21 Feb 2026 21:48 - 21 Feb 2026 22:04 #343283 by cakeslob
those wires look too long and too loose. you will need to shorten them for sure and tighten them up a big
shorter is better, keep it as short as possible
edit do you mean 8inches and not 8cm? 8cm is the length of the rpi board
Last edit: 21 Feb 2026 22:04 by cakeslob.
23 Feb 2026 18:34 - 23 Feb 2026 19:06 #343354 by AlessandroEmm
They were actually 10cm, now they are closer to 4. :-) Unfortunately wasnt the (root) cause of my issues.
Last edit: 23 Feb 2026 19:06 by AlessandroEmm.
25 Feb 2026 05:48 #343444 by AlessandroEmm
Fyi to clear this up I was able to fix it. It likely wasn't a remora-based issue
please refer to.
forum.linuxcnc.org/49-basic-configuratio...without-error#343443
That said I'm still on a 2024 commit with my current setup, as it seemed more resilient in regards to SPI Comms on F103, but i'm pretty sure upstream would work too.
Time to create page: 0.973 seconds
