- Thank you received: 126
That seems to be a very good candiate, given, you still got room to improve. But I guess, tommlight would agree: good as it is now, no further improvments required. One caveat: The video stuff: Couldn't you see the vimeo video at all?LinuxCNC pc tests, version 20200930, started 10.03.2022 08:59:06
General info:
ASUSTeK COMPUTER INC., All Series
Bios version 2601, dated 12/08/2014
Chipset: Intel Corporation 9 Series
Harddisk is non-rotational, ie. SSD
The amount of swap currently used is 0
CPU related data:
model name : Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz
cpu cores : 4
stepping : 3
cache size : 8192 KB
RAM related data:
Maximum Capacity: 32 GB
Maximum Voltage: Unknown
Maximum Voltage: 1.5 V
Size: No Module Installed
GPU related data:
product: Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics Controller
configuration: driver=i915 latency=0
Parallel port related data:
number of parallel ports is 0
Os and desktop related data:
PRETTY_NAME="Debian GNU/Linux 10 (buster)"
Should the info below not match with your machine,
kindly post the output of pstree here, including a brief
desciption of your desktop environment, window manager and
display manager. Tia
forum.linuxcnc.org/18-computer/39370-scr...-of-computer-latency
Desktop environment : gnome
Windowmanager : Xfwm4
Displaymanager : lightdm
Kernel related data:
Kernel 4.19.0-19-rt-amd64
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash"
Cpu idle driver: intel_idle
Kernel modules data:
Check if pcspkr is loaded: No, which is good!
Check if snd modules are loaded: Yes, may cause bigger latency.
can probably be disabled in bios, alternatively, you can run
"./block-snd-modules"
which has just now been created for your convenience.
Keyboard & Mouse related data:
Number of mice: 1
Mouse 0 : Logitech USB Optical Mouse
Mice attached to USB:
Logitech, Inc. M105 Optical Mouse
Keyboards attached to USB:
Primax Electronics, Ltd HP PR1101U / Primax PMX-KPR1101U Keyboard
LinuxCNC related data:
LinuxCNC version is: 2.9.0~pre0.5982.gcebd57f65
Preparing for latency test:
Started glxgears No. 1, 2, 3, 4, 5
Started firefox with ' vimeo.com/150574260 ', WID 88080428
Command for latency test is:
su mauro -c "latency-histogram --nobase --sbinsize 1000 --nox 2>&1 | tee -a 1646899127.lat &"
Latency testing loop started gio 10 mar 2022, 08.59.18, CET,
should end after gio 10 mar 2022, 10.59.18, CET
Swap useage: prerun: 0, running: 0
CPU core temperatures:
Core 0: Tmin: 28.0°C, Tmax: 56.0°C, (high = +80.0°C, crit = +100.0°C)
Core 1: Tmin: 27.0°C, Tmax: 60.0°C, (high = +80.0°C, crit = +100.0°C)
Core 2: Tmin: 28.0°C, Tmax: 58.0°C, (high = +80.0°C, crit = +100.0°C)
Core 3: Tmin: 24.0°C, Tmax: 55.0°C, (high = +80.0°C, crit = +100.0°C)
last latency data is as follows:.
7202 s servo min: -30.400 us max: 30.300 us sdev: 0.700 us
LinuxCNC pc tests, version 20200930, started 10.03.2022 02:10:07
General info:
Dell Inc., OptiPlex 980
Bios version A18, dated 02/27/2018
Chipset: Intel Corporation 5 Series/3400 Series
CPU related data:
model name : Intel(R) Core(TM) i5 CPU 650 @ 3.20GHz
cpu cores : 2
stepping : 5
cache size : 4096 KB
RAM related data:
Maximum Capacity: 16 GB
GPU related data:
product: Core Processor Integrated Graphics Controller
number of parallel ports is 1
parport0: PC-style at 0x378 (0x778), irq 7 [PCSPP,TRISTATE,EPP]
Desktop environment : kdeconnectd
Windowmanager : KWin
GRUB_CMDLINE_LINUX_DEFAULT="quiet isolcpus=1 mitigations=off intel_idle.max_cstate=0 processor.max_cstate=0 idle=poll acpi_irq_nobalance noirqbalance"
Cpu idle driver: none
Check if snd modules are loaded: No, which is good!
Number of mice: 2
Mouse 0 : CATEX TECH. 84EC-S Mouse
Mouse 1 : Logitech M570
LinuxCNC version is: 2.8.2.11.g6a3d0a434
Started firefox with ' vimeo.com/150574260 ', WID 71303372
su optiplex980 -c "latency-histogram --bbinsize 1000 --base 25000 --sbinsize 1000 --nox 2>&1 | tee -a 1646845802.lat &"
Latency testing loop started 2022年 3月 10日 木曜日 02:10:21 JST,
should end after 2022年 3月 10日 木曜日 04:10:21 JST
=====================Terminal===========================================================
Core 0: Tmin: 53.0°C, Tmax: 63.0°C, (high = +89.0°C, crit = +105.0°C)
Core 2: Tmin: 53.0°C, Tmax: 61.0°C, (high = +89.0°C, crit = +105.0°C)
7204 secs base min: -18.300 uS max: 15.500 uS sdev: 0.200 uS
7204 secs servo min: -12.300 uS max: 12.300 uS sdev: 0.500 uS
LinuxCNC pc tests, version 20200930, started 10.03.2022 08:49:32
General info:
CPU related data:
cpu cores : 2
stepping : 5
RAM related data:
GPU related data:
Number of mice: 2
Started firefox with ' vimeo.com/150574260 ', WID 71303422
su optiplex980 -c "latency-histogram --bbinsize 1000 --base 50000 --sbinsize 1000 --nox 2>&1 | tee -a 1646869745.lat &"
Latency testing loop started 2022年 3月 10日 木曜日 08:49:45 JST,
should end after 2022年 3月 10日 木曜日 10:49:45 JST
Core 0: Tmin: 50.0°C, Tmax: 62.0°C, (high = +89.0°C, crit = +105.0°C)
Core 2: Tmin: 51.0°C, Tmax: 60.0°C, (high = +89.0°C, crit = +105.0°C)
7202 secs base min: -19.200 uS max: 17.300 uS sdev: 0.300 uS
7202 secs servo min: -15.400 uS max: 14.800 uS sdev: 0.600 uS
I tried to verify this on different machines, even a windows pc. Never got this message. Could you kindly try again manually and describe what you did as close as possible?I am trying the script, it works but the video does not start "video not rated" I let it go like this?
in a terminal while running the script?wmctrl -l | grep -i vimeo
The "Jugg a Jug" should change as soon as the next video is being played. Kindly also verify this.0x050002ac 0 {pcname} Jugg a Jug on Vimeo - Mozilla Firefox
