- Hardware & Machines
- Computers and Hardware
- Remora - Rpi Software Stepping Using External Microcontroller via SPI
- scotta
- Thank you received: 489
05 Sep 2025 21:26 #334519
by scotta
Replied by scotta on topic Remora - Rpi Software Stepping Using External Microcontroller via SPI
Good to hear. I'd suggest slowing down the SPI comms like in the discussion above.
hal
loadrt remora-spi SPI_num=0 CS_num=0 SPI_freq=2000000
ini
#SERVO_PERIOD = 1000000
SERVO_PERIOD = 5000000
hal
ini
The following user(s) said Thank You: Gusgus
- Gusgus
06 Sep 2025 01:23 #334523
by Gusgus
Replied by Gusgus on topic Remora - Rpi Software Stepping Using External Microcontroller via SPI
Hello again Scotta!
We've continued testing on the octopus board, we have gotten movement but it seems that the SPI communication with the board seems to keep dying. We got the serial output:
Creating a std module
Remora PRU - Programmable Realtime Unit
Mbed-OS6
Remora-spi Driver
## Entering SETUP state
1. Reading json configuration file
Mounting the filesystem... OK
Opening "/fs/config.txt"... OK
Json config file lenght = 1996
Closing "/fs/config.txt"...
2. Setting up DMA and threads
Initialising SPI1 slave
Initialising DMA for SPI
3. Parsing json configuration file
Config deserialisation - Deserialization succeeded
4. Config threads
Creating thread 40000
Creating thread 1000
Creating thread 57600
5. Loading modules
Servo thread object
Reset pin
Make Reset Pin at pin PC_15
Creating Pin @
port = GPIOC
pin = 15
Servo thread object
eStop
Make eStop at pin PG_12
Creating Pin @
port = GPIOG
pin = 12
Servo thread object
Spindle
Make PWM at pin PB_0
Creating variable frequency Hardware PWM at pin PB_0
Creating Pin @
port = GPIOB
pin = 0
Base thread object
X - Joint 0 step generator
Creating Pin @
port = GPIOG
pin = 2
Creating Pin @
port = GPIOF
pin = 9
Creating Pin @
port = GPIOF
pin = 10
Base thread object
Y1 - Joint 1 step generator
Creating Pin @
port = GPIOF
pin = 1
Creating Pin @
port = GPIOC
pin = 13
Creating Pin @
port = GPIOF
pin = 0
Base thread object
Y2 - Joint 1 step generator
Creating Pin @
port = GPIOD
pin = 4
Creating Pin @
port = GPIOE
pin = 2
Creating Pin @
port = GPIOE
pin = 3
Base thread object
Z - Joint 2 step generator
Creating Pin @
port = GPIOE
pin = 0
Creating Pin @
port = GPIOE
pin = 6
Creating Pin @
port = GPIOA
pin = 14
Servo thread object
X min
Make Digital Input at pin PG_6
Setting pin as No Pull
Creating Pin @
port = GPIOG
pin = 6
Servo thread object
Y min
Make Digital Input at pin PG_9
Creating Pin @
port = GPIOG
pin = 9
Servo thread object
Z min
Make Digital Input at pin PG_10
Creating Pin @
port = GPIOG
pin = 10
Servo thread object
Probe
Make Digital Input at pin PG_11
Creating Pin @
port = GPIOG
pin = 11
## Entering START state
Starting the BASE thread
Registering interrupt for interrupt number = 24
power on Timer 9
Starting the SERVO thread
Registering interrupt for interrupt number = 25
power on Timer 10
## Entering IDLE state
## Entering RUNNING state
## Entering RESET state
Resetting rxBuffer
This last bit is where we are running into a wall, we are not sure what is causing this.
Mbed-OS6
Remora-spi Driver
4. Config threads
5. Loading modules
Servo thread object
Reset pin
Creating Pin @
port = GPIOC
pin = 15
Servo thread object
eStop
Creating Pin @
port = GPIOG
pin = 12
Servo thread object
Spindle
Creating Pin @
port = GPIOB
pin = 0
Base thread object
Creating Pin @
port = GPIOG
pin = 2
Creating Pin @
port = GPIOF
pin = 9
Creating Pin @
port = GPIOF
pin = 10
Base thread object
Creating Pin @
port = GPIOF
pin = 1
Creating Pin @
port = GPIOC
pin = 13
Creating Pin @
port = GPIOF
pin = 0
Base thread object
Creating Pin @
port = GPIOD
pin = 4
Creating Pin @
port = GPIOE
pin = 2
Creating Pin @
port = GPIOE
pin = 3
Base thread object
Creating Pin @
port = GPIOE
pin = 0
Creating Pin @
port = GPIOE
pin = 6
Creating Pin @
port = GPIOA
pin = 14
Servo thread object
X min
Creating Pin @
port = GPIOG
pin = 6
Servo thread object
Y min
Creating Pin @
port = GPIOG
pin = 9
Servo thread object
Z min
Creating Pin @
port = GPIOG
pin = 10
Servo thread object
Probe
Creating Pin @
port = GPIOG
pin = 11
power on Timer 9
power on Timer 10
Resetting rxBuffer
- Gusgus
06 Sep 2025 01:25 #334524
by Gusgus
we turn on the machine, and all normal
we open linux cnc and enable the machine
x ammount of time passes and this happens
Resetting rxBuffer
disable and we then get this printout
after that we can enable the machine but the time it takes for it to enter the reset state is much much shorter, like milliseconds
Resetting rxBuffer
- Thank you received: 7465
06 Sep 2025 01:33 #334525
Replied by tommylight on topic Remora - Rpi Software Stepping Using External Microcontroller via SPI
Most probably interference on the SPI wiring, so the first thing would be to make those wires very short, like 10cm short, or use shielded cable.
I would also not bother with the power supply as Octopus has pretty good regulators.
If the machine has a spindle, notice if the error occurs when the spindle is turned on.
- Gusgus
06 Sep 2025 01:37 #334526
by Gusgus
Hi tommylight!
We have tested the spinndle idea but the error happens regardless of if its on or off. We use and unshielded cable, let me test that out.
- amanker
06 Sep 2025 04:17 - 06 Sep 2025 04:18 #334528
by amanker
Replied by amanker on topic Remora - Rpi Software Stepping Using External Microcontroller via SPI
If someone can give me example config.txt and config files hal and ini for skr3 board, it would be really helpful. Or look at my config files for skr3.
Last edit: 06 Sep 2025 04:18 by amanker.
- amanker
06 Sep 2025 05:49 #334531
by amanker
When machine comes out of estop it gives error "Remora FATAL ERROR [JASON Config]: Config file open failed (status=0xA2)".
- amanker
06 Sep 2025 06:45 #334533
by amanker
The above error is sorted out. But still joint following error
- oodanner
07 Sep 2025 18:01 - 07 Sep 2025 19:05 #334583
by oodanner
Replied by oodanner on topic Remora - Rpi Software Stepping Using External Microcontroller via SPI
I posted something I thought might be helpful since it seemed to fix my problem but, then it started happening again. My SPI interface keeps getting reset as well and only when my spindle gets turned on. I already created a shielded cable between the SPI connections. I thought messing with the base servo speed helped in the ini file at one point but, I just tried again and got the same microcontroller reset. After that I have to reset the microcontroller before I get a good status signal for the SPI connection and I can toggle machine power once again and communications work as well. I guess it could be interference on the SPI interface still but, I'm not sure how that is happening. EDIT: I guess after creating a shielded SPI cable it did work for longer before getting an SPI reset. I still had issues and I just put a piece of tin foil over no directly onto the raspberry pi4 GPIO pins and it looks like all of my errors are gone so maybe some EMI was getting into the raspberry pi pins and resetting the controller somehow? I'm still testing to see if my problem is gone for good but, fingers crossed.
Last edit: 07 Sep 2025 19:05 by oodanner.
- oodanner
07 Sep 2025 18:07 #334584
by oodanner
I had a joint following error as well but, it was because my default jog speed was set too high for my set up. Not sure if this is happening to you but, thought I would mention it.
Time to create page: 0.526 seconds
