1 year 1 month ago #334309 by Gusgus
Hi Scotta! Thank you for all the help and being so patient with us.
We have wired all of the enabels to one single enable since that enables the whole machine for simplicity's sake.
We have tested what you suggested and we now get enable and move the axis, the issue now, is that we can't move them for long. Not even a second, in the best cases just a second. We attempted to decrease the accelerations even further and increase the f error to 2 and 5 which also didn't really help, we also tested decreasing the SPI frequency to 1MHz and changed the STEPGEN_MAXACCEL to 1000; whilst keeping the 25% acceleration buffer from the max acceleration to the stepgen.
remora-xyz.ini:
# Basic LinuxCNC config for testing of Remora firmware
[EMC]
MACHINE = Remora-XYZ
DEBUG = 0
VERSION = 1.1
[DISPLAY]
DISPLAY = axis
EDITOR = gedit
POSITION_OFFSET = RELATIVE
POSITION_FEEDBACK = ACTUAL
ARCDIVISION = 64
GRIDS = 10mm 20mm 50mm 100mm
MAX_FEED_OVERRIDE = 1.2
MIN_SPINDLE_OVERRIDE = 0.5
MAX_SPINDLE_OVERRIDE = 1.2
DEFAULT_LINEAR_VELOCITY = 28.7
MIN_LINEAR_VELOCITY = 0
MAX_LINEAR_VELOCITY = 28.7
DEFAULT_ANGULAR_VELOCITY = 28.7
MIN_ANGULAR_VELOCITY = 0
MAX_ANGULAR_VELOCITY = 28.7
INTRO_TIME = 5
PROGRAM_PREFIX = ~/linuxcnc/nc_files
INCREMENTS = 50mm 10mm 5mm 1mm .5mm .1mm .05mm .01mm
[KINS]
JOINTS = 3
#KINEMATICS =trivkins coordinates=XYZ kinstype=BOTH
[FILTER]
py = python
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
[RS274NGC]
PARAMETER_FILE = linuxcnc.var
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
COMM_WAIT = 0.010
BASE_PERIOD = 0
SERVO_PERIOD = 5000000
[HAL]
HALFILE = remora-xyz.hal
POSTGUI_HALFILE = postgui_call_list.hal
[TRAJ]
COORDINATES =  X Y Z
LINEAR_UNITS = mm
ANGULAR_UNITS = degree
CYCLE_TIME = 0.010
DEFAULT_LINEAR_VELOCITY = 4.17
NO_FORCE_HOMING = 1
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
TOOL_TABLE = tool.tbl
#*** AXIS_X *******************************
[AXIS_X]
MAX_VELOCITY = 28.7
MAX_ACCELERATION = 287.0
MIN_LIMIT = -0.001
MAX_LIMIT = 1080.0
[JOINT_0]
TYPE = LINEAR
HOME = 0.0
MIN_LIMIT = -0.001
MAX_LIMIT = 1080.0
MAX_VELOCITY = 28.7
STEPGEN_MAXACCEL = 1000.0
SCALE = 100.0
FERROR = 5.0
MIN_FERROR = 5.0
HOME_OFFSET = 0.000000
HOME_SEARCH_VEL = -45.000000
HOME_LATCH_VEL = -2.500000
HOME_SEQUENCE = 1
#*** AXIS_Y *******************************
[AXIS_Y]
MAX_VELOCITY = 28.7
MIN_LIMIT = -0.001
MAX_LIMIT = 950.0
[JOINT_1]
TYPE = LINEAR
HOME = 0.0
MIN_LIMIT = -0.001
MAX_LIMIT = 950.0
MAX_VELOCITY = 28.7
SCALE = 100.0
FERROR = 5.0
MIN_FERROR = 5.0
HOME_LATCH_VEL = 2.500000
HOME_SEQUENCE = 2
#*** AXIS_Z *******************************
[AXIS_Z]
MAX_VELOCITY = 20.0
MAX_ACCELERATION = 150.0
MIN_LIMIT = -125.0
MAX_LIMIT = 0.001
[JOINT_2]
TYPE = LINEAR
HOME = 0.0
MIN_LIMIT = -125.0
MAX_LIMIT = 0.001
MAX_VELOCITY = 20
STEPGEN_MAXACCEL = 187.5
SCALE = 800.0
FERROR = 5.0
MIN_FERROR = 5.0
HOME_SEARCH_VEL = 15.000000
HOME_LATCH_VEL = 0.625000
HOME_SEQUENCE = 0
remora-xyz.hal:
# load the realtime components
        loadrt [KINS]KINEMATICS
        loadrt [EMCMOT]EMCMOT base_period_nsec=[EMCMOT]BASE_PERIOD servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[KINS]J$
        loadrt remora-spi SPI_clk_div=32 SPI_num=0 CS_num=0 SPI_freq=1000000
        #loadrt remora_lpc chip_type=LPC SPI_clk_div=64
# estop loopback, SPI comms enable and feedback
        net user-enable-out     <= iocontrol.0.user-enable-out          => remora.SPI-enable
        net user-request-enable <= iocontrol.0.user-request-enable      => remora.SPI-reset
        net remora-status       <= remora.SPI-status                    => iocontrol.0.emc-enable-in
# add the remora and motion functions to threads
        addf remora.read servo-thread
        addf remora.update-freq servo-thread
        addf remora.write servo-thread
# Joint 0 setup
        setp remora.joint.0.scale               [JOINT_0]SCALE
        setp remora.joint.0.maxaccel    [JOINT_0]STEPGEN_MAXACCEL
        net xpos-cmd            <= joint.0.motor-pos-cmd        => remora.joint.0.pos-cmd
        net j0pos-fb            <= remora.joint.0.pos-fb        => joint.0.motor-pos-fb
        net j0enable            <= joint.0.amp-enable-out       => remora.joint.0.enable
# Joint 1 setup
        setp remora.joint.1.scale               [JOINT_1]SCALE
        setp remora.joint.1.maxaccel    [JOINT_1]STEPGEN_MAXACCEL
        net j1pos-cmd           <= joint.1.motor-pos-cmd        => remora.joint.1.pos-cmd
        net j1pos-fb            <= remora.joint.1.pos-fb        => joint.1.motor-pos-fb
        net j1enable            <= joint.1.amp-enable-out       => remora.joint.1.enable
# Joint 2 setup
        setp remora.joint.2.scale               [JOINT_2]SCALE
        setp remora.joint.2.maxaccel    [JOINT_2]STEPGEN_MAXACCEL
        net j2pos-cmd           <= joint.2.motor-pos-cmd        => remora.joint.2.pos-cmd
        net j2pos-fb            <= remora.joint.2.pos-fb        => joint.2.motor-pos-fb
        net j2enable            <= joint.2.amp-enable-out       => remora.joint.2.enable
# inputs
        #endstops
        net X-min remora.input.01 => joint.0.home-sw-in
        net Y-min remora.input.00 => joint.1.home-sw-in
        net Z-min remora.input.02 => joint.2.home-sw-in
This is our current setup
the config.txt remains unchanged
1 year 1 month ago #334371 by scotta
Great to hear you are making progress.
No need for the SPI_clk_div=32 in the loadrt command line, that is for the RPi4/3.
What fault / error is generated when the machine stops? I've still got the Octopus and RPi setup on the bench, will look to try your config again over the weekend.
1 year 1 month ago #334375 by Gusgus
Hi Scotta!
This is the error we get:
"command (EMC_JOG_CONT) cannot be executed until the machine is out of E-stop and turned on"
but when we disconnect the E-stop it recognizes that it is connected, we also sometimes get the Joint X following error.
1 year 1 month ago #334399 by amanker
I was using Octopus Pro Board for LinuxCNC. That one is giving some problems. So I bought new board BTT SKR3 so that I can use TMC5160. Can anyone help me setting up its config.txt and LinuxCNC configuration. And connection diagram. I have wired it as per SKR2 board. Pinouts of both boards seems similar. I cant get Machine out of estop. I think there is no communication between rpi and skr3.
Remora.ini
# Basic LinuxCNC config for testing of Remora firmware [EMC] MACHINE = Remora-XYZ DEBUG = 0 VERSION = 1.1 [DISPLAY] DISPLAY = axis EDITOR = gedit POSITION_OFFSET = RELATIVE POSITION_FEEDBACK = ACTUAL ARCDIVISION = 64 GRIDS = 10mm 20mm 50mm 100mm MAX_FEED_OVERRIDE = 1.2 MIN_SPINDLE_OVERRIDE = 0.5 MAX_SPINDLE_OVERRIDE = 1.2 DEFAULT_LINEAR_VELOCITY = 50.00 MIN_LINEAR_VELOCITY = 0 MAX_LINEAR_VELOCITY = 200.00 DEFAULT_ANGULAR_VELOCITY = 36.00 MIN_ANGULAR_VELOCITY = 0 MAX_ANGULAR_VELOCITY = 45.00 INTRO_GRAPHIC = linuxcnc.gif INTRO_TIME = 5 PROGRAM_PREFIX = ~/linuxcnc/nc_files INCREMENTS = 50mm 10mm 5mm 1mm .5mm .1mm .05mm .01mm [KINS] JOINTS = 3 #KINEMATICS =trivkins coordinates=XYZ kinstype=BOTH KINEMATICS =trivkins coordinates=XYZ [FILTER] PROGRAM_EXTENSION = .py Python Script py = python [TASK] TASK = milltask CYCLE_TIME = 0.010 [RS274NGC] PARAMETER_FILE = linuxcnc.var [EMCMOT] EMCMOT = motmod COMM_TIMEOUT = 1.0 COMM_WAIT = 0.010 BASE_PERIOD = 0 SERVO_PERIOD = 1000000 [HAL] HALFILE = remora.hal POSTGUI_HALFILE = postgui_call_list.hal [TRAJ] COORDINATES =  X Y Z  LINEAR_UNITS = mm ANGULAR_UNITS = degree CYCLE_TIME = 0.010 DEFAULT_LINEAR_VELOCITY = 50.00 MAX_LINEAR_VELOCITY = 200.00 NO_FORCE_HOMING = 1  [EMCIO] EMCIO = io CYCLE_TIME = 0.100 TOOL_TABLE = tool.tbl [AXIS_X] MAX_VELOCITY = 500 MAX_ACCELERATION = 1000.0 MIN_LIMIT = -500 MAX_LIMIT = 500.0 [JOINT_0] TYPE = LINEAR HOME = 0.0 MIN_LIMIT = -500.0 MAX_LIMIT = 500.0 MAX_VELOCITY = 500.0 MAX_ACCELERATION = 1000.0 STEPGEN_MAXACCEL = 2000.0 SCALE = 200.0 FERROR = 2 MIN_FERROR = 2.0 HOME_OFFSET = 0.0 HOME_SEARCH_VEL = 0 HOME_LATCH_VEL = 0 HOME_SEQUENCE = 0 [AXIS_Y] MAX_VELOCITY = 250.0 MAX_ACCELERATION = 750.0 MIN_LIMIT = -300.0 MAX_LIMIT = 300.0 [JOINT_1] TYPE = LINEAR HOME = 0.0 MIN_LIMIT = -300.0 MAX_LIMIT = 300.0 MAX_VELOCITY = 250.0 MAX_ACCELERATION = 750.0 STEPGEN_MAXACCEL = 2000.0 SCALE = 80.0 FERROR = 9.0 MIN_FERROR = 5.0 HOME_OFFSET = 0.0 HOME_SEARCH_VEL = 0 HOME_LATCH_VEL = 0 HOME_SEQUENCE = 0 [AXIS_Z] OFFSET_AV_RATIO = 0.2 MAX_VELOCITY = 5.0 MAX_ACCELERATION = 200.0 MIN_LIMIT = -280 MAX_LIMIT = 280 [JOINT_2] TYPE = LINEAR HOME = 0.0 MIN_LIMIT = -280 MAX_LIMIT = 280 MAX_VELOCITY = 5.0 MAX_ACCELERATION = 200.0 STEPGEN_MAXACCEL = 3000.0 SCALE = 400.0 FERROR = 5 MIN_FERROR = 1.0 HOME_OFFSET = 0.0 HOME_SEARCH_VEL = 0 HOME_LATCH_VEL = 0 HOME_SEQUENCE = 0
remora.hal
# load the realtime components     loadrt [KINS]KINEMATICS     loadrt [EMCMOT]EMCMOT base_period_nsec=[EMCMOT]BASE_PERIOD servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[KINS]JOINTS     loadrt remora-spi     #loadrt remora_lpc chip_type=LPC SPI_clk_div=64 # estop loopback, SPI comms enable and feedback     net user-enable-out     <= iocontrol.0.user-enable-out        => remora.SPI-enable     net user-request-enable <= iocontrol.0.user-request-enable    => remora.SPI-reset     net remora-status     <= remora.SPI-status             => iocontrol.0.emc-enable-in      # add the remora and motion functions to threads     addf remora.read servo-thread     addf motion-command-handler servo-thread     addf motion-controller servo-thread     addf remora.update-freq servo-thread     addf remora.write servo-thread # Joint 0 setup     setp remora.joint.0.scale         [JOINT_0]SCALE     setp remora.joint.0.maxaccel     [JOINT_0]STEPGEN_MAXACCEL     net xpos-cmd         <= joint.0.motor-pos-cmd     => remora.SP.0  joint.0.motor-pos-fb #    net j0pos-fb         <= remora.joint.0.pos-fb     => joint.0.motor-pos-fb #    net j0enable         <= joint.0.amp-enable-out     => remora.joint.0.enable # Joint 1 setup     setp remora.joint.1.scale         [JOINT_1]SCALE     setp remora.joint.1.maxaccel     [JOINT_1]STEPGEN_MAXACCEL     net j1pos-cmd         <= joint.1.motor-pos-cmd     => remora.joint.1.pos-cmd     net j1pos-fb         <= remora.joint.1.pos-fb     => joint.1.motor-pos-fb      net j1enable         <= joint.1.amp-enable-out     => remora.joint.1.enable # Joint 2 setup     setp remora.joint.2.scale         [JOINT_2]SCALE     setp remora.joint.2.maxaccel     [JOINT_2]STEPGEN_MAXACCEL     net j2pos-cmd         <= joint.2.motor-pos-cmd     => remora.joint.2.pos-cmd     net j2pos-fb         <= remora.joint.2.pos-fb     => joint.2.motor-pos-fb     net j2enable         <= joint.2.amp-enable-out     => remora.joint.2.enable
config.txt
{     "Board": "BIGTREETECH SKR v3",     "Modules":[     {     "Thread": "Servo",     "Type": "Reset Pin",         "Comment":            "Reset pin",         "Pin":                "PC_4"     },     {     "Thread": "On load",     "Type": "Motor Power",         "Comment": "Enable motor power SKR2",         "Pin":                     "PC_13"     },     {     "Thread": "Base",     "Type": "Stepgen",         "Comment":            "X - Joint 0 step generator",         "Joint Number":        0,         "Step Pin":         "PD_4",         "Direction Pin":     "PD_3",         "Enable Pin":         "PD_6"     },     {     "Thread": "Base",     "Type": "Stepgen",         "Comment":            "Y - Joint 1 step generator",         "Joint Number":        1,         "Step Pin":         "PA_15",         "Direction Pin":     "PA_8",         "Enable Pin":         "PD_1"     },     {     "Thread": "Base",     "Type": "Stepgen",         "Comment":            "Z - Joint 2 step generator",         "Joint Number":        2,         "Step Pin":         "PE_2",         "Direction Pin":     "PE_3",         "Enable Pin":         "PE_0"     },     {     "Thread": "Servo",     "Type": "Digital Pin",         "Comment":            "X min",         "Pin":                "PC_1",         "Mode":                "Input",         "Data Bit":            0     },     {     "Thread": "Servo",     "Type": "Digital Pin",         "Comment":            "X max",         "Pin":                "PC_2",         "Mode":                "Input",         "Data Bit":            1     },     {     "Thread": "Servo",     "Type": "Digital Pin",         "Comment":            "Y min",         "Pin":                "PC_3",         "Mode":                "Input",         "Data Bit":            2     },     {     "Thread": "Servo",     "Type": "Digital Pin",         "Comment":            "Y max",         "Pin":                "PA_0",         "Mode":                "Input",         "Data Bit":            3     },     {     "Thread": "Servo",     "Type": "Digital Pin",         "Comment":            "Z min",         "Pin":                "PC_0",         "Mode":                "Input",         "Data Bit":            4     },     {     "Thread": "Servo",     "Type": "Digital Pin",         "Comment":            "Z max",         "Pin":                "PC_15",         "Mode":                "Input",         "Data Bit":            5     }     ] }
1 year 1 month ago #334441 by scotta
Which firmware are you using? The SKR3 is only supported in the latest Remora-core development repo.
1 year 1 month ago #334466 by amanker
Yes. I have cloned latest remora-h7xx-pio repository from remora-cnc. And compiled that. And used config files attached in previous post.
Time to create page: 0.160 seconds
