LinuxCNC + Orange Pi (allwincnc)
24 Sep 2020 12:05 - 24 Sep 2020 12:09 #183575 by aekhv
Replied by aekhv on topic LinuxCNC + Orange Pi
This one works fine on OPi PC-plus:
Armbian_20.05.1_Orangepipcplus_buster_current_5.4.43_desktop.img.xz
As far as I know latest Armbian images are not supported, building process ends with error.
Last edit: 24 Sep 2020 12:09 by aekhv.
  • twoflowers
  • twoflowers's Avatar
  • Visitor
  • Visitor
24 Sep 2020 12:21 #183576 by twoflowers
Replied by twoflowers on topic LinuxCNC + Orange Pi
I have started from on the OrangePi Zero LTS (arrived yesterday :)) with Armbian_20.08.1_Orangepizero_buster_current_5.8.5.img.xz, then I converted it to Devuan, removing systemd and other things I don't like. "install.sh" installed an older kernel than armbian had to offer and LinuxCNC 2.7.15. Now I have:
Welcome to Devuan GNU/Linux 3 (beowulf) with Linux 5.4.18-rt11-sunxi
.. and it looks as if it works. Zero has no HDMI, so axis over ssh is a bit on the slow side, but works for me.
@fery15sty: It looks like you cannot reach the debian mirror at 151.101.10.133. I don't have that problem - I switched to devuan.
24 Sep 2020 12:31 #183578 by fery15sty
Replied by fery15sty on topic LinuxCNC + Orange Pi
ok, thanks for your answer. I will try it for my orangePi PC:
Armbian_20.05.1_Orangepipc_buster_current_5.4.43_desktop.img.xz
  • Moderator
  • Moderator
24 Sep 2020 12:47 #183580 by tommylight
Replied by tommylight on topic LinuxCNC + Orange Pi
E: Failed to fetch httpredir.debian.org/debian/pool/main/s/...-7~deb10u3_armhf.deb 404 Not Found [IP: 151.101.10.133 80]
E: Failed to fetch httpredir.debian.org/debian/pool/main/p/...tk_5.4.1-2_armhf.deb 404 Not Found [IP: 151.101.10.133 80]
E: Failed to fetch httpredir.debian.org/debian/pool/main/p/...il_5.4.1-2_armhf.deb 404 Not Found [IP: 151.101.10.133 80]
None of those addresses work.
sudo apt-get update
in a terminal should fix that.
The following user(s) said Thank You: fery15sty
24 Sep 2020 14:27 - 24 Sep 2020 14:28 #183597 by fery15sty
Thank you very much, I try again using Armbian:
Armbian_20.02.1_Orangepipc_buster_current_5.4.20_desktop.7z
After installing Armbian, I updated it
sudo apt-get update
and then
./install.sh
finished all, without any errors, done.
Thank you very much. I am very happy :)
Last edit: 24 Sep 2020 14:28 by fery15sty.
  • Moderator
  • Moderator
24 Sep 2020 20:29 #183618 by tommylight
You are welcomed, always.
Glad that it worked out.
  • twoflowers
  • Visitor
  • Visitor
25 Sep 2020 16:54 #183748 by twoflowers
I'm not so lucky :/ The older RT kernel does not agree with my new orangepi PC one plus. USB is not powered, ergo all USB devices don't work. The lates kernel from armbian works flawless. Network works, so this thing still can work as a networked controlle ...
But the installer worked without problems on OrangePi Zero LTS (USB is working) :)
26 Sep 2020 07:27 - 26 Sep 2020 07:44 #183800 by fery15sty
I've tried multiaxis (5axis) in my armbian, and it works fine. but some menus is not working..
in joint mode, joint 1 and joint 5 cannot manually jog
and
in word mode, axis c cannot manually jog
how to fix this problem?
Last edit: 26 Sep 2020 07:44 by fery15sty.
30 Sep 2020 18:12 #184400 by beardbird
Replied by beardbird on topic LinuxCNC + Orange Pi
Is there any progress on the skipping step issue? Is it suggested to not run my machine with an Orange Pi until it is resolved?
01 Oct 2020 08:29 - 01 Oct 2020 08:36 #184462 by pinder
Replied by pinder on topic LinuxCNC + Orange Pi
Huge thanks to MX_master,
I have been following the cnc-club.ru thread for a long time.
Now I have some boards to test.
CNC32.ru seems like not working.
Can someone point me in right direction for installing.
Update: Found quick start guide.
orangecnc.gitlab.io/quick-start.html
It should have been on the first post.
Last edit: 01 Oct 2020 08:36 by pinder.
Time to create page: 0.381 seconds
