- Hardware & Machines
- Computers and Hardware
- Results of latency test, list of computers tested for use with LinuxCNC
- Thank you received: 5330
01 Oct 2020 22:15 #184516
Replied by PCW on topic Results of latency test, list of computers tested for use with LinuxCNC
Intel chips are normally fine for Mesa Ethernet cards,
but you do need to disable IRQ coalescing as described
in the hm2_eth man page.
- BeagleBrainz
- Visitor
01 Oct 2020 22:46 #184520
by BeagleBrainz
Replied by BeagleBrainz on topic Results of latency test, list of computers tested for use with LinuxCNC
Just a thought.
Whilst all this testing is great, the average forum user isn’t going to wade through this many pages. It would really need collating and summarising.
Maybe a new topic just listing the machine and latency with a link to the actual test in this thread maybe the go. Keep the summary on the first post, just add an edit for a new test.
I don’t think the wiki gets used that much, sometimes I think the docs get just as much use.
- txtrone
- Thank you received: 106
02 Oct 2020 02:07 #184528
by txtrone
Replied by txtrone on topic Results of latency test, list of computers tested for use with LinuxCNC
Same Lenovo E430 BUT with upgraded RAM and new SSD drive. Tuned the BIOS as best I know how. Mint 19.3
LinuxCNC pc tests, version 20200930, started 01.10.2020 18:44:13
General info:
LENOVO, 3254CTO
Bios version H0ET98WW (2.58 ), dated 08/18/2016
Chipset: Intel Corporation 7 Series/C216
Harddisk is non-rotational, ie. SSD
The amount of swap currently used is 0
CPU related data:
model name : Intel(R) Core(TM) i5-3210M CPU @ 2.50GHz
cpu cores : 2
stepping : 9
cache size : 3072 KB
RAM related data:
Maximum Capacity: 16 GB
GPU related data:
product: 3rd Gen Core processor Graphics Controller
configuration: driver=i915 latency=0
Parallel port related data:
number of parallel ports is 0
Os and desktop related data:
PRETTY_NAME="Linux Mint 19.3"
Should the info below not match with your machine,
kindly post the output of pstree here, including a brief
desciption of your desktop environment, window manager and
display manager. Tia
https://forum.linuxcnc.org/18-computer/39370-script-for-automated-testing-of-computer-latency
Desktop environment : lightdm
Windowmanager : Xfwm4
Displaymanager : lightdm
Kernel related data:
Kernel 4.19.106-rt46-lcnc
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash"
Cpu idle driver: intel_idle
Kernel modules data:
Check if pcspkr is loaded: No, which is good!
Check if snd modules are loaded: No, which is good!
Keyboard & Mouse related data:
Number of mice: 2
Mouse 0 : SynPS/2 Synaptics TouchPad
Mouse 1 : TPPS/2 IBM TrackPoint
Mice attached to USB:
Keyboards attached to USB:
LinuxCNC related data:
LinuxCNC version is: 2.8.0
Preparing for latency test:
Started glxgears No. 1, 2, 3, 4, 5
Started firefox with 'https://vimeo.com/150574260', WID 71303171
Command for latency test is:
su oldlt -c "latency-histogram --nobase --sbinsize 1000 --nox 2>&1 | tee -a 1601595852.lat &"
Latency testing loop started Thu Oct 1 18:44:28 CDT 2020,
should end after Thu Oct 1 20:44:28 CDT 2020
Swap useage: prerun: 0, running: 0
CPU core temperatures:
Core 0: Tmin: 53.0°C, Tmax: 74.0°C, (high = +87.0°C, crit = +105.0°C)
Core 1: Tmin: 56.0°C, Tmax: 80.0°C, (high = +87.0°C, crit = +105.0°C)
last latency data is as follows:.
7203 secs servo min:-113.800 uS max: 121.800 uS sdev: 5.900 uS
7204 secs servo min:-113.800 uS max: 121.800 uS sdev: 5.900 uS
- seuchato
- Thank you received: 126
02 Oct 2020 10:49 #184550
by seuchato
Replied by seuchato on topic Results of latency test, list of computers tested for use with LinuxCNC
No problem. We are in no hurry. Support your brother, that's a very good thing to do.
greez
chris
greez
chris
- seuchato
02 Oct 2020 14:33 #184577
by seuchato
BeagleBrainz
a) There is off course search function that can shorten the "wading".
b) Agreed, but without c) it will probably end at the same level of insight as in the latency database . To me, the variety of information and quality thereof plus that many hardware details are missing in the wiki database, was the main motivation to write lcnc-hw and ask tommy to open this thread. It will need a high level of discipline and probably a guideline to write up good short comprehensive summaries. Of course if that thread was moderated and entries corrected by say a few authorized people that could be granted. In that case 100% agreed. But who is going to do this?
greez
chris
Just a thought.
a) Whilst all this testing is great, the average forum user isn’t going to wade through this many pages.
b) It would really need collating and summarising.
c) Maybe a new topic just listing the machine and latency with a link to the actual test in this thread maybe the go. Keep the summary on the first post, just add an edit for a new test.
BeagleBrainz
greez
chris
- Bari
- Thank you received: 234
03 Oct 2020 18:43 #184716
by Bari
Replied by Bari on topic Results of latency test, list of computers tested for use with LinuxCNC
One of the main issues in getting low latency is getting the BIOS configured properly. BIOSes are also often broken and the settings do not do as they are expected. This is one reason why the same CPU and chipset used on different motherboards will have different latency results.
Things in BIOS that should always be OFF:
Power management
Speed stepping/cpu core speed throttling
Virtualization
Fast Boot
Some of the info on the wiki about getting lower latency is also old. Trying an external graphics card has not helped for PC's made in the past 10 year.
I should rewrite the wiki page about lowering latency and what numbers are actually good vs poor. I should work on this with Mesa to post accurate info since I still see people asking about EPP modes on PCI/e LPT cards when not even using a Mesa FPGA.
Power management
Virtualization
Fast Boot
The following user(s) said Thank You: seuchato, tommylight
- seuchato
04 Oct 2020 01:10 #184767
by seuchato
100% agreed...
I will retest this, but I have not seen an effect on my pc's. Should my tests bring another result, I will edit this remark correspondingly. However, as we use our pcs for machining, the little extra time for normal boot will not really be harmful.
Thanks a ton
chris
Power management
Virtualization
100% agreed...
Fast Boot
Not sure about that. I am going to test this on this pc.Trying an external graphics card has not helped for PC's made in the past 10 year.
That rewrite and especially adding "what numbers are actually good vs poor" would be greatly appreciatedI should rewrite the wiki page about lowering latency and what numbers are actually good vs poor.
Thanks a ton
chris
- txtrone
05 Oct 2020 22:47 #185014
by txtrone
Same Lenovo E430. 16GB memory, new SSD, running Buster. I am happy with the results. I am going to run one more test on this rig, with the original HDD in it.
LinuxCNC pc tests, version 20200930, started 05.10.2020 15:37:04
General info:
LENOVO, 3254CTO
CPU related data:
cpu cores : 2
stepping : 9
RAM related data:
GPU related data:
PRETTY_NAME="Debian GNU/Linux 10 (buster)"
Desktop environment : xfce4
Kernel 4.19.0-10-rt-amd64
GRUB_CMDLINE_LINUX_DEFAULT="quiet"
Number of mice: 2
Started firefox with 'https://vimeo.com/150574260', WID 50331651
su oldlt -c "latency-histogram --nobase --sbinsize 1000 --nox 2>&1 | tee -a 1601930222.lat &"
Latency testing loop started Mon 05 Oct 2020 03:37:18 PM CDT,
should end after Mon 05 Oct 2020 05:37:18 PM CDT
Core 0: Tmin: 54.0°C, Tmax: 71.0°C, (high = +87.0°C, crit = +105.0°C)
Core 1: Tmin: 56.0°C, Tmax: 78.0°C, (high = +87.0°C, crit = +105.0°C)
7202 secs servo min: -73.900 uS max: 73.700 uS sdev: 5.100 uS
7203 secs servo min: -73.900 uS max: 73.700 uS sdev: 5.100 uSPlease Log in or Create an account to join the conversation.
- txtrone
06 Oct 2020 04:34 #185033
by txtrone
Same as above, bit with 7200 HDD.
LinuxCNC pc tests, version 20200930, started 05.10.2020 18:30:41
General info:
LENOVO, 3254CTO
Harddisk is rotational
CPU related data:
cpu cores : 2
stepping : 9
RAM related data:
GPU related data:
Number of mice: 2
Started firefox with 'https://vimeo.com/150574260', WID 48234499
su oldlt -c "latency-histogram --nobase --sbinsize 1000 --nox 2>&1 | tee -a 1601940640.lat &"
Latency testing loop started Mon 05 Oct 2020 06:30:57 PM CDT,
should end after Mon 05 Oct 2020 08:30:57 PM CDT
Core 0: Tmin: 54.0°C, Tmax: 68.0°C, (high = +87.0°C, crit = +105.0°C)
Core 1: Tmin: 56.0°C, Tmax: 72.0°C, (high = +87.0°C, crit = +105.0°C)
7201 secs servo min: -55.400 uS max: 55.100 uS sdev: 3.300 uS
7202 secs servo min: -55.400 uS max: 55.100 uS sdev: 3.300 uSPlease Log in or Create an account to join the conversation.
- seuchato
06 Oct 2020 07:22 #185038
by seuchato
txtrone
Quite astonishing that the results with hd give better results than with ssd!
I guess, tommylight would agree: really usable.
Greez
Chris
Greez
Chris
Time to create page: 0.151 seconds
