Ok, Im getting this error Linuxcnc side when I try to get out of estop
Bad SPI payload = 0
sometimes
Bad SPI payload = ffffffff
This is what I get from UART
Remora PRU - Programmable Realtime Unit
## Entering SETUP state
1. Reading json configuration file
Mounting the filesystem... OK
Opening "/fs/config.txt"... OK
Json config file lenght = 2381
Closing "/fs/config.txt"...
2. Setting up DMA and threads
Creating thread 40000
Creating thread 1000
3. ParsiConfig deserialisation - Deserialization succeeded
Servo thread object
Reset pin
Make Reset Pinule
Creating Pin @
portNumber = 1
pin = 31
Base thread object
X - Joint 0 step generator
Creating a std module
Creating Pin @
portNumber = 2
pin = 1
Creating Pin @
portNumber = 2
pin = 2
Creating Pin @
portNumber = 2
pin = 6
Base thread r
Creating Pin @
portNumber = 2
pin = 8
Creating Pin @
portNumber = 0
pin = 19
Creating Pin @
portNumber = 0
pin = 20
Base thread object
Z - Joint 2 step generator
Creating Pin @
portNumber = 0
pin = 21
Creating Pin @
portNumber = 0
pin = 22
Creating Pin @
portNumber = 2
pin = 11
Base thread object
E0 - Joint 3 step generator
Creating Pin @
portNumber = 2
pin = 12
Creating Pin @
portNumber = 2
pin = 13
Creating Pin @
portNumber = 0
pin = 11
Servo thread object
Make Temperature measurement object
Extruder tenperature sensor
Creating a slower module, updating every 1000 thread cycles
Creating Thermistor Tempearture measurement @ pin 0.23
Creating Pin @
portNumber = 0
pin = 23
Temperature sensor error, pin 0.23 reading = -273.15
Temperature sensor error, pin 0.23 reading = -86.8344
Start temperature = -86.8344
Base thread object
RC servo for probe
Make RC Servo at pin 2.0
Creating a slower module, updating every 4000 thread cycles
Creating RC servo at pin 2.0
Creating Pin @
portNumber = 2
pin = 0
Base thread object
Encoder
Creating Quadrature Encoder at pins 1.20 and 1.22
Encoder has index at pin 8
Creating Pin @
portNumber = 1
pin = 20
Creating Pin @
portNumber = 1
pin = 22
Creating Pin @
portNumber = 8
Servo thread object
X min
Make Digital Input at pin 1.29
Creating Pin @
portNumber = 1
pin = 29
Servo thread object
X max
Make Digital Input at pin 1.28
Creating Pin @
portNumber = 1
pin = 28
Servo thread object
Y min
Make Digital Input at pin 1.27
Creating Pin @
portNumber = 1
pin = 27
Servo thread object
Y max
Make Digital Input at pin 1.26
Creating Pin @
portNumber = 1
pin = 26
Servo thread object
Z min
Make Digital Input at pin 1.25
Creating Pin @
portNumber = 1
pin = 25
Servo thread object
Z max
Make Digital Input at pin 1.24
Creating Pin @
portNumber = 1
pin = 24
Servo thread object
Extruder fan switch
Make Switch (On) at pin 0.0
Creating a Switch @ pin 0.0
Creating Pin @
portNumber = 0
pin = 0
## Entering START state
Starting the BASE thread
Registering interrupt for interrupt number = 1
power on timer
timer set MCR
timer set PR
timer set PRO
timer start
++ MbedOS Fault Handler ++
FaultType: HardFault
Context:
R0 : 10003C00
R1 : AA3DE7CC
R2 : 00000016
R3 : FEFFC713
R4 : 10003B78
R5 : 00000068
R6 : 00000001
R7 : 00000000
R8 : 00000000
R9 : 200801E0
R10 : 20081324
R11 : 00000006
R12 : 00C80000
SP : 10007F80
LR : 00010995
PC : 0000FE8E
xPSR : 21000011
PSP : C1688394
MSP : 10007F60
CPUID: 412FC230
HFSR : 40000000
MMFSR: 00000000
BFSR : 00000082
UFSR : 00000000
DFSR : 00000000
AFSR : 00000000
BFAR : AA3DE7E0
Mode : Handler
Priv : Privileged
Stack: MSP
-- MbedOS Fault Handler --
Cable is 4in long. Copied exactly the same as manual, even colour.
Config is remora-xyz sample config
Board is skr v1.4 , with lcp1768
Loaded firmware lcp1768 firmware.bin to the root of sd
Loaded skr1.3 config.txt to root of sd
How can I diagnose this?
Ive done this from the github, but dont know where to go now.
Remora running now on RPi 4 without issues! The SPI clock is provided by the GPU so adding gpu_freq=200 into /boot/config.txt did the trick. I'll update the docs.
