Results of latency test, list of computers tested for use with LinuxCNC
4 years 9 months ago - 4 years 9 months ago #233327 by arvidb
The same system with isolcpus=1 (and noirqbalance, but the latter doesn't seem to make a noticeable difference). The "standard" vimeo video was running, as well as a YouTube video.
Last edit: 4 years 9 months ago by arvidb.
The following user(s) said Thank You: seuchato, tommylight
4 years 8 months ago - 4 years 8 months ago #233799 by deus
Hi ,I am currently testing my Intel NUC7i5BNH which I plan to use with a MESA 7i76E.
First, I needed to change from nm-tray to network manager as I got a long list of icons on the top right:
sudo apt remove nm-tray
sudo apt install network-manager-gnome
Subsequently, I tried everything under the sun to get the latency down:
I disabled pretty much everything in the BIOS such as CPU related options (power saving, hyper-threading, turbo boost, 1 core only), any devices that are not needed (bluetooth, audio, microphone) and set the energy management to max performance. The only thing that I did not disabled (which I believe may affect latency according to other posts) is cooling, LAN and wireless which I intend to use during operations. But even when I switched them off they didn't seem to have a great impact on the latency.
I also added a long list of grub commands:
GRUB_CMDLINE_LINUX_DEFAULT="quiet transparent_hugepage=never splash mitigations=off isolcpus=1 acpi_irq_nobalance noirqbalance lapic nohlt idle=poll radeon.modeset=0 intel_idle.max_cstate=0 processor.max_cstate=0 ipv6.disable=1 pci=routeirq"
I  added 'vm.swappiness=0' to /etc/sysctl.conf
I added 'hardware−irq−coalesce−rx−usecs 0' to /etc/network/interfaces
I used the following command to avoid any sleep modes:
'sudo systemctl mask sleep.target suspend.target hibernate.target hybrid-sleep.target'
My latest latency data is below!
If anybody has some suggestions to further improve the latency that would be very much appreciated?!
I was also wondering if the below latency numbers are good enough to use the MESA 7i76E board?
In retrospect (considering the results I have seen in this thread), I should have gone for a Dell Optiplex 980 (i5) which would have been a 'hassle-free' to setup with superb latency performance. However, I really like the form factor of the NUC.
Thank you!
LinuxCNC pc tests, version 20200930, started 02.02.2022 13:32:31 ******************************************************************************** General info: Intel Corporation,  NUC7i5BNH Bios version BNKBL357.86A.0087.2021.1210.1903, dated 12/10/2021 Chipset: Harddisk is non-rotational, ie. SSD The amount of swap currently used is 0 ================================================================================ CPU related data: model name    : Intel(R) Core(TM) i5-7260U CPU @ 2.20GHz cpu cores    : 1 stepping    : 9 cache size    : 4096 KB ================================================================================ RAM related data: Maximum Capacity: 32 GB Maximum Voltage: 1.2 V Maximum Voltage: 1.2 V Size: 8192 MB Size: 8192 MB ================================================================================ GPU related data: product: Intel Corporation configuration: driver=i915 latency=0 ================================================================================ Parallel port related data: number of parallel ports is 0 ================================================================================ Os and desktop related data: PRETTY_NAME="Debian GNU/Linux 10 (buster)" Should the info below not match with your machine, kindly post the output of pstree here, including a brief desciption of your desktop environment, window manager and display manager. Tia https://forum.linuxcnc.org/18-computer/39370-script-for-automated-testing-of-computer-latency Desktop environment : xfce4 Windowmanager       : Xfwm4 Displaymanager      : lightdm ================================================================================ Kernel related data: Kernel 4.19.0-18-rt-amd64 GRUB_CMDLINE_LINUX_DEFAULT="quiet transparent_hugepage=never splash mitigations=off isolcpus=1 acpi_irq_nobalance noirqbalance lapic nohlt idle=poll radeon.modeset=0 intel_idle.max_cstate=0 processor.max_cstate=0 ipv6.disable=1 pci=routeirq" Cpu idle driver: none ================================================================================ Kernel modules data: Check if pcspkr is loaded: No, which is good! Check if snd modules are loaded: No, which is good! ================================================================================ Keyboard & Mouse related data: Number of mice: 1 Mouse 0 : HP HP USB 1000dpi Laser Mouse Mice  attached to USB: HP, Inc HID-compliant mouse Keyboards attached to USB: ================================================================================ LinuxCNC related data: LinuxCNC version is: 2.8.2.11.g6a3d0a434 ================================================================================ Preparing for latency test: Started glxgears No. 1, 2, 3, 4, 5 .......... Started firefox with 'https://vimeo.com/150574260', WID 50331651 ================================================================================ Command for latency test is: su cnc -c  "latency-histogram --nobase  --sbinsize 1000 --nox 2>&1 | tee -a 1643779951.lat &" Latency testing loop started Wed  2 Feb 13:32:44 AWST 2022,  should end after Wed  2 Feb 15:32:44 AWST 2022 ================================================================================ Swap useage: prerun: 0, running: 0 ================================================================================ CPU core temperatures: Core 0: Tmin: 49.0°C, Tmax: 55.0°C, (high = +100.0°C, crit = +100.0°C) ================================================================================ last latency data is as follows:.  7204 secs  servo min: -83.700 uS max:  86.400 uS sdev:   4.800 uS  7205 secs  servo min: -83.700 uS max:  86.400 uS sdev:   4.800 uS
Last edit: 4 years 8 months ago by deus.
The following user(s) said Thank You: seuchato, arvidb
4 years 8 months ago #233811 by seuchato
Hi deus
I think these are a LOT of options. I am not sure if one might bite the other. In order to rule out any bad influence by changing/adding just on option at a time, run the test and record the numbers along with a protocol of what you have changed. Guess that will keep you busy for quite a while :-)
But, honestly, I think the latency figures you get should be OK with ethernet based cards. I guess tommylight can give you a much more quilified answer, as I have not received my mesa cards to date.
Greez
chris
4 years 8 months ago #233813 by arvidb
This is probably a bad idea. The swappiness parameter sets the ratio between file page and anonymous page reclamation. Probably not what you wanted.
Read more here if you want: www.howtogeek.com/449691/what-is-swapine...nd-how-to-change-it/
4 years 8 months ago #233829 by seuchato
arvidb
Thx for the link. Read it once, will have to read it again, probably various times.
Greez
chris
The following user(s) said Thank You: arvidb
4 years 8 months ago - 4 years 8 months ago #233833 by seuchato
Hi, my ITX-ASRock880GXH with one onboard Parport and one PCIe Parport:
... ================================================================================ CPU related data: model name    : Intel(R) Celeron(R) J4005 CPU @ 2.00GHz cpu cores    : 2 stepping    : 1 cache size    : 4096 KB ...
I have question regarding the MoBo:
  • 880GXH suggests, the MoBo is for an AMD based one, see hereffff
  • But that cannot be, as far as I know, an Intel CPU would probably ieek itself out of an AMD socket ("Intel(R) Celeron(R) J4005 CPU @ 2.00GHz")
So: what is the exact MoBO?
remark to myself: have to add code in the script to depict as closely as possible the MoBo manufacturer and model
Greez
chris
PS: could it be this Mobo ?
Last edit: 4 years 8 months ago by seuchato. Reason: typos and link to intel MoBo
Time to create page: 0.498 seconds
