- Thank you received: 13
linuxcnc-esp32 Software Stepping over Ethernet Using ESP32
- schoch
2 years 8 months ago - 2 years 8 months ago #293180
by schoch
Replied by schoch on topic linuxcnc-esp32 Software Stepping over Ethernet Using ESP32
very cool software, thanks Wez!!!
will be working on getting pots, and buttons working.
not sure how to embed video...
Last edit: 2 years 8 months ago by schoch. Reason: vid
- wez
- Thank you received: 104
2 years 8 months ago - 2 years 8 months ago #293184
by wez
Replied by wez on topic linuxcnc-esp32 Software Stepping over Ethernet Using ESP32
You're welcome! Don't forget about the motion control aspects too
For anyone new visiting this - this is where the discussion took place with this: [url] github.com/wezhunter/ESP32_LinuxCNC_Wireless_Client/issues/3 [/url]
Last edit: 2 years 8 months ago by wez.
The following user(s) said Thank You: aparecido
- wez
2 years 8 months ago - 2 years 8 months ago #293663
by wez
A new firmware release of this has been added which adds board agnostic firmware builds and a serial command line to configure both Controller and Client modes.
You can now simply download and flash a firmware build directly in order to get up and running.
See the releases section of the repo:
[url] github.com/wezhunter/ESP32_LinuxCNC_Moti...ses/tag/v20240218.01 [/url]
A guide to configuring a board using the console command line is here:
[url] github.com/wezhunter/ESP32_LinuxCNC_Moti...in/SerialCommands.md [/url]
New feature overview in this release are here:
[url] github.com/wezhunter/ESP32_LinuxCNC_Moti...-refactor---feb-2024 [/url]
- wez
2 years 8 months ago #293891
by wez
Whoever may be following the development of this...
You might be interested in my comments here:
[url] github.com/wezhunter/ESP32_LinuxCNC_Moti...uecomment-1955855354 [/url]
The following user(s) said Thank You: hairy, aaronstone, cekaa
- cekaa
2 years 7 months ago - 3 weeks 1 day ago #295665
by cekaa
Replied by cekaa on topic linuxcnc-esp32 Software Stepping over Ethernet Using ESP32
Hello
My English is weak, I write via Google Translate
I installed linuxcnc? I couldn't get the esp32 to communicate with the w5500.
sudo apt-get install linuxcnc-uspace-dev build-essential
sudo halcompile --install udp.comp
I could not succeed with hallcompile, unfortunately my knowledge about installing this file is limited and my Linux knowledge is low.
I used serial commands with success
An article explaining what I need to do
I would like an explanatory setup in bullet points, please.
thank you very much
thank you very much
Last edit: 3 weeks 1 day ago by tommylight. Reason: Link removed
- rohit269
2 years 6 months ago #298012
by rohit269
Replied by rohit269 on topic linuxcnc-esp32 Software Stepping over Ethernet Using ESP32
Sir,
driver , udp.comp not install I try many time but always found error user/bin/halcomplie not found udp.comp file
Time to create page: 0.263 seconds
