linuxcnc-esp32 Software Stepping over Ethernet Using ESP32
5 years 2 months ago #217024 by taylorcmq
the doubt i have is anyone ever had any real return with this code, i will try to reformulate it and maybe soon bring new results, i am also following the mx work, a pity it was closed, i believe that the H5 boards should have been implemented has more powerful hardware, but I'll be happy if I can use it with the H3 that arrives tomorrow, even so I still intend to study more about esp32
4 years 11 months ago - 4 years 10 months ago #226005 by jzolee
Hi, I'm new to the forum, I'd like to share my plans with you.I like do it yourself things. I have been trying to build a hardware step generator with different microcontrollers for a long time. I got the idea for a good implementation on this forum.
File Name: udp.comp
File Size:5 KB
File Name: UDP2.hal
File Size:8 KB
File Name: UDP2.ini
File Size:5 KB
File Name: platformio.ini
File Size:1 KB
File Name: main.cpp.txt
File Size:18 KB
I uploaded a video of a test:
2021.12.04 - I optimized some esp32 code snippets
Last edit: 4 years 10 months ago by jzolee.
The following user(s) said Thank You: Bari, tjtr33
4 years 11 months ago #226100 by taylorcmq
hi brother, could you explain to me the logic you are using, what are you thinking, what is the .ino file you used in esp32? I did some tests here the program works fine but the step generator is square, the steps don't build a good acceleration ramp!
4 years 11 months ago #226102 by taylorcmq
sorry but now i see the cpp file, i will test your code and let you know what i see
4 years 11 months ago #227373 by viewtop1
Hi All
I have a test setup of the above, well the Dlhenkel version actually as my ultimate use requires an encoder. Anyway, on a bench setup with a laptop running Linuxcnc and looking at the step gens on a scope, the outputs seem to be pretty acurate every milisecond. My question is how realtime is this ethernet implemtation? Lots of literature out there about the challenges of realtime ethernet. not my area of expertise, so if anyone more knowledgeable please chime in. Is this worth building a machine on?
4 years 11 months ago #227376 by Bari
It is all in early beta as you can see. You will be a beta tester like the rest of us if you build it!
Do you dare to go where it has not been fully tested yet?
Time to create page: 0.281 seconds
