linuxcnc-esp32 Software Stepping over Ethernet Using ESP32
1 year 7 months ago #324301 by leandrocontarini
Replied by leandrocontarini on topic linuxcnc-esp32 Software Stepping over Ethernet Using ESP32
Hello, could you share these files?
The link has been deleted
1 year 7 months ago #324320 by tommylight
github.com/wezhunter/ESP32_LinuxCNC_MotionController_RealTime
This is not the same project as the other one you posted in, although they are probably related somehow...somewhere...
1 year 3 months ago #331959 by leandrocontarini
Segue o vídeo , consegui com uma placa de impressora 3d.
www.facebook.com/share/v/1BzA9DNq27/
Mas parece não ser tempo real.
1 year 2 months ago - 1 year 2 months ago #333733 by FrankDunn
I have a Mks dlc32 board connected as described in previous posts but I am not sure how to assign x pulse via i2s channel and not gpio25. Is there a a way to have pulse and direction via i2s? I am using this :
Edit:  I found the answer, the software is not designed to work with pulse assigned to i2s pins. I use the A4988 stepper drivers and wanted to use them without any mods.
Last edit: 1 year 2 months ago by FrankDunn.
Time to create page: 0.299 seconds
