linuxcnc-esp32 Software Stepping over Ethernet Using ESP32
- rohit269
2 years 6 months ago #298013
by rohit269
Replied by rohit269 on topic linuxcnc-esp32 Software Stepping over Ethernet Using ESP32
Sir,
driver , udp.comp not install I try many time but always found error user/bin/halcomplie not found udp.comp file so please tell how to install linuxcnc driver.
- pippin88
- Thank you received: 51
2 years 6 months ago #298030
by pippin88
Replied by pippin88 on topic linuxcnc-esp32 Software Stepping over Ethernet Using ESP32
The problem is halcompile is missing
Not anything to do with this thread component
Try:
sudo apt-get install linuxcnc-uspace-dev
How did you install linuxcnc?
Try:
- pocovolvedor
2 years 6 months ago #298328
by pocovolvedor
Replied by pocovolvedor on topic linuxcnc-esp32 Software Stepping over Ethernet Using ESP32
Hey Wez. Its possible to pay for your help?
Im looking to do a retrofit with this project but have no knowledge about programing.
Please let me know. Thanks
- wez
- Thank you received: 104
2 years 6 months ago - 2 years 6 months ago #298639
by wez
Replied by wez on topic linuxcnc-esp32 Software Stepping over Ethernet Using ESP32
Quick update: I plan on picking this up again in the near future. After detailed testing is complete I will publish a new version, as originally promised - life has got in the way quite a bit.
Hopefully (fingers crossed) once a working multi-architecture (ESP32/S2/S3) supporting multiple connectivity types is released and is being used in the wild others may be willing to help take up future maintenance of the project.
pocovolvedor - I'll do my best to try to help you out. Feel free to contact me directly on my email address which is located at the top in the licensing header of the "src/main.cpp" source file in my GitHub repo. Not posting directly for obvious reasons.
Cheers
Cheers
Last edit: 2 years 6 months ago by wez.
- itsemast
2 years 5 months ago #300322
by itsemast
Replied by itsemast on topic linuxcnc-esp32 Software Stepping over Ethernet Using ESP32
- aparecido
- Thank you received: 6
2 years 5 months ago - 2 years 5 months ago #301245
by aparecido
Replied by aparecido on topic linuxcnc-esp32 Software Stepping over Ethernet Using ESP32
Hello, how are you? I was reading the topic and saw your post, did you make the code available on a github account as you said in this post? Tks.i'm still learning about programming, i just took its structure from dds and put it inside a void IRAM_ATTR onTime_0() the same we used here in esp32, and used your .c
with some simple changes, I hope to make it the same as jzolee, as soon as everything is working correctly I will make it available on github so we can use it because at the moment everything is new to me and I don't have enough knowledge to discuss about it, I'm going in trial and error with some basic calculations.
Last edit: 2 years 5 months ago by aparecido.
Time to create page: 0.616 seconds
