- Hardware & Machines
- Computers and Hardware
- Remora - Rpi Software Stepping Using External Microcontroller via SPI
- Zuo99
HI,cakeslob Thank you very much for your help, I have tried the relevant content of octopus pro 429 and it works well.new Skr2 with stm32f429vgt works with octopus pro 429 firmware and regular skr2 config , so same old skr2 but with 180mhz
i set up uart pins for octopus to use tft connector same as skr2 for consistency
What interests me is that you mentioned the issue of Skr2 with stm32f429vgt, I pre-ordered a Skr2 before, but I received it recently because of the manufacturer's problem, so I also tried it, but there are some problems, after starting a Communication will be disconnected after the meeting, I noticed 180mhz in your description, where should it be changed, I tried to change it in the file below, but it doesn't seem to work
Remora/Firmware/FirmwareSource/Remora-OS5/TARGET_SKRV2/system_clock.c
Do I need to change any other files
- Zuo99
Here's what I did:
1 Octopus pro 429 firmware in the sd card of SKR2, old skr2 config.txt
2 Replace system_clock.c of skr v2 with system_clock.c of octopus pro 429
3 Delete the content in the old skr2 config.txt except the motor drive part
It seems that the content in config.txt affects the SPI communication
- Zuo99
How was it when you tested the SKR2 429 earlier?
Thank you for your help
- cakeslob
- Thank you received: 280
The issue you describe, try this config file , or see if your config has this section, and if not, try adding this. the skr2 has an anti reversing thing for the stepper drives with an io that needs to be turned on to get power to the stepper drives,
"Thread": "On load",
"Type": "Motor Power",
"Comment": "Enable motor power SKR2",
"Pin": "PC_13"
},Attachments:
- cakeslob
"Board": "BIGTREETECH SKR v2",
"Modules":[
"Thread": "Servo",
"Type": "Reset Pin",
"Comment": "Reset pin",
"Pin": "PC_4"
"Pin": "PC_13"
"Thread": "Base",
"Type": "Stepgen",
"Comment": "X - Joint 0 step generator",
"Joint Number": 0,
"Step Pin": "PE_2",
"Direction Pin": "PE_1",
"Enable Pin": "PE_3"
"Thread": "Base",
"Type": "Stepgen",
"Comment": "Y - Joint 1 step generator",
"Joint Number": 1,
"Step Pin": "PD_5",
"Direction Pin": "PD_4",
"Enable Pin": "PD_6"
"Thread": "Base",
"Type": "Stepgen",
"Comment": "Z - Joint 2 step generator",
"Joint Number": 2,
"Step Pin": "PA_15",
"Direction Pin": "PA_8",
"Enable Pin": "PD_1"
}Please Log in or Create an account to join the conversation.
- Zuo99
thanks again for your work
- scotta
- Thank you received: 489
Is this a feature, the Flash storage that is, that people would use on 3D printer controller boards. This would allow the removal of the SD card. The only time the SD card would need to be inserted would be for firmware or config updates.
Thoughts?
- Thank you received: 7488
Does not have resume after power off though, although i rarely need it.
- drewnabobber
- Thank you received: 27
In the work I have been doing on the NVEM Ethernet version of Remora I have now been able to store and retrieve the config.txt file contents to and from the Flash memory of the STM32. I've been working on this as there is no SD card on the NVEM and we can send the config over Ethernet to the board.
Either this method or else a protocol to receive the configuration at startup would be quite useful to extend remora to boards that do not have an SD slot. Although in many cases I think it could be enough to simply make it easy to custom-compile a fixed feature build where the steppers, inputs and outputs are hard-coded.
- cakeslob
