- Thank you received: 234
LinuxCNC + Orange Pi (allwincnc)
- Bari
4 years 1 month ago #252628
by Bari
Replied by Bari on topic LinuxCNC + Orange Pi (allwincnc)
"set the CPU min and max frequencies" they should be the same number/value since you don't want the speeds changing over temperature or load since this introduces latency spikes.
Does Armbian warn the user in big red letters about the 5-10 minute first boot "stuck" time?
- xylotex
4 years 1 month ago #252634
by xylotex
Replied by xylotex on topic LinuxCNC + Orange Pi (allwincnc)
I've followed the first boot process after the update/upgrade/install process. It does come to the resize and has an asterisk (iirc) going back and forth between the [ and ]. It finishes quick enough and continues. I'll watch again and see if it gives any specific information that might be useful before it continues the process.
Thanks.
Thanks.
- xylotex
4 years 1 month ago #252648
by xylotex
Hi, The resize did happen in the initial deployment of the armbian system right after the putting the uSD in the OrangePi after running the Raspberry Pi Imager (v1.7.3), and I found no problems there. It was rather quick as well (20 to 30seconds perhaps). It always stop with:
ALERT! UUID...... does not exist. Dropping to shell!
(initramfs)
but from there is is dead on both the debug UART and the USB/HDMI interface.
Jeff
(initramfs)
Jeff
- fery15sty
- Thank you received: 12
4 years 1 week ago - 4 years 1 week ago #254443
by fery15sty
Replied by fery15sty on topic LinuxCNC + Orange Pi (allwincnc)
please help me solve this problem. this problem appears after the installation is complete and restart
Last edit: 4 years 1 week ago by fery15sty.
- Xthyjd
4 years 1 week ago #254750
by Xthyjd
Replied by Xthyjd on topic LinuxCNC + Orange Pi (allwincnc)
I did everything a week ago according to the instructions using OPI
PC, Armbian_21.02.1_Orangepipc_buster_current_5.10.12_desktop.img, 2 attempts were not successful, after a reboot there were no responses from the board, but for some reason everything worked for the third time, I made a copy of the SD (15.5GB vhd) and continued setting up. If you have a place - I can upload it and write the username and password for root and cnc.
- virencq
- Thank you received: 5
3 years 11 months ago #256320
by virencq
Replied by virencq on topic LinuxCNC + Orange Pi (allwincnc)
Hello,
I have a working installation but my O code not loading. I have changed O to "o". mine file name is also in lowercase. not working at all.
[RS274NGC]
#RS274NGC_STARTUP_CODE = G18 G21 S05 G40 G49 G54 G80 G90 G94 G07 M09 M05 G64 P0.005 Q0.005
RS274NGC_STARTUP_CODE = O<setup> CALL
PARAMETER_FILE = linuxcnc.var
USER_M_PATH = /home/pi/linuxcnc/configs/OTM/m_codes/
SUBROUTINE_PATH = /home/pi/linuxcnc/configs/OTM/macros/
[RS274NGC]
Time to create page: 0.562 seconds
