linuxcnc-esp32 Software Stepping over Ethernet Using ESP32
  • ALittleOffTheRails
  • Visitor
  • Visitor
4 years 10 months ago #229650 by ALittleOffTheRails
Replied by ALittleOffTheRails on topic linuxcnc-esp32 Software Stepping over Ethernet Using ESP32
Plus a switch
4 years 10 months ago #230245 by Cncninja
Check out this ESP CNC board I found for 15USD it just arrived   I will have to dig into the pinout to see if the SPI is accessible.
This browser does not support PDFs. Please download the PDF to view it: Download PDF
4 years 10 months ago #230249 by tommylight
You lucky ....   :)
4 years 9 months ago #231782 by tuzki
The point and feature of using the esp32 is that it connects over UDP so there can be a good distance between the motion controller and the stepgens.
If you want minimal parts count then look at AllwinCNC
forum.linuxcnc.org/18-computer/39037-lin...-orange-pi-allwincnc
It has the LCNC motion controller, GPU for GUI and stepgens all in one device. But you'll still need some output protection like you'll find on the Mesa IO boards.
Will UDP protocol not cause data loss ?
4 years 9 months ago #232081 by Bari
Not if implemented properly. LCNC has been working fine with UDP and Mesa cards for several years.
4 years 8 months ago #234164 by eng
Can you help me with this doubt? would it be possible to put something that monitors the communication between linux and esp32? I say this because I noticed that I see a drop in the communication, the engines being at work they continue to infinity, that is, they will only stop when the communication is established, this can cause a loss of a part for example, this also happens when a interference and loss of communication between esp32 and w5500, I thought of a watchdog to check the connection between linux cnc and esp32.
Time to create page: 0.180 seconds
