18 Sep 2025 18:42 #335160 by amanker
Finally I got it working. I shortened the spi cables, reduced spi frequency, tried erasing and flashing remora via stm32cube, nothing worked. But after some time it automagically started working. I don't know how it worked?
18 Sep 2025 19:04 #335163 by Gusgus
Hello once again!
I haven't really been active but we got to testing once again and now I have encountered another issue I don't understand.
So now we get movement and stable connection to the octopus, we got an spi cable with shielding and that worked wonders, thank you tommylight for the suggestion and thanks Scotta for all the help.
The issue we are encountering now is that we have x y1 y2 and z, but we only get movement from x and y1, y2 and z are completely unresponsive, we have eliminated the drivers and their wiring since if we connect the y2 and z terminals to the x and y1 outputs on the octopus we get movement from them.
We have them wired to the octopus' Motor 4, 5, 6, and 7 ports, which are decleared in the following config:
[color=#d4d4d4]{[/color][color=#9cdcfe]"Board"[/color][color=#d4d4d4]: [/color][color=#ce9178]"BIGTREETECH Octopus Pro"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Modules"[/color][color=#d4d4d4]:[[/color][color=#d4d4d4]{[/color][color=#9cdcfe]"Thread"[/color][color=#d4d4d4]: [/color][color=#ce9178]"Servo"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Type"[/color][color=#d4d4d4]: [/color][color=#ce9178]"Reset Pin"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Comment"[/color][color=#d4d4d4]: [/color][color=#ce9178]"Reset pin"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Pin"[/color][color=#d4d4d4]: [/color][color=#ce9178]"PC_15"[/color][color=#d4d4d4]},[/color][color=#d4d4d4]{[/color][color=#9cdcfe]"Thread"[/color][color=#d4d4d4]: [/color][color=#ce9178]"Servo"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Type"[/color][color=#d4d4d4]: [/color][color=#ce9178]"eStop"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Comment"[/color][color=#d4d4d4]: [/color][color=#ce9178]"eStop"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Pin"[/color][color=#d4d4d4]: [/color][color=#ce9178]"PG_12"[/color][color=#d4d4d4]},[/color][color=#d4d4d4]{[/color][color=#9cdcfe]"Thread"[/color][color=#d4d4d4]: [/color][color=#ce9178]"Servo"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Type"[/color][color=#d4d4d4]: [/color][color=#ce9178]"PWM"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Comment"[/color][color=#d4d4d4]: [/color][color=#ce9178]"Spindle"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"SP[i]"[/color][color=#d4d4d4]: [/color][color=#b5cea8]3[/color][color=#d4d4d4],[/color][color=#9cdcfe]"PWM Pin"[/color][color=#d4d4d4]: [/color][color=#ce9178]"PB_0"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"PWM Max"[/color][color=#d4d4d4]: [/color][color=#b5cea8]255[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Hardware PWM"[/color][color=#d4d4d4]: [/color][color=#ce9178]"True"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Variable Freq"[/color][color=#d4d4d4]: [/color][color=#ce9178]"True"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Period SP[i]"[/color][color=#d4d4d4]: [/color][color=#b5cea8]1[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Period us"[/color][color=#d4d4d4]: [/color][color=#b5cea8]200[/color][color=#d4d4d4]},[/color][color=#d4d4d4]{[/color][color=#9cdcfe]"Thread"[/color][color=#d4d4d4]: [/color][color=#ce9178]"Base"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Type"[/color][color=#d4d4d4]: [/color][color=#ce9178]"Stepgen"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Comment"[/color][color=#d4d4d4]: [/color][color=#ce9178]"X - Joint 0 step generator"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Joint Number"[/color][color=#d4d4d4]: [/color][color=#b5cea8]0[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Step Pin"[/color][color=#d4d4d4]: [/color][color=#ce9178]"PF_9"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Direction Pin"[/color][color=#d4d4d4]: [/color][color=#ce9178]"PF_10"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Enable Pin"[/color][color=#d4d4d4]: [/color][color=#ce9178]"PG_2"[/color][color=#d4d4d4]},[/color][color=#d4d4d4]{[/color][color=#9cdcfe]"Thread"[/color][color=#d4d4d4]: [/color][color=#ce9178]"Base"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Type"[/color][color=#d4d4d4]: [/color][color=#ce9178]"Stepgen"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Comment"[/color][color=#d4d4d4]: [/color][color=#ce9178]"Y1 - Joint 1 step generator"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Joint Number"[/color][color=#d4d4d4]: [/color][color=#b5cea8]1[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Step Pin"[/color][color=#d4d4d4]: [/color][color=#ce9178]"PC_13"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Direction Pin"[/color][color=#d4d4d4]: [/color][color=#ce9178]"PF_0"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Enable Pin"[/color][color=#d4d4d4]: [/color][color=#ce9178]"PF_1"[/color][color=#d4d4d4]},[/color][color=#d4d4d4]{[/color][color=#9cdcfe]"Thread"[/color][color=#d4d4d4]: [/color][color=#ce9178]"Base"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Type"[/color][color=#d4d4d4]: [/color][color=#ce9178]"Stepgen"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Comment"[/color][color=#d4d4d4]: [/color][color=#ce9178]"Y2 - Joint 1 step generator"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Joint Number"[/color][color=#d4d4d4]: [/color][color=#b5cea8]1[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Step Pin"[/color][color=#d4d4d4]: [/color][color=#ce9178]"PE_2"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Direction Pin"[/color][color=#d4d4d4]: [/color][color=#ce9178]"PE_3"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Enable Pin"[/color][color=#d4d4d4]: [/color][color=#ce9178]"PD_4"[/color][color=#d4d4d4]},[/color][color=#d4d4d4]{[/color][color=#9cdcfe]"Thread"[/color][color=#d4d4d4]: [/color][color=#ce9178]"Base"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Type"[/color][color=#d4d4d4]: [/color][color=#ce9178]"Stepgen"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Comment"[/color][color=#d4d4d4]: [/color][color=#ce9178]"Z - Joint 2 step generator"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Joint Number"[/color][color=#d4d4d4]: [/color][color=#b5cea8]2[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Step Pin"[/color][color=#d4d4d4]: [/color][color=#ce9178]"PE_6"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Direction Pin"[/color][color=#d4d4d4]: [/color][color=#ce9178]"PA_14"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Enable Pin"[/color][color=#d4d4d4]: [/color][color=#ce9178]"PE_0"[/color][color=#d4d4d4]},[/color][color=#d4d4d4]{[/color][color=#9cdcfe]"Thread"[/color][color=#d4d4d4]: [/color][color=#ce9178]"Servo"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Type"[/color][color=#d4d4d4]: [/color][color=#ce9178]"Digital Pin"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Comment"[/color][color=#d4d4d4]: [/color][color=#ce9178]"X min"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Pin"[/color][color=#d4d4d4]: [/color][color=#ce9178]"PG_6"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Mode"[/color][color=#d4d4d4]: [/color][color=#ce9178]"Input"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Data Bit"[/color][color=#d4d4d4]: [/color][color=#b5cea8]0[/color][color=#d4d4d4]},[/color][color=#d4d4d4]{[/color][color=#9cdcfe]"Thread"[/color][color=#d4d4d4]: [/color][color=#ce9178]"Servo"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Type"[/color][color=#d4d4d4]: [/color][color=#ce9178]"Digital Pin"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Comment"[/color][color=#d4d4d4]: [/color][color=#ce9178]"Y min"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Pin"[/color][color=#d4d4d4]: [/color][color=#ce9178]"PG_9"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Mode"[/color][color=#d4d4d4]: [/color][color=#ce9178]"Input"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Data Bit"[/color][color=#d4d4d4]: [/color][color=#b5cea8]1[/color][color=#d4d4d4]},[/color][color=#d4d4d4]{[/color][color=#9cdcfe]"Thread"[/color][color=#d4d4d4]: [/color][color=#ce9178]"Servo"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Type"[/color][color=#d4d4d4]: [/color][color=#ce9178]"Digital Pin"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Comment"[/color][color=#d4d4d4]: [/color][color=#ce9178]"Z min"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Pin"[/color][color=#d4d4d4]: [/color][color=#ce9178]"PG_10"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Mode"[/color][color=#d4d4d4]: [/color][color=#ce9178]"Input"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Data Bit"[/color][color=#d4d4d4]: [/color][color=#b5cea8]2[/color][color=#d4d4d4]},[/color][color=#d4d4d4]{[/color][color=#9cdcfe]"Thread"[/color][color=#d4d4d4]: [/color][color=#ce9178]"Servo"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Type"[/color][color=#d4d4d4]: [/color][color=#ce9178]"Digital Pin"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Comment"[/color][color=#d4d4d4]: [/color][color=#ce9178]"Probe"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Pin"[/color][color=#d4d4d4]: [/color][color=#ce9178]"PG_11"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Mode"[/color][color=#d4d4d4]: [/color][color=#ce9178]"Input"[/color][color=#d4d4d4],[/color][color=#9cdcfe]"Data Bit"[/color][color=#d4d4d4]: [/color][color=#b5cea8]3[/color][color=#d4d4d4]}[/color][color=#d4d4d4]][/color][color=#d4d4d4]}[/color]
We are running this in our .ini file:
[color=#6a9955]# Basic LinuxCNC config for testing of Remora firmware[/color] [color=#d4d4d4][EMC][/color][color=#569cd6]MACHINE[/color][color=#d4d4d4] = Remora-XYZ[/color][color=#569cd6]DEBUG[/color][color=#d4d4d4] = 0[/color][color=#569cd6]VERSION[/color][color=#d4d4d4] = 1.1[/color] [color=#d4d4d4][DISPLAY][/color][color=#569cd6]DISPLAY[/color][color=#d4d4d4] = axis[/color][color=#569cd6]EDITOR[/color][color=#d4d4d4] = gedit[/color][color=#569cd6]POSITION_OFFSET[/color][color=#d4d4d4] = RELATIVE[/color][color=#569cd6]POSITION_FEEDBACK[/color][color=#d4d4d4] = ACTUAL[/color][color=#569cd6]ARCDIVISION[/color][color=#d4d4d4] = 64[/color][color=#569cd6]GRIDS[/color][color=#d4d4d4] = 10mm 20mm 50mm 100mm[/color][color=#569cd6]MAX_FEED_OVERRIDE[/color][color=#d4d4d4] = 1.2[/color][color=#569cd6]MIN_SPINDLE_OVERRIDE[/color][color=#d4d4d4] = 0.5[/color][color=#569cd6]MAX_SPINDLE_OVERRIDE[/color][color=#d4d4d4] = 1.2[/color][color=#569cd6]DEFAULT_LINEAR_VELOCITY[/color][color=#d4d4d4] = 28.7[/color][color=#569cd6]MIN_LINEAR_VELOCITY[/color][color=#d4d4d4] = 0[/color][color=#569cd6]MAX_LINEAR_VELOCITY[/color][color=#d4d4d4] = 28.7[/color][color=#569cd6]DEFAULT_ANGULAR_VELOCITY[/color][color=#d4d4d4] = 28.7[/color][color=#569cd6]MIN_ANGULAR_VELOCITY[/color][color=#d4d4d4] = 0[/color][color=#569cd6]MAX_ANGULAR_VELOCITY[/color][color=#d4d4d4] = 28.7[/color][color=#569cd6]INTRO_GRAPHIC[/color][color=#d4d4d4] = linuxcnc.gif[/color][color=#569cd6]INTRO_TIME[/color][color=#d4d4d4] = 5[/color][color=#569cd6]PROGRAM_PREFIX[/color][color=#d4d4d4] = ~/linuxcnc/nc_files[/color][color=#569cd6]INCREMENTS[/color][color=#d4d4d4] = 50mm 10mm 5mm 1mm .5mm .1mm .05mm .01mm[/color] [color=#d4d4d4][KINS][/color][color=#569cd6]JOINTS[/color][color=#d4d4d4] = 3[/color][color=#6a9955]#KINEMATICS =trivkins coordinates=XYZ kinstype=BOTH[/color][color=#569cd6]KINEMATICS[/color][color=#d4d4d4] =trivkins [/color][color=#569cd6]coordinates[/color][color=#d4d4d4]=XYZ[/color] [color=#d4d4d4][FILTER][/color][color=#569cd6]PROGRAM_EXTENSION[/color][color=#d4d4d4] = .py Python Script[/color][color=#569cd6]py[/color][color=#d4d4d4] = python[/color] [color=#d4d4d4][TASK][/color][color=#569cd6]TASK[/color][color=#d4d4d4] = milltask[/color][color=#569cd6]CYCLE_TIME[/color][color=#d4d4d4] = 0.010[/color] [color=#d4d4d4][RS274NGC][/color][color=#569cd6]PARAMETER_FILE[/color][color=#d4d4d4] = linuxcnc.var[/color] [color=#d4d4d4][EMCMOT][/color][color=#569cd6]EMCMOT[/color][color=#d4d4d4] = motmod[/color][color=#569cd6]COMM_TIMEOUT[/color][color=#d4d4d4] = 1.0[/color][color=#569cd6]COMM_WAIT[/color][color=#d4d4d4] = 0.010[/color][color=#569cd6]BASE_PERIOD[/color][color=#d4d4d4] = 0[/color][color=#569cd6]SERVO_PERIOD[/color][color=#d4d4d4] = 5000000[/color] [color=#d4d4d4][HAL][/color][color=#569cd6]HALFILE[/color][color=#d4d4d4] = remora-xyz.hal[/color][color=#569cd6]POSTGUI_HALFILE[/color][color=#d4d4d4] = postgui_call_list.hal[/color] [color=#d4d4d4][TRAJ][/color][color=#569cd6]COORDINATES[/color][color=#d4d4d4] = X Y Z [/color][color=#569cd6]LINEAR_UNITS[/color][color=#d4d4d4] = mm[/color][color=#569cd6]ANGULAR_UNITS[/color][color=#d4d4d4] = degree[/color][color=#569cd6]CYCLE_TIME[/color][color=#d4d4d4] = 0.010[/color][color=#569cd6]DEFAULT_LINEAR_VELOCITY[/color][color=#d4d4d4] = 4.17[/color][color=#569cd6]MAX_LINEAR_VELOCITY[/color][color=#d4d4d4] = 28.7[/color][color=#569cd6]NO_FORCE_HOMING[/color][color=#d4d4d4] = 1 [/color] [color=#d4d4d4][EMCIO][/color][color=#569cd6]EMCIO[/color][color=#d4d4d4] = io[/color][color=#569cd6]CYCLE_TIME[/color][color=#d4d4d4] = 0.100[/color][color=#569cd6]TOOL_TABLE[/color][color=#d4d4d4] = tool.tbl[/color] [color=#6a9955]#*** AXIS_X *******************************[/color][color=#d4d4d4][AXIS_X][/color][color=#569cd6]MAX_VELOCITY[/color][color=#d4d4d4] = 28.7[/color][color=#569cd6]MAX_ACCELERATION[/color][color=#d4d4d4] = 287.0[/color][color=#569cd6]MIN_LIMIT[/color][color=#d4d4d4] = -0.001[/color][color=#569cd6]MAX_LIMIT[/color][color=#d4d4d4] = 1080.0[/color] [color=#d4d4d4][JOINT_0][/color][color=#569cd6]TYPE[/color][color=#d4d4d4] = LINEAR[/color][color=#569cd6]HOME[/color][color=#d4d4d4] = 0.0[/color][color=#569cd6]MIN_LIMIT[/color][color=#d4d4d4] = -0.001[/color][color=#569cd6]MAX_LIMIT[/color][color=#d4d4d4] = 1080.0[/color][color=#569cd6]MAX_VELOCITY[/color][color=#d4d4d4] = 28.7[/color][color=#569cd6]MAX_ACCELERATION[/color][color=#d4d4d4] = 287.0[/color][color=#569cd6]STEPGEN_MAXACCEL[/color][color=#d4d4d4] = 1000.0[/color][color=#569cd6]SCALE[/color][color=#d4d4d4] = 100.0[/color][color=#569cd6]FERROR[/color][color=#d4d4d4] = 5.0[/color][color=#569cd6]MIN_FERROR[/color][color=#d4d4d4] = 5.0[/color][color=#569cd6]HOME_OFFSET[/color][color=#d4d4d4] = 0.000000[/color][color=#569cd6]HOME_SEARCH_VEL[/color][color=#d4d4d4] = -45.000000[/color][color=#569cd6]HOME_LATCH_VEL[/color][color=#d4d4d4] = -2.500000[/color][color=#569cd6]HOME_SEQUENCE[/color][color=#d4d4d4] = 1[/color][color=#6a9955]#******************************************[/color] [color=#6a9955]#*** AXIS_Y *******************************[/color][color=#d4d4d4][AXIS_Y][/color][color=#569cd6]MAX_VELOCITY[/color][color=#d4d4d4] = 28.7[/color][color=#569cd6]MAX_ACCELERATION[/color][color=#d4d4d4] = 287.0[/color][color=#569cd6]MIN_LIMIT[/color][color=#d4d4d4] = -0.001[/color][color=#569cd6]MAX_LIMIT[/color][color=#d4d4d4] = 950.0[/color] [color=#d4d4d4][JOINT_1][/color][color=#569cd6]TYPE[/color][color=#d4d4d4] = LINEAR[/color][color=#569cd6]HOME[/color][color=#d4d4d4] = 0.0[/color][color=#569cd6]MIN_LIMIT[/color][color=#d4d4d4] = -0.001[/color][color=#569cd6]MAX_LIMIT[/color][color=#d4d4d4] = 950.0[/color][color=#569cd6]MAX_VELOCITY[/color][color=#d4d4d4] = 28.7[/color][color=#569cd6]MAX_ACCELERATION[/color][color=#d4d4d4] = 287.0[/color][color=#569cd6]STEPGEN_MAXACCEL[/color][color=#d4d4d4] = 1000.0[/color][color=#569cd6]SCALE[/color][color=#d4d4d4] = 100.0[/color][color=#569cd6]FERROR[/color][color=#d4d4d4] = 5.0[/color][color=#569cd6]MIN_FERROR[/color][color=#d4d4d4] = 5.0[/color][color=#569cd6]HOME_OFFSET[/color][color=#d4d4d4] = 0.000000[/color][color=#569cd6]HOME_SEARCH_VEL[/color][color=#d4d4d4] = -45.000000[/color][color=#569cd6]HOME_LATCH_VEL[/color][color=#d4d4d4] = 2.500000[/color][color=#569cd6]HOME_SEQUENCE[/color][color=#d4d4d4] = 2[/color][color=#6a9955]#******************************************[/color] [color=#6a9955]#*** AXIS_Z *******************************[/color][color=#d4d4d4][AXIS_Z][/color][color=#569cd6]MAX_VELOCITY[/color][color=#d4d4d4] = 20.0[/color][color=#569cd6]MAX_ACCELERATION[/color][color=#d4d4d4] = 150.0[/color][color=#569cd6]MIN_LIMIT[/color][color=#d4d4d4] = -125.0[/color][color=#569cd6]MAX_LIMIT[/color][color=#d4d4d4] = 0.001[/color] [color=#d4d4d4][JOINT_2][/color][color=#569cd6]TYPE[/color][color=#d4d4d4] = LINEAR[/color][color=#569cd6]HOME[/color][color=#d4d4d4] = 0.0[/color][color=#569cd6]MIN_LIMIT[/color][color=#d4d4d4] = -125.0[/color][color=#569cd6]MAX_LIMIT[/color][color=#d4d4d4] = 0.001[/color][color=#569cd6]MAX_VELOCITY[/color][color=#d4d4d4] = 20[/color][color=#569cd6]MAX_ACCELERATION[/color][color=#d4d4d4] = 150.0[/color][color=#569cd6]STEPGEN_MAXACCEL[/color][color=#d4d4d4] = 187.5[/color][color=#569cd6]SCALE[/color][color=#d4d4d4] = 800.0[/color][color=#569cd6]FERROR[/color][color=#d4d4d4] = 5.0[/color][color=#569cd6]MIN_FERROR[/color][color=#d4d4d4] = 5.0[/color][color=#569cd6]HOME_OFFSET[/color][color=#d4d4d4] = 0.000000[/color][color=#569cd6]HOME_SEARCH_VEL[/color][color=#d4d4d4] = 15.000000[/color][color=#569cd6]HOME_LATCH_VEL[/color][color=#d4d4d4] = 0.625000[/color][color=#569cd6]HOME_SEQUENCE[/color][color=#d4d4d4] = 0[/color][color=#6a9955]#******************************************[/color]
and this in our .hal file:
# load the realtime components
    loadrt [KINS]KINEMATICS
    loadrt [EMCMOT]EMCMOT base_period_nsec=[EMCMOT]BASE_PERIOD servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[KINS]JOINTS
    loadrt remora-spi SPI_num=0 CS_num=0 SPI_freq=2000000
    #loadrt remora_lpc chip_type=LPC SPI_clk_div=64
# estop loopback, SPI comms enable and feedback
    net user-enable-out     <= iocontrol.0.user-enable-out        => remora.SPI-enable
    net user-request-enable <= iocontrol.0.user-request-enable    => remora.SPI-reset
    net remora-status     <= remora.SPI-status             => iocontrol.0.emc-enable-in
# add the remora and motion functions to threads
    addf remora.read servo-thread
    addf remora.update-freq servo-thread
    addf remora.write servo-thread
# Joint 0 setup
    setp remora.joint.0.scale         [JOINT_0]SCALE
    setp remora.joint.0.maxaccel     [JOINT_0]STEPGEN_MAXACCEL
    net xpos-cmd         <= joint.0.motor-pos-cmd     => remora.joint.0.pos-cmd
    net j0pos-fb         <= remora.joint.0.pos-fb     => joint.0.motor-pos-fb
    net j0enable         <= joint.0.amp-enable-out     => remora.joint.0.enable
# Joint 1 setup
    setp remora.joint.1.scale         [JOINT_1]SCALE
    setp remora.joint.1.maxaccel     [JOINT_1]STEPGEN_MAXACCEL
    net j1pos-cmd         <= joint.1.motor-pos-cmd     => remora.joint.1.pos-cmd
    net j1pos-fb         <= remora.joint.1.pos-fb     => joint.1.motor-pos-fb
    net j1enable         <= joint.1.amp-enable-out     => remora.joint.1.enable
# Joint 2 setup
    setp remora.joint.2.scale         [JOINT_2]SCALE
    setp remora.joint.2.maxaccel     [JOINT_2]STEPGEN_MAXACCEL
    net j2pos-cmd         <= joint.2.motor-pos-cmd     => remora.joint.2.pos-cmd
    net j2pos-fb         <= remora.joint.2.pos-fb     => joint.2.motor-pos-fb
    net j2enable         <= joint.2.amp-enable-out     => remora.joint.2.enable
# inputs
    #endstops
    net X-min remora.input.01 => joint.0.home-sw-in
    net Y-min remora.input.00 => joint.1.home-sw-in
    net Z-min remora.input.02 => joint.2.home-sw-in
We flashed this firmware to it: github.com/scottalford75/Remora/tree/mai...in/STM32F446/BTT_446
and are running the above mentioned config file.
we also tried looking at the debug info but nothing came up, here's the printout:
Creating a std module
Remora PRU - Programmable Realtime Unit
 Mbed-OS6
 Remora-spi Driver
## Entering SETUP state
1. Reading json configuration file
Mounting the filesystem... OK
Opening "/fs/config.txt"... OK
Json config file lenght = 1996
Closing "/fs/config.txt"...
2. Setting up DMA and threads
Initialising SPI1 slave
Initialising DMA for SPI
3. Parsing json configuration file
Config deserialisation - Deserialization succeeded
4. Config threads
Creating thread 40000
Creating thread 1000
Creating thread 57600
5. Loading modules
Servo thread object
Reset pin
Make Reset Pin at pin PC_15
Creating Pin @
  port = GPIOC
  pin = 15
Servo thread object
eStop
Make eStop at pin PG_12
Creating Pin @
  port = GPIOG
  pin = 12
Servo thread object
Spindle
Make PWM at pin PB_0
Creating variable frequency Hardware PWM at pin PB_0
Creating Pin @
  port = GPIOB
  pin = 0
Base thread object
Creating Pin @
  port = GPIOG
  pin = 2
Creating Pin @
  port = GPIOF
  pin = 9
Creating Pin @
  port = GPIOF
  pin = 10
Base thread object
Creating Pin @
  port = GPIOF
  pin = 1
Creating Pin @
  port = GPIOC
  pin = 13
Creating Pin @
  port = GPIOF
  pin = 0
Base thread object
Creating Pin @
  port = GPIOD
  pin = 4
Creating Pin @
  port = GPIOE
  pin = 2
Creating Pin @
  port = GPIOE
  pin = 3
Base thread object
Creating Pin @
  port = GPIOE
  pin = 0
Creating Pin @
  port = GPIOE
  pin = 6
Creating Pin @
  port = GPIOA
  pin = 14
Servo thread object
X min
Make Digital Input at pin PG_6
  Setting pin as No Pull
Creating Pin @
  port = GPIOG
  pin = 6
Servo thread object
Y min
Make Digital Input at pin PG_9
Creating Pin @
  port = GPIOG
  pin = 9
Servo thread object
Z min
Make Digital Input at pin PG_10
Creating Pin @
  port = GPIOG
  pin = 10
Servo thread object
Probe
Make Digital Input at pin PG_11
Creating Pin @
  port = GPIOG
  pin = 11
## Entering START state
Starting the BASE thread
Registering interrupt for interrupt number = 24
        power on Timer 9
Starting the SERVO thread
Registering interrupt for interrupt number = 25
        power on Timer 10
## Entering IDLE state
## Entering RUNNING state
## Entering RESET state
   Resetting rxBuffer
All the pins are generated in the correct order it seem's, we are gonna test next the output signal strength, maybe the drivers don't have enough power on high state to start moving, even if everything is connected to the same ground.
18 Sep 2025 19:08 #335165 by Gusgus
	"Board": "BIGTREETECH Octopus Pro",
	"Modules":[
	"Thread": "Servo",
	"Type": "Reset Pin",
		"Comment":			"Reset pin",
		"Pin":				"PC_15"
	"Thread": "Servo",
	"Type": "eStop",
		"Comment":			"eStop",
		"Pin":				"PG_12"
    "Thread": "Servo",
    "Type": "PWM",
            "Comment":                      "Spindle",
            "SP[i]":                        3,
            "PWM Pin":                      "PB_0",
            "PWM Max":                      255,
            "Hardware PWM":                 "True",
            "Variable Freq":                "True",
            "Period SP[i]":         1,
            "Period us":                    200
	"Thread": "Base",
	"Type": "Stepgen",
		"Comment":			"X - Joint 0 step generator",
		"Joint Number":		0,
		"Step Pin": 		"PF_9",
		"Direction Pin": 	"PF_10",
		"Enable Pin": 		"PG_2"
	"Thread": "Base",
	"Type": "Stepgen",
		"Comment":			"Y1 - Joint 1 step generator",
		"Joint Number":		1,
		"Step Pin": 		"PC_13",
		"Direction Pin": 	"PF_0",
		"Enable Pin": 		"PF_1"
	"Thread": "Base",
	"Type": "Stepgen",
		"Comment":			"Y2 - Joint 1 step generator",
		"Joint Number":		1,
		"Step Pin": 		"PE_2",
		"Direction Pin": 	"PE_3",
		"Enable Pin": 		"PD_4"
	"Thread": "Base",
	"Type": "Stepgen",
		"Comment":			"Z - Joint 2 step generator",
		"Joint Number":		2,
		"Step Pin": 		"PE_6",
		"Direction Pin": 	"PA_14",
		"Enable Pin": 		"PE_0"
	"Thread": "Servo",
	"Type": "Digital Pin",
		"Comment":			"X min",
		"Pin":				"PG_6",
		"Mode":				"Input",
		"Data Bit":			0
	"Thread": "Servo",
		"Comment":			"Y min",
		"Pin":				"PG_9",
		"Mode":				"Input",
		"Data Bit":			1
	"Thread": "Servo",
		"Comment":			"Z min",
		"Pin":				"PG_10",
		"Mode":				"Input",
		"Data Bit":			2
	"Thread": "Servo",
		"Comment":			"Probe",
		"Pin":				"PG_11",
		"Mode":				"Input",
		"Data Bit":			3
[EMC]
MACHINE = Remora-XYZ
DEBUG = 0
VERSION = 1.1
[DISPLAY]
DISPLAY = axis
EDITOR = gedit
POSITION_OFFSET = RELATIVE
POSITION_FEEDBACK = ACTUAL
ARCDIVISION = 64
GRIDS = 10mm 20mm 50mm 100mm
MAX_FEED_OVERRIDE = 1.2
MIN_SPINDLE_OVERRIDE = 0.5
MAX_SPINDLE_OVERRIDE = 1.2
DEFAULT_LINEAR_VELOCITY = 28.7
MIN_LINEAR_VELOCITY = 0
MAX_LINEAR_VELOCITY = 28.7
DEFAULT_ANGULAR_VELOCITY = 28.7
MIN_ANGULAR_VELOCITY = 0
MAX_ANGULAR_VELOCITY = 28.7
INTRO_TIME = 5
PROGRAM_PREFIX = ~/linuxcnc/nc_files
INCREMENTS = 50mm 10mm 5mm 1mm .5mm .1mm .05mm .01mm
[KINS]
JOINTS = 3
[FILTER]
py = python
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
[RS274NGC]
PARAMETER_FILE = linuxcnc.var
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
COMM_WAIT = 0.010
BASE_PERIOD = 0
SERVO_PERIOD = 5000000
[HAL]
HALFILE = remora-xyz.hal
POSTGUI_HALFILE = postgui_call_list.hal
[TRAJ]
COORDINATES =  X Y Z
LINEAR_UNITS = mm
ANGULAR_UNITS = degree
CYCLE_TIME = 0.010
DEFAULT_LINEAR_VELOCITY = 4.17
NO_FORCE_HOMING = 1
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
TOOL_TABLE = tool.tbl
[AXIS_X]
MAX_VELOCITY = 28.7
MAX_ACCELERATION = 287.0
MIN_LIMIT = -0.001
MAX_LIMIT = 1080.0
[JOINT_0]
TYPE = LINEAR
HOME = 0.0
MIN_LIMIT = -0.001
MAX_LIMIT = 1080.0
MAX_VELOCITY = 28.7
STEPGEN_MAXACCEL = 1000.0
SCALE = 100.0
FERROR = 5.0
MIN_FERROR = 5.0
HOME_OFFSET = 0.000000
HOME_SEARCH_VEL = -45.000000
HOME_LATCH_VEL = -2.500000
HOME_SEQUENCE = 1
[AXIS_Y]
MAX_VELOCITY = 28.7
MIN_LIMIT = -0.001
MAX_LIMIT = 950.0
[JOINT_1]
TYPE = LINEAR
HOME = 0.0
MIN_LIMIT = -0.001
MAX_LIMIT = 950.0
MAX_VELOCITY = 28.7
SCALE = 100.0
FERROR = 5.0
MIN_FERROR = 5.0
HOME_LATCH_VEL = 2.500000
HOME_SEQUENCE = 2
[AXIS_Z]
MAX_VELOCITY = 20.0
MAX_ACCELERATION = 150.0
MIN_LIMIT = -125.0
MAX_LIMIT = 0.001
[JOINT_2]
TYPE = LINEAR
HOME = 0.0
MIN_LIMIT = -125.0
MAX_LIMIT = 0.001
MAX_VELOCITY = 20
STEPGEN_MAXACCEL = 187.5
SCALE = 800.0
FERROR = 5.0
MIN_FERROR = 5.0
HOME_SEARCH_VEL = 15.000000
HOME_LATCH_VEL = 0.625000
HOME_SEQUENCE = 0
sorry i had a formatting error
18 Sep 2025 20:40 #335167 by scotta
I would suggest setting up a configuration for 4 joints X Y Y Z. You should not be pointing multiple step generators at the same frequency command or command feedback.
Take a look at this 5 joint config where there are two joints assigned to the Z axis. You can do the same for your dual Y axes.
github.com/scottalford75/Remora/tree/mai...figSamples/hypercube
20 Oct 2025 16:18 #336754 by fatih.d
Hi all, first post.
Could anyone point me to the right direction about using a 446 based board (Fysetc S6) with no SD card slot?
What would be the best, going with static config approach (I don't know how to do it or use which version/fork) or using an SD card adapter and have them talk over SPI? Using SDIO/SDMMC interface would not be so straightforward I guess.
Many thanks to those who made this project real. It was a fun read and I've learned so much. (Not a software guy)
24 Oct 2025 02:41 #337017 by Fred2560
Is QEI working ?
I have a RPI 4 SPI connected to a BLACK_407VE and an encoder with index connected to PE9, PE11, PE13. All works well except QEI, remora.PV.2 never changes, always = 0. Am I missing something ?
config txt :
    "Thread": "Servo",
    "Type": "QEI",
            "Comment":                      "Spindle encoder",
            "PV":                        2,
            "Data Bit":                     7,
            "Enable Index":                 "True"
Debug output:
Servo thread object
Spindle encoder
Creating QEI, hardware quadrature encoder interface
  Encoder has index
  Initialising hardware QEI module
26 Oct 2025 19:50 #337243 by scotta
The A and B channels should be connected to PE9 and PE11, index to PE13. So that looks correct. It should work, but I have not played with the QEI for ages.
12 Nov 2025 01:12 #338230 by OBi
I have a newly minted Linuxcnc 2.9.7 installed on a Raspberry PI 4.
I have successfully compiled the remora.c component from cakeslob/rrw_lab
trying 'sudo halcompile --install remora-spi.c' from cakeslob/main and scottalford75 will not compile. Lots of errors.
Components/Remora-spi/rp1lib.c:94:9: error: assignment to ‘struct spi_device *’ from incompatible pointer type ‘struct spi_device **’ [-Wincompatible-pointer-types]    94 |     dev = &inst->spi_dev[spi_num];
I have also a working linuxcnc 2.9.3 that compiles remora-spi.c fine
Are there any changes in linuxcnc from version 2.9.3 to 2.9.7 that makes this happen?
I will make do with the earlier remora component...
I just wanted to inform that there is some issues
12 Nov 2025 01:16 #338231 by unknown
You didn't by chance use the new trixie image on the downloads page did you ?
12 Nov 2025 21:12 #338283 by OBi
Actually, yes I did... Shouldn't I?
Time to create page: 1.391 seconds
