27 Apr 2025 19:55 #327181 by cakeslob
Thanks for all the hard work Scott. The PIO install went really smooth, all I needed to do was update my ststm32 lib and it compiled no problem. Next steps for me is doing a H723 port, and figure out how this new repo works. Regarding hardware abstraction, (as always) I have notes on that based on the PIO stuff I did with Drew on the W5500 ethernet branch.
Hmmm call it something like Remora Motion Controller or something? ReMot? ReMOC? RemoraCNC?
28 Apr 2025 05:21 #327203 by scotta
Thanks Cakeslob, which board is the H723 being used? This will be a good test to see if we can get PlatformIO working happy with multiple targets. The code will need #ifdef's and compiler defines for each board to select the code changes needed for each H7 variant.
29 Apr 2025 18:49 #327309 by cakeslob
Ill be honest here Scott, they all do, and they dont use the H437 anymore. I didnt wanna discourage you, but it should be straight forward after the h723.
github.com/cakeslob/Remora-STM32H7xx-PIO/tree/h723
here is my WIP abstraction for multi targets from last night. Still havent copied over the SPI channel stuff just working on the clocks right now. Need to figure out abstraction for UART and CS pin also
Check the pile of shit I sent, I think theres another H7 something there you can test. Theres basically only 4 main profiles and everything else is just pin changes
H743 - 25mhz clock
H743 - 8mhz clock
H723 - 25mhz
H73 - 8mhz clock
29 Apr 2025 21:12 #327315 by scotta
Nice work! Using PIO board variants might be the way to go. That's how Marlin has managed it and it's so much like how Mbed uses custom targets. They use some custom python scripts to make the magic work.
29 Apr 2025 21:58 #327318 by cakeslob
i dont know much about marlin or how to use the pythonscripts, but with the W5500 branch from Drew, we have been copying grblhal, which has proven to be a good model. You can select build environment in the PIO extension and it will syntax highlight based on the build environment, or just build all of them. For the F4 branch, we didnt even need to make PIO board variants because most generic ones were included. Since there arent even that many options(clock, spi channel, etc), Drew threw them all out there for me at the beginning and I just had to add some defs and configure some stuff. Have a look at our other repo, I have been mashing this + grblhal into your new thing, and to try and work.
github.com/cakeslob/Remora-STM32F4xx-W55.../f429/platformio.ini
So far on the W5500 one, he had a bunch of SPI DMA options already included ( SPI1, SPI1-ALT, SPI2, etc), the common clock configs and I just mashed some defs and boards. I dont have it very clean but I was able to support all the other remora boards pretty easy.
09 May 2025 18:44 #328095 by amanker
Eagerly waiting for tmc5160 support on stm32f4 board
10 May 2025 03:21 #328120 by cakeslob
hey scott, ive been playing with it for the last 2 weeks. I dont have much to show, but i think the environment switching is working kinda. im testing with a nucleoh743, from the debug it seems to be working but serial is messed, it seems i dont know how to do a define or something,
github.com/cakeslob/Remora-STM32H7xx-PIO...43/Src/main.cpp#L116
17 May 2025 04:39 - 17 May 2025 05:34 #328609 by cakeslob
hey Scott, my homies and i have the environment switching working, but we did a messy job to support a different board we were testing
Last edit: 17 May 2025 05:34 by cakeslob.
19 May 2025 20:53 #328760 by scotta
Thanks cakeslob! Analog inputs are ready for testing this coming weekend. Then I'll merge over your work.
20 May 2025 02:45 #328775 by cakeslob
Dont merge anything just yet. me and my friend have spent the last 3 days trying to figure out the shit outta this problem. we have environment configured, we can switch uart, but we are very stuck and out of ideas. We are trying to switch SPI channels from 1 to 2 and/or 4, but we just dont know what variable we are missing/not configured. It works mostly but the MOSI doesnt seem to work but the MISO does. SPI1 works fine, but we cant figure out how to switch to 2
github.com/cakeslob/Remora-STM32H7xx-PIO/tree/spi4
Time to create page: 2.990 seconds
