1 year 1 month ago #334526 by Gusgus
Hi tommylight!
We have tested the spinndle idea but the error happens regardless of if its on or off. We use and unshielded cable, let me test that out.
1 year 1 month ago - 1 year 1 month ago #334528 by amanker
If someone can give me example config.txt and config files hal and ini for skr3 board, it would be really helpful. Or look at my config files for skr3.
Last edit: 1 year 1 month ago by amanker.
1 year 1 month ago #334531 by amanker
When machine comes out of estop it gives error "Remora FATAL ERROR [JASON Config]: Config file open failed (status=0xA2)".
1 year 1 month ago #334533 by amanker
The above error is sorted out. But still joint following error
1 year 1 month ago - 1 year 1 month ago #334583 by oodanner
I posted something I thought might be helpful since it seemed to fix my problem but, then it started happening again.  My SPI interface keeps getting reset as well and only when my spindle gets turned on.  I already created a shielded cable between the SPI connections. I thought messing with the base servo speed helped in the ini file at one point but, I just tried again and got the same microcontroller reset.  After that I have to reset the microcontroller before I get a good status signal for the SPI connection and I can toggle machine power once again and communications work as well.  I guess it could be interference on the SPI interface still but, I'm not sure how that is happening. EDIT:  I guess after creating a shielded SPI cable it did work for longer before getting an SPI reset.  I still had issues and I just put a piece of tin foil over no directly onto the raspberry pi4 GPIO pins and it looks like all of my errors are gone so maybe some EMI was getting into the raspberry pi pins and resetting the controller somehow?  I'm still testing to see if my problem is gone for good but, fingers crossed.
Last edit: 1 year 1 month ago by oodanner.
1 year 1 month ago #334584 by oodanner
I had a joint following error as well but, it was because my default jog speed was set too high for my set up. Not sure if this is happening to you but, thought I would mention it.
Time to create page: 0.524 seconds
