LinuxCNC + Orange Pi (allwincnc)
4 years 2 months ago - 4 years 2 months ago #250820 by yi2580
Replied by yi2580 on topic LinuxCNC + Orange Pi (allwincnc)
What a pity! Can you give me some suggestions on using this board for development? It's my first time to use this board. I hope I can get some help. I now have an RK3399 board, which is Orange Pi 4B. I don't know if he is feasible.
Last edit: 4 years 2 months ago by yi2580.
4 years 2 months ago - 4 years 2 months ago #250822 by Bari
Replied by Bari on topic LinuxCNC + Orange Pi (allwincnc)
opensource.rock-chips.com/wiki_RK3399
forum.linuxcnc.org/18-computer/46077-pot...ngle-board-computers
You just need developer/s that are familiar with u-boot, ARM Linux, LCNC and how to program the Cortex M0 microcontrollers.
I think it's a great ARM SOC for running LCNC with a high speed integrated stepgen, and the boards are available and only ~$60ea. It's a few week project for someone that knows what they are doing. It also has a GPU capable of running a HD display at 30fps.
Last edit: 4 years 2 months ago by Bari.
4 years 2 months ago #250825 by yi2580
OK, thank you very much for your suggestions. I don't know how to start. For example, how can I install a real-time kernel on my system to run Linux CNC? I also have an H3 board here. I have his system image. All Linux CNC has been installed and can be used, but it does not meet my requirements. I need a lot of IO ports, which seems to be a little small, so I consider using EtherCAT to realize it. I don't know whether it is feasible.
4 years 2 months ago #250828 by Bari
The most simple way is to use Mesa FPGA cards with a RK3399 boards over Ethernet. How to build RT ARM Linux kernels for RK3399 is beyond the scope of this forum.
EtherCAT discussions are at: www.forum.linuxcnc.org/ethercat
4 years 2 months ago #250830 by yi2580
I would like to ask how you installed the RT real-time kernel when using H3 card before? Can you give me some suggestions? I will be very grateful
4 years 2 months ago #250831 by Bari
I think this project started out using Armbian and there was a filesystem image that you could just dd onto an SD-card.
allwincnc.github.io/install.html
Time to create page: 0.898 seconds
