If you lookup this thread, you will find some entries of my 980s. I am running one of these using parport just fine. See here for example. Kindly checkout my other posts for these dell 980s. There is some finetuning ahead, but I guess the results speak for themselves.tommylight Thank you for your reply.
I recently got this computer. I have used it with OPTIPLEX 760 with parallel port connection. However, I am worried about when it will not start, so I am thinking about replacing it with this OPTIPLEX 980.
But does this mean there is a fatal delay?
Should I forgo using it on a parallel port?
I saw the thread here and bought "Optiplex 980" for $ 60.I have installed LinuxCNC 2.8.2 Debian10.It seems to have improved a little. I wish there was a better way.
LinuxCNC pc tests, version 20200930, started 09.03.2022 00:03:53
Desktop environment : gnome
Windowmanager : Xfwm4
Displaymanager : lightdm
Kernel related data:
Kernel 5.10.0-0.bpo.9-rt-amd64
GRUB_CMDLINE_LINUX_DEFAULT="quiet isolcpus=1"
Cpu idle driver: intel_idle
Kernel modules data:
Check if pcspkr is loaded: Yes, may cause bigger latency.
can be eliminated using:
sudo echo "install pcspkr /bin/true" >/etc/modprobe.d/pcspkr.conf
Check if snd modules are loaded: No, which is good!
Command for latency test is:
su linuxcnc -c "latency-histogram --bbinsize 1000 --base 25000 --sbinsize 1000 --nox 2>&1 | tee -a 1646751829.lat &"
>>>Unexpected realtime delay on task 0 with period 25000<<<
[/spoiler]
Hmmm. I don't know how to attach the result.
How do you paste it in a gray window?
Further, run the test again, but increase base to say 50'000. 50'000 is actually what I am using on my 980. Also check out my GRUB_CMDLINE_LINUX_DEFAULT (dig in this thread to find the last, best one. Further, doHow do you paste it in a gray window? use Block quote in advanced editor ( [ quote ] and [ / quote ] without the blanks)
It made some difference on my machine. In addition check out the colored parts in your output and compare them to what I have used. Ie.sudo echo "install pcspkr /bin/true" >/etc/modprobe.d/pcspkr.conf
