + Orange Pi
SPI can be used for tuning. That is not a problem since the Allwinners have a working SPI interface.
- Blake_Volpex
6 years 5 months ago #168517
by Blake_Volpex
Replied by Blake_Volpex on topic LinuxCNC + Orange Pi
I'm not sure that's possible on the trinamic drivers, they are in step/direction mode or SPI.
Besides it ignores all the other advantages.
I will make my first prototype board to allow switching (with jumpers) and see about the software side.
Also I'm still curios what you meant by "long distance"
The drivers would be in the same enclosure as the orange pi, and I think spi is good to several feet.
- fb
6 years 5 months ago #169198
by fb
Replied by fb on topic LinuxCNC + Orange Pi
Hi MX_Master,
So I've got linuxcnc up and running on my orange pi (installer script works extremely well, thank you for all your work on that) - I haven't actually connected it to driver/motors quite yet, but I ran the latency test and note that jitter/latency is still quite high.
Is this something I should be concerned about, or does the jitter/normal latency not matter so much given that stepgen can now run on the separate RISC core (ie: not shared with the main CPU/kernel)?
- MX_Master
- Thank you received: 48
6 years 5 months ago #169199
by MX_Master
Replied by MX_Master on topic LinuxCNC + Orange Pi
Latency values for these boards are all about 50-100 us. Old kernel and OS versions has a bit better values. But when we using a separated CPU core, these latency values can be ignored.
- fb
6 years 5 months ago #169378
by fb
This is amazing news. I'm going to try things out properly with actual hardware very soon.
Is it just me, or does this make the orangepi's (or rather, the Allwinner H3/5/6 CPUs) kind of the ultimate platform in terms of cost vs performance for linuxcnc/machinekit?
I feel like this should be getting more attention
MX_Master wrote: ... But when we using a separated CPU core, these latency values can be ignored.
- gello0
6 years 5 months ago - 6 years 5 months ago #169387
by gello0
Replied by gello0 on topic LinuxCNC + Orange Pi
I am trying to install this on my orange pi zero (allwinner H2+) with latest armbian bionic but i keep getting these errors
install.log
Thank you.
install.log
Thank you.
Last edit: 6 years 5 months ago by gello0.
Time to create page: 0.466 seconds
