- Thank you received: 489
scotta wrote: The hard fault output at the bottom points to a configuration error. And my guess is its the encoder. This is the error "Encoder has index at pin 8". This is not a valid port and pin assignment. And you will see that the pin is not created properly at the bottom. If you do not need the encoder remove it from the config.txt and see what happens.
