linuxcnc-esp32 Software Stepping over Ethernet Using ESP32
11 Mar 2024 18:01 - 09 Oct 2026 20:45 #295665 by cekaa
Hello
My English is weak, I write via Google Translate
I installed linuxcnc? I couldn't get the esp32 to communicate with the w5500.
sudo apt-get install linuxcnc-uspace-dev build-essential
sudo halcompile --install udp.comp
I could not succeed with hallcompile, unfortunately my knowledge about installing this file is limited and my Linux knowledge is low.
github.com/wezhunter/ESP32_LinuxCNC_Moti...in/SerialCommands.md
I used serial commands with success
An article explaining what I need to do
I would like an explanatory setup in bullet points, please.
thank you very much
Last edit: 09 Oct 2026 20:45 by tommylight. Reason: Link removed
11 Apr 2024 17:21 #298012 by rohit269
Sir,
driver , udp.comp not install I try many time but always found error user/bin/halcomplie not found udp.comp file
11 Apr 2024 17:24 #298013 by rohit269
Sir,
driver , udp.comp not install I try many time but always found error user/bin/halcomplie not found udp.comp file so please tell how to install linuxcnc driver.
11 Apr 2024 22:00 #298030 by pippin88
The problem is halcompile is missing
Not anything to do with this thread component
Try:
How did you install linuxcnc?
16 Apr 2024 02:36 #298328 by pocovolvedor
Hey Wez. Its possible to pay for your help?
Im looking to do a retrofit with this project but have no knowledge about programing.
Please let me know. Thanks
19 Apr 2024 17:48 - 19 Apr 2024 17:49 #298639 by wez
Quick update: I plan on picking this up again in the near future. After detailed testing is complete I will publish a new version, as originally promised - life has got in the way quite a bit.
Hopefully (fingers crossed) once a working multi-architecture (ESP32/S2/S3) supporting multiple connectivity types is released and is being used in the wild others may be willing to help take up future maintenance of the project.
pocovolvedor - I'll do my best to try to help you out. Feel free to contact me directly on my email address which is located at the top in the licensing header of the "src/main.cpp" source file in my GitHub repo. Not posting directly for obvious reasons.
Cheers
Last edit: 19 Apr 2024 17:49 by wez.
10 May 2024 13:20 #300322 by itsemast
Great project! Do you have any plans to support direct SPI connection to RPi similar to RIO and Remora ?
23 May 2024 19:02 - 23 May 2024 19:03 #301245 by aparecido
i'm still learning about programming, i just took its structure from dds and put it inside a void IRAM_ATTR onTime_0() the same we used here in esp32, and used your .c
with some simple changes, I hope to make it the same as jzolee, as soon as everything is working correctly I will make it available on github so we can use it because at the moment everything is new to me and I don't have enough knowledge to discuss about it, I'm going in trial and error with some basic calculations.
Hello, how are you? I was reading the topic and saw your post, did you make the code available on a github account as you said in this post? Tks.
Last edit: 23 May 2024 19:03 by aparecido.
02 Jul 2024 09:28 - 02 Jul 2024 09:30 #304217 by aaronstone
Hi, brother. pippin88
Do you have a problem that you can't find a solution for?
Last edit: 02 Jul 2024 09:30 by aaronstone.
12 Jul 2024 17:02 #305011 by mBender
Awesome, just saw this topic on the forum. Once the new release is out I will try it.
Time to create page: 0.212 seconds
