- Thank you received: 234
linuxcnc-esp32 Software Stepping over Ethernet Using ESP32
- Bari
4 years 3 months ago #248473
by Bari
Replied by Bari on topic linuxcnc-esp32 Software Stepping over Ethernet Using ESP32
Ok, managed to get the video to load some times.
- eng
- Thank you received: 8
4 years 3 months ago #248475
by eng
Replied by eng on topic linuxcnc-esp32 Software Stepping over Ethernet Using ESP32
this video is already old, I changed a few things and improved communication.
- xek
4 years 2 months ago - 4 years 2 months ago #250495
by xek
Replied by xek on topic linuxcnc-esp32 Software Stepping over Ethernet Using ESP32
A quick update. I have used a using slightly modified jzolee's code to coomodate for 4th axis for around a month, it works okay, but reboots/hangs several times a day because of my plasma cutter's radio interference.
Overall it is a working solution.
Last edit: 4 years 2 months ago by xek.
- Thank you received: 7491
4 years 2 months ago #250501
Replied by tommylight on topic linuxcnc-esp32 Software Stepping over Ethernet Using ESP32
Yeah, plasma makes a lot of electric noise.
Use the shortest cable possible, use a ground cable wound around signal cables, put the electronics inside a metal box that is properly grounded, move signal cables as far from the plasma source as possible, ground the PC, table and plasma source, etc.
If everything fails, put 330-470Ohm resistors on all inputs, even the ones not in use.
- Trihwangyudi1990
4 years 2 months ago #250671
by Trihwangyudi1990
Replied by Trihwangyudi1990 on topic linuxcnc-esp32 Software Stepping over Ethernet Using ESP32
- Thank you received: 4153
4 years 2 months ago #250672
Replied by rodw on topic linuxcnc-esp32 Software Stepping over Ethernet Using ESP32
Its tricky to set up from a Windows machine but you should be able to crete a SAMBA share and write direct.
Then you can open the file on the LinuxPC and start the job
If you use QTplasmac, you can program a Load Latest file button which wokrs amazingly well. eg save the postprocessor output (eg sheetcam) to the lcnc nc_files folder, press load latest and then press cycle start
