1 year 2 months ago #334007 by scotta
Hi Gusugs,
Thanks for sharing your setup. In your ini file your accelerations are extremely high, way higher than I use in 3D printing.
Also, your FERROR of 0.025 and MIN_FERROR of 0.25 are the most likely causes. These are way way to small. You need enough allowable following error for the control loop to do it's thing.
Have a look at some of the example configs to get a feel for what is needed.
github.com/scottalford75/Remora/tree/mai...nuxCNC/ConfigSamples
The following user(s) said Thank You: Gusgus
1 year 2 months ago #334009 by Gusgus
We have used this settings before, and the machine worked fantastic, the only change we've made is the change from raspberry pi 3 to 5 and the Remora version change. Well attempt config changes. Thankyou Scotta!
1 year 2 months ago #334010 by Gusgus
forgot to add, we don't use this for 3d printing but as a router, it has the dm556s connected to NEMA 23 motors.
1 year 2 months ago #334014 by Gusgus
Hi again and thanks for all the help up until now!
I wan't to give more context and explain myself better, we have been using this cnc router since 2023, originally setup with a raspberry pi 3b and octopus pro combo, it has worked wonders and is amazing the only real issue is that the raspberry pi 3b was slow. Recently we made the change to a raspberry pi 5, we took the original .ini and .hal files which we then update to be compatible with the new remora version, we kept the same config.txt file. We installed the linuxcnc-raspberrypi5 image and installed the remora components as instructed in the documentation.
The issues we've seen: when we first loaded linuxcnc and ran the .ini file by double clicking on it and choosing linuxcnc as the app to run the ini file we then saw the raspberry pi 5 using rp1 driver alert, we initially thought this was error but figured this was just an alert and so continued. We then started testing leaving e stop we could but just for a moment, no more than 3s, we could even get to enable but non of the drivers actually enable. We then tested if this was the E-stop's fault but we assumed it wasn't since if we disconnected the estop we could exit estop at all, wehn it was properly setup we could but can't enable the steppers fisically. This isn't a stepper issue or driver issue since they get enabled with the raspberry pi 3.
Thanks in advance and thank you for all of the help until now! Oh and sorry for any grammar or spelling mistakes, english isn't our first tounge.
1 year 2 months ago #334159 by scotta
Ok, so I pulled out my octopus board and RPi5 to see what could be the issue. I found my working config and noted:
#SERVO_PERIOD = 1000000
SERVO_PERIOD = 5000000
Making this change to your config, I got it up and running. With the faster servo period the board was throwing so many communication errors.
1 year 2 months ago #334160 by scotta
Sorry, forgot to mention updated hal line as well to set the SPI speed to 2Mhz, the default 20Mhz is probably the issue.
loadrt remora-spi SPI_num=0 CS_num=0 SPI_freq=2000000
Time to create page: 0.321 seconds
