LinuxCNC + Orange Pi (allwincnc)
6 years 4 months ago #170730 by Bari
Replied by Bari on topic LinuxCNC + Orange Pi
Rockchip3399 has an integrated Cortex M0 so these might also be ale to run LCNC and hardware step without external hardware:
store.pine64.org/?product=rockpro64-4gb-single-board-computer
git.theobroma-systems.com/rk3399-cortex-m0.git
opensource.rock-chips.com/images/6/60/Ro...et_V1.6-20170301.pdf
www.theobroma-systems.com/rk3399-q7-user...ual/04-software.html
The board is also equipped with a PCIe x4 open ended slot, so you could use Mesa over PCIe, Ethernet or SPI if needed.
6 years 4 months ago #170863 by Bari
The integrated microcontroller uses a different core than the ones used in the Allwinners but the code could be adapted.
6 years 4 months ago #171205 by catur4widhi
Replied by catur4widhi on topic LinuxCNC + Orange Pi
great job mx_master..i have test it, that was works..orange pi 2 H3 both GPIO and ARISC work very nice. put step generator on my oscilloscope, the signal is uniformly god even at 400khz.
now im planing to build H6 RTkernel from armbian config, but not success yet..
6 years 4 months ago #171206 by catur4widhi
h3 core is not fast enough to run linuxcnc, im get bad lag runing gmoccapy and gscreen. i think h6 is more promissing, i was test h6 smoothly run gmoccapy in simulation mode (dont have rt kernel yet), h6 has more powerfull computation power and much higher clock.
6 years 4 months ago #171211 by MX_Master
Replied by MX_Master on topic LinuxCNC + Orange Pi
project's repo already contains the PREEMPT_RT kernel for H5/H6 (arm64). Use the install_rt_kernel.sh to install it.
But there's no gpio/arisc support for the H6 now. And there's no arisc support for the H5 (it has some issues with arm trusted firmware using arisc's memory).
6 years 4 months ago #171212 by catur4widhi
MX_master, i was try your PREEMPT_RT (arm64) kernel on H5 running fine n smooth, but doesnt work on H6. dont know why, but my h6 boot into initrams mode with your 64bit kernel
Time to create page: 1.077 seconds
