- Thank you received: 126
Can't really speak for the T610. I played with a 8300 sff, see here . My conclusions playing with the 8300 were confirmed while playing with my dell 980s, too. Looking forward to the bios settings of your T610. Hopefully I can test the T620 and T630 in the mean time, too.Joco wrote: Thanks Chris. I will go over things again and I think I might post the bios settings here to act as a reference. BIOS is at v1.10. I looked at the 1.20 release notes and the only comment was some security related stuff that is not relevant so I have not risked a BIOS update.
As mentioned: I could not use the t630 until I upgraded the bios, thus: imho yes, BIOS update helps. So far I have not tested it with LCNC, that will follow. My machine has a single 4GB RAM. I am sure, it will be much more performant with two bars. I got OpenSuse on the T630 on a sata based M.2 SSD: very useable!Joco wrote: I can pick up a T630 with 4GB RAM and a 32GB SSD for about $60NZD (around 36USD). Would that be worth getting and pushing the BIOS forward? For the use I plan for it 4GB is actually heaps given it is intended to only be running linuxcnc and even the GUI is going to be run on a remote X11 server. Probably a nice portable laptop. The T6xx0 will be inside an enclosure connected to a 7i76e and a USB3 wifi or ethernet adaptor linking it to said laptop.
Thoughts really welcome as these wee boxes are super cheap and I hope for ethernet connected h/w StepGen able to do the job.
