- Hardware & Machines
- Computers and Hardware
- Remora - Rpi Software Stepping Using External Microcontroller via SPI
- amanker
07 Sep 2025 18:34 - 07 Sep 2025 18:36 #334585
by amanker
Replied by amanker on topic Remora - Rpi Software Stepping Using External Microcontroller via SPI
Can anyone help me in setting up remora on btt skr3 board. I have posted my config files on previous posts.
Now can I can make LinuxCNC to come out of estop. But stepper don't move, not even slightly. Don't feel like stepper is energized. Getting joint following error. LinuxCNC display dev/ttyAMA10 device, I connected through minicom but can't get any output on screen.
PS. I am not new to remora, earlier I was using on Octopus pro board, now when newer Remora supported TMC5160 on skr3, so I changed the board.
Last edit: 07 Sep 2025 18:36 by amanker.
- amanker
08 Sep 2025 14:40 #334627
by amanker
I can see remora input or joint cmd in HAL Meter. But nothing happnes in GUI. If I press limit switch, I can see remora input in HAL Meter but there is no msg regarding limit switch in GUI.
- oodanner
08 Sep 2025 15:28 #334634
by oodanner
Replied by oodanner on topic Remora - Rpi Software Stepping Using External Microcontroller via SPI
Have you tried to open the HAL configuration after the axis gui comes up and add in the pins you want to monitor. I would have the SPI status and enable pins there to check and see if your SPI connection is stable. I initially had a problem with the board I was using not getting a good flash and I had to use the BTT tool they talk about in their wiki to rewrite the original firmware before I could load the Remora firmware.bin to the root of the SD card and then it finally loaded the firmware correctly. I also ran into some issues with the firmware constantly resetting itself if I tried certain settings in my config.txt file. This is what I currently have in the conifg.txt file which may not be helpful since I'm running an Octopus v1.1 board.
"Board": "BIGTREETECH OCTOPUS PRO V1.1 STM32F446",
"Modules": [
"Thread": "Servo",
"Type": "Digital Pin",
"Comment": "X-min endstop",
"Pin": "PG_9",
"Mode": "Input",
"Invert": "True",
"Data Bit": "1",
"Modifier": "Pull Up"
"Thread": "Servo",
"Comment": "Y1-min endstop (left Y motor)",
"Pin": "PG_10",
"Mode": "Input",
"Invert": "True",
"Data Bit": "2",
"Thread": "Servo",
"Comment": "Y2-min endstop (right Y motor)",
"Pin": "PG_11",
"Mode": "Input",
"Invert": "True",
"Data Bit": "3",
"Thread": "Servo",
"Comment": "Z-min endstop",
"Pin": "PG_12",
"Mode": "Input",
"Invert": "True",
"Data Bit": "4",
"Thread": "Servo",
"Comment": "E-stop input",
"Pin": "PG_15",
"Mode": "Input",
"Invert": "True",
"Data Bit": "5",
"Thread": "Servo",
"Comment": "Probe input",
"Pin": "PB_7",
"Mode": "Input",
"Data Bit": "6",
"Thread": "Servo",
"Comment": "Coolant flood",
"Pin": "PD_12",
"Mode": "Output",
"Data Bit": "1"
"Thread": "Servo",
"Comment": "Coolant mist",
"Pin": "PD_13",
"Mode": "Output",
"Data Bit": "2"
"Thread": "Base",
"Type": "Stepgen",
"Comment": "X-axis - Stepper Driver 0",
"Joint Number": 0,
"Step Pin": "PF_13",
"Direction Pin": "PF_12",
"Enable Pin": "PF_14"
"Thread": "Base",
"Type": "Stepgen",
"Comment": "Y1-axis (left Y motor) - Stepper Driver 1",
"Joint Number": 1,
"Step Pin": "PG_0",
"Direction Pin": "PG_1",
"Enable Pin": "PF_15"
"Thread": "Base",
"Type": "Stepgen",
"Comment": "Y2-axis (right Y motor) - Stepper Driver 2",
"Joint Number": 2,
"Step Pin": "PF_11",
"Direction Pin": "PG_3",
"Enable Pin": "PG_5"
"Thread": "Base",
"Type": "Stepgen",
"Comment": "Z-axis - Stepper Driver 3",
"Joint Number": 3,
"Step Pin": "PG_4",
"Direction Pin": "PC_1",
"Enable Pin": "PA_0"
"Thread": "Servo",
"Type": "Reset Pin",
"Comment": "Reset pin",
"Pin": "PC_15"
"Modules": [
"Thread": "Servo",
"Pin": "PG_9",
"Mode": "Input",
"Invert": "True",
"Data Bit": "1",
"Thread": "Servo",
"Pin": "PG_10",
"Mode": "Input",
"Invert": "True",
"Data Bit": "2",
"Thread": "Servo",
"Pin": "PG_11",
"Mode": "Input",
"Invert": "True",
"Data Bit": "3",
"Thread": "Servo",
"Pin": "PG_12",
"Mode": "Input",
"Invert": "True",
"Data Bit": "4",
"Thread": "Servo",
"Pin": "PG_15",
"Mode": "Input",
"Invert": "True",
"Data Bit": "5",
"Thread": "Servo",
"Pin": "PB_7",
"Mode": "Input",
"Data Bit": "6",
"Thread": "Servo",
"Pin": "PD_12",
"Mode": "Output",
"Data Bit": "1"
"Thread": "Servo",
"Pin": "PD_13",
"Mode": "Output",
"Data Bit": "2"
"Thread": "Base",
"Type": "Stepgen",
"Joint Number": 0,
"Thread": "Base",
"Type": "Stepgen",
"Joint Number": 1,
"Step Pin": "PG_0",
"Thread": "Base",
"Type": "Stepgen",
"Joint Number": 2,
"Thread": "Base",
"Type": "Stepgen",
"Joint Number": 3,
"Step Pin": "PG_4",
"Thread": "Servo",
"Pin": "PC_15"
- amanker
08 Sep 2025 17:22 #334641
by amanker
Yes I checked spi status. There was no problem. I also added Blink module to check if firmware is flashed correctly and working. I too had octopus pro board. But I wanted tmc5160 drivers working so I bought skr3. I can see signals in hal meter, but in GUI I am getting No signals what ever
- oodanner
08 Sep 2025 18:50 #334646
by oodanner
On the bright side I figured out what my problem was. I had followed the documentation with recommended the preconfigured xpatria raspberry pi build and that did make getting everything up and running easy but, I didn't think to git clone the newer Remora developments since that image was released so I was running the older halcompiled remora-spi which I'm sure now was causing me issues. Now that I have pulled the most recent Remora version and compiled remora-spi again with halcompile like the docuementation says to do, although I noticed that in an earlier post it was mentioned that you no longer need the SPI_clk_div=32 after the loadrt remora-spi component in the HAL file but, mine wouldn't come out of estop until I added that back into the line. I also had a grounding issue and some EMI issues that collectively were causing my spindle to throw errors and after that and the correct version of firmware on the Octopus and most recent Remora branch then it looks like I'm good now.
- amanker
08 Sep 2025 19:21 #334648
by amanker
I have tested my rpi5 installation with octopus pro. Black pill and ec500 controller all are working. But now I am stuck on skr3.
@scotta @cakeslob please help.
- amanker
09 Sep 2025 18:04 #334722
by amanker
Waiting for some reply from devs @scotta @cakeslob
- scotta
- Thank you received: 489
09 Sep 2025 20:40 #334730
by scotta
Replied by scotta on topic Remora - Rpi Software Stepping Using External Microcontroller via SPI
Hi, please share your config files. If signals can be seen in Hal Meter there must be another config issue.
- amanker
10 Sep 2025 04:21 #334742
by amanker
I was using Octopus Pro Board for LinuxCNC. That one is giving some problems. So I bought new board BTT SKR3 so that I can use TMC5160. Can anyone help me setting up its config.txt and LinuxCNC configuration. And connection diagram. I have wired it as per SKR2 board. Pinouts of both boards seems similar. I cant get Machine out of estop. I think there is no communication between rpi and skr3.
Remora.ini[/code][/code]# Basic LinuxCNC config for testing of Remora firmware [EMC] MACHINE = Remora-XYZ DEBUG = 0 VERSION = 1.1 [DISPLAY] DISPLAY = axis EDITOR = gedit POSITION_OFFSET = RELATIVE POSITION_FEEDBACK = ACTUAL ARCDIVISION = 64 GRIDS = 10mm 20mm 50mm 100mm MAX_FEED_OVERRIDE = 1.2 MIN_SPINDLE_OVERRIDE = 0.5 MAX_SPINDLE_OVERRIDE = 1.2 DEFAULT_LINEAR_VELOCITY = 50.00 MIN_LINEAR_VELOCITY = 0 MAX_LINEAR_VELOCITY = 200.00 DEFAULT_ANGULAR_VELOCITY = 36.00 MIN_ANGULAR_VELOCITY = 0 MAX_ANGULAR_VELOCITY = 45.00 INTRO_GRAPHIC = linuxcnc.gif INTRO_TIME = 5 PROGRAM_PREFIX = ~/linuxcnc/nc_files INCREMENTS = 50mm 10mm 5mm 1mm .5mm .1mm .05mm .01mm [KINS] JOINTS = 3 #KINEMATICS =trivkins coordinates=XYZ kinstype=BOTH KINEMATICS =trivkins coordinates=XYZ [FILTER] PROGRAM_EXTENSION = .py Python Script py = python [TASK] TASK = milltask CYCLE_TIME = 0.010 [RS274NGC] PARAMETER_FILE = linuxcnc.var [EMCMOT] EMCMOT = motmod COMM_TIMEOUT = 1.0 COMM_WAIT = 0.010 BASE_PERIOD = 0 SERVO_PERIOD = 1000000 [HAL] HALFILE = remora.hal POSTGUI_HALFILE = postgui_call_list.hal [TRAJ] COORDINATES = X Y Z LINEAR_UNITS = mm ANGULAR_UNITS = degree CYCLE_TIME = 0.010 DEFAULT_LINEAR_VELOCITY = 50.00 MAX_LINEAR_VELOCITY = 200.00 NO_FORCE_HOMING = 1 [EMCIO] EMCIO = io CYCLE_TIME = 0.100 TOOL_TABLE = tool.tbl [AXIS_X] MAX_VELOCITY = 500 MAX_ACCELERATION = 1000.0 MIN_LIMIT = -500 MAX_LIMIT = 500.0 [JOINT_0] TYPE = LINEAR HOME = 0.0 MIN_LIMIT = -500.0 MAX_LIMIT = 500.0 MAX_VELOCITY = 500.0 MAX_ACCELERATION = 1000.0 STEPGEN_MAXACCEL = 2000.0 SCALE = 200.0 FERROR = 2 MIN_FERROR = 2.0 HOME_OFFSET = 0.0 HOME_SEARCH_VEL = 0 HOME_LATCH_VEL = 0 HOME_SEQUENCE = 0 [AXIS_Y] MAX_VELOCITY = 250.0 MAX_ACCELERATION = 750.0 MIN_LIMIT = -300.0 MAX_LIMIT = 300.0 [JOINT_1] TYPE = LINEAR HOME = 0.0 MIN_LIMIT = -300.0 MAX_LIMIT = 300.0 MAX_VELOCITY = 250.0 MAX_ACCELERATION = 750.0 STEPGEN_MAXACCEL = 2000.0 SCALE = 80.0 FERROR = 9.0 MIN_FERROR = 5.0 HOME_OFFSET = 0.0 HOME_SEARCH_VEL = 0 HOME_LATCH_VEL = 0 HOME_SEQUENCE = 0 [AXIS_Z] OFFSET_AV_RATIO = 0.2 MAX_VELOCITY = 5.0 MAX_ACCELERATION = 200.0 MIN_LIMIT = -280 MAX_LIMIT = 280 [JOINT_2] TYPE = LINEAR HOME = 0.0 MIN_LIMIT = -280 MAX_LIMIT = 280 MAX_VELOCITY = 5.0 MAX_ACCELERATION = 200.0 STEPGEN_MAXACCEL = 3000.0 SCALE = 400.0 FERROR = 5 MIN_FERROR = 1.0 HOME_OFFSET = 0.0 HOME_SEARCH_VEL = 0 HOME_LATCH_VEL = 0 HOME_SEQUENCE = 0 remora.hal [code]# load the realtime components loadrt [KINS]KINEMATICS loadrt [EMCMOT]EMCMOT base_period_nsec=[EMCMOT]BASE_PERIOD servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[KINS]JOINTS loadrt remora-spi #loadrt remora_lpc chip_type=LPC SPI_clk_div=64 # estop loopback, SPI comms enable and feedback net user-enable-out <= iocontrol.0.user-enable-out => remora.SPI-enable net user-request-enable <= iocontrol.0.user-request-enable => remora.SPI-reset net remora-status <= remora.SPI-status => iocontrol.0.emc-enable-in # add the remora and motion functions to threads addf remora.read servo-thread addf motion-command-handler servo-thread addf motion-controller servo-thread addf remora.update-freq servo-thread addf remora.write servo-thread # Joint 0 setup setp remora.joint.0.scale [JOINT_0]SCALE setp remora.joint.0.maxaccel [JOINT_0]STEPGEN_MAXACCEL net xpos-cmd <= joint.0.motor-pos-cmd => remora.SP.0 joint.0.motor-pos-fb # net j0pos-fb <= remora.joint.0.pos-fb => joint.0.motor-pos-fb # net j0enable <= joint.0.amp-enable-out => remora.joint.0.enable # Joint 1 setup setp remora.joint.1.scale [JOINT_1]SCALE setp remora.joint.1.maxaccel [JOINT_1]STEPGEN_MAXACCEL net j1pos-cmd <= joint.1.motor-pos-cmd => remora.joint.1.pos-cmd net j1pos-fb <= remora.joint.1.pos-fb => joint.1.motor-pos-fb net j1enable <= joint.1.amp-enable-out => remora.joint.1.enable # Joint 2 setup setp remora.joint.2.scale [JOINT_2]SCALE setp remora.joint.2.maxaccel [JOINT_2]STEPGEN_MAXACCEL net j2pos-cmd <= joint.2.motor-pos-cmd => remora.joint.2.pos-cmd net j2pos-fb <= remora.joint.2.pos-fb => joint.2.motor-pos-fb net j2enable <= joint.2.amp-enable-out => remora.joint.2.enable config.txt [code]{ "Board": "BIGTREETECH SKR v3", "Modules":[ { "Thread": "Servo", "Type": "Reset Pin", "Comment": "Reset pin", "Pin": "PC_4" }, { "Thread": "On load", "Type": "Motor Power", "Comment": "Enable motor power SKR2", "Pin": "PC_13" }, { "Thread": "Base", "Type": "Stepgen", "Comment": "X - Joint 0 step generator", "Joint Number": 0, "Step Pin": "PD_4", "Direction Pin": "PD_3", "Enable Pin": "PD_6" }, { "Thread": "Base", "Type": "Stepgen", "Comment": "Y - Joint 1 step generator", "Joint Number": 1, "Step Pin": "PA_15", "Direction Pin": "PA_8", "Enable Pin": "PD_1" }, { "Thread": "Base", "Type": "Stepgen", "Comment": "Z - Joint 2 step generator", "Joint Number": 2, "Step Pin": "PE_2", "Direction Pin": "PE_3", "Enable Pin": "PE_0" }, { "Thread": "Servo", "Type": "Digital Pin", "Comment": "X min", "Pin": "PC_1", "Mode": "Input", "Data Bit": 0 }, { "Thread": "Servo", "Type": "Digital Pin", "Comment": "X max", "Pin": "PC_2", "Mode": "Input", "Data Bit": 1 }, { "Thread": "Servo", "Type": "Digital Pin", "Comment": "Y min", "Pin": "PC_3", "Mode": "Input", "Data Bit": 2 }, { "Thread": "Servo", "Type": "Digital Pin", "Comment": "Y max", "Pin": "PA_0", "Mode": "Input", "Data Bit": 3 }, { "Thread": "Servo", "Type": "Digital Pin", "Comment": "Z min", "Pin": "PC_0", "Mode": "Input", "Data Bit": 4 }, { "Thread": "Servo", "Type": "Digital Pin", "Comment": "Z max", "Pin": "PC_15", "Mode": "Input", "Data Bit": 5 } ] }
- amanker
10 Sep 2025 17:48 #334783
by amanker
@scotta it would be really helpful if you can post sample config files. Or if I need to completely erase skr3 and reflash using stm32cube programmer?
Time to create page: 1.264 seconds
