- Hardware & Machines
- Computers and Hardware
- Remora - Rpi Software Stepping Using External Microcontroller via SPI
- amanker
19 Jan 2026 04:19 #341564
by amanker
Replied by amanker on topic Remora - Rpi Software Stepping Using External Microcontroller via SPI
Sorry, I was confused in spi. I assumed that both board use same single spi without seeing it's board pin maps. But after seeing SKR3 pin map I found that it's using separate spi for config and comms. But in Octopus it's same for config and comms. Thanks for pointing out.
- amanker
20 Jan 2026 19:13 #341622
by amanker
Thanks for your tips.
@3040gerber and @cakeslob
Finally I got TMC5160 working on Octopus pro board f446 version.
I have changed the spi to spi2 with new interrupt and uart to uart3. I choosen spi2 because it's on wifi connector on board which is at the edge of board, so there will be much shorter length spi cable required and it has uart3 at same place.
Thanks a lot
Thanks a lot
- amanker
07 Feb 2026 11:00 #342594
by amanker
I was testing new remora-eth from ben-jacobson repository. With the suggestions from you was able to make it work on SPI3, with TMC5160 drivers on remora-spi.
But now I am testing remora-eth from same repo. Can you help me in this?. I have edited ldscript for octopus pro with ethernet. But I can't ping w5500.
- 3404gerber
- Thank you received: 14
08 Feb 2026 09:13 #342637
by 3404gerber
Replied by 3404gerber on topic Remora - Rpi Software Stepping Using External Microcontroller via SPI
I'm happy to help if I can. I'm ot familiar with the STM32 controllers and I don't really understand the ldscript files, but from what I understand you'll need a ldscript and some adjustment in the platformio.ini file. Can you share your platformio.ini file?
- amanker
08 Feb 2026 18:28 #342661
by amanker
Thanks a lot.
I am attaching my ldscript which I made based on existing ldscripts included in repository. And attaching my platformio.ini.
- 3404gerber
09 Feb 2026 05:16 #342694
by 3404gerber
So you are using the spi1 pins for the w5500? I think this will be a problem if your config uses tmc5160, as the module uses software spi and configure the pins as standard gpio.
- amanker
09 Feb 2026 06:07 - 09 Feb 2026 06:10 #342696
by amanker
Sorry, I was on mobile, not on PC so I wrongly uploaded platformio.ini.
I am using SPI2 pins as per your previous suggestions and it was working ok in remora-spi with TMC.
So I am using same for ETH version.
I am uploading actual platformio.ini
Please look at ldscript, which is I have made with reference to already available ldscripts.
Last edit: 09 Feb 2026 06:10 by amanker.
- 3404gerber
09 Feb 2026 18:22 #342723
by 3404gerber
I had a quick look to the platformio.ini and it seems consistent. For the ldscript I'm afraid I'm not the right person to look at it, as I have absolutely no experience with this. Did you already try to reduce SPI speed, as you had issues with SPI communication? I think this line set it to 45MHz in EthComms.cpp:
spiHandle.Init.BaudRatePrescaler = SPI_BAUDRATEPRESCALER_2;
- amanker
09 Feb 2026 18:36 - 09 Feb 2026 18:40 #342725
by amanker
I just made logical changes in ldscript, by looking at 3 scripts in repository. I think you are good in programming so you can make out something by looking at those scripts.
FYI... I am using ben-jacobson repository for remora_stm32f4xx_pio. He has working on nucleo_f446 board.
No spi issue was resolved. Since I was using RPI4, I have to include spi_clk_div=32 as argument to make spi working.
Other issue with tmc was resolved by changing spi to spi2 and assigning new interrupt.
Last edit: 09 Feb 2026 18:40 by amanker.
- 3404gerber
09 Feb 2026 19:13 #342727
by 3404gerber
I understand that you resolved the SPI issue when the RPi was the SPI master and was talking to the Octopus, but for the Ethernet config the Octopus board is the SPI master talking to the W5500 chip. So I would first try to reduce the SPI speed by changing the line I mentioned before.
Time to create page: 0.189 seconds
