Results of latency test, list of computers tested for use with LinuxCNC
2 years 10 months ago #287309 by tommylight
For parallel port use the Buster official ISO and install the RTAI kernel as described in the downloads page.
For mesa, use the 2.9.1 ISO or install Debian 12 BookWorm and do
sudo apt update
sudo apt install linuxcnc-uspace
reboot and enjoy.
2 years 10 months ago #287310 by tommylight
Word of warning tho, whilst it does have an on board Parallel port header it does require a genuine Lenovo parallel port cable to work. Tried a standard one and no luck. Haven’t done any reverse engineering of it.
Normal or mini header?
For normal header with normal DB25 port/cable, the side with the red line on the wire goes on the pin1 side of the header. Be aware that some DB25 adapters/cables have that backwards, so inserting it in reverse bares no risk and might work.
2 years 10 months ago - 2 years 10 months ago #287316 by Cant do this anymore bye all
Using a normal 0.1" header the parallel port options aren't shown in the BIOS setup. Use the Lenovo one and they show up. I'm guessing that one of the GND pins or pin 26 is connected to a GPIO on the incarnation of the Super IO chip. I know that for the serial port header there is a COM_DETECT pin, so the same kind of thing is at play with the Parallel I guess.
Like I said I didn't decide to pull the thing apart to find out what was going on.
Seems to be pin 18 on the header is the PR_DET# pin.
Last edit: 2 years 10 months ago by Cant do this anymore bye all.
2 years 10 months ago - 2 years 10 months ago #287524 by Glite
Asus Prime J4005I-C
Turbo boost enabled
C states disabled
Command line: idle=poll mitigations=off cpufreq.default_governor=performance
7203 s  servo min: -88.800 us max:  92.000 us sdev: 2.600 us Core 0: +68.0°C (high = +105.0°C, crit = +105.0°C) Core 1: +68.0°C (high = +105.0°C, crit = +105.0°C)
Last edit: 2 years 10 months ago by Glite.
The following user(s) said Thank You: seuchato, tommylight, zmrdko, Unlogic
2 years 10 months ago #287849 by CNC_ANDI
2 years 10 months ago #287859 by tommylight
Time to create page: 0.138 seconds
