LinuxCNC + Orange Pi (allwincnc)
- fb
28 May 2020 06:19 #169198
by fb
Replied by fb on topic LinuxCNC + Orange Pi
Hi MX_Master,
So I've got linuxcnc up and running on my orange pi (installer script works extremely well, thank you for all your work on that) - I haven't actually connected it to driver/motors quite yet, but I ran the latency test and note that jitter/latency is still quite high.
Is this something I should be concerned about, or does the jitter/normal latency not matter so much given that stepgen can now run on the separate RISC core (ie: not shared with the main CPU/kernel)?
- MX_Master
- Thank you received: 48
28 May 2020 07:20 #169199
by MX_Master
Replied by MX_Master on topic LinuxCNC + Orange Pi
Latency values for these boards are all about 50-100 us. Old kernel and OS versions has a bit better values. But when we using a separated CPU core, these latency values can be ignored.
- fb
30 May 2020 02:16 #169378
by fb
This is amazing news. I'm going to try things out properly with actual hardware very soon.
Is it just me, or does this make the orangepi's (or rather, the Allwinner H3/5/6 CPUs) kind of the ultimate platform in terms of cost vs performance for linuxcnc/machinekit?
I feel like this should be getting more attention
... But when we using a separated CPU core, these latency values can be ignored.
- gello0
30 May 2020 06:50 - 30 May 2020 06:52 #169387
by gello0
Replied by gello0 on topic LinuxCNC + Orange Pi
I am trying to install this on my orange pi zero (allwinner H2+) with latest armbian bionic but i keep getting these errors
install.log
Thank you.
install.log
Thank you.
Last edit: 30 May 2020 06:52 by gello0.
- Thank you received: 7374
30 May 2020 09:50 #169402
Replied by tommylight on topic LinuxCNC + Orange Pi
Enable the "partner" and "source code" repositories in the software sources, do an update and try to install again.
- MX_Master
30 May 2020 11:28 #169414
by MX_Master
Try DebianI am trying to install this on my orange pi zero (allwinner H2+) with latest armbian bionic but i keep getting these errors
install.log
Thank you.
- gello0
31 May 2020 13:56 #169516
by gello0
sorry I'm new to this, How do I enable "partner" and "source code" repositories?Enable the "partner" and "source code" repositories in the software sources, do an update and try to install again.
Getting same error in debin and Ubuntu, I downloaded them from orangepi.orgTry Debian
- MX_Master
31 May 2020 14:13 #169517
by MX_Master
Use Armbian images
- gello0
31 May 2020 14:19 #169518
by gello0
I was originally using armbian image that's didn't work either
- MX_Master
31 May 2020 14:30 #169520
by MX_Master
Try Armbian Buster and make
before project installation.
apt update & apt upgradebefore project installation.
Time to create page: 0.187 seconds
