- Thank you received: 4
Yeah, sorry that was some test code. The 2nd PR that I submitted got rid of that commented out #define. Not sure if you saw that or not. That is all that was in the 2nd PR.
I created a pull request in your library with the fix for your approval. Works great!
Scott...
Brilliant! Thank you very much. I'll pull that straight across and add a formal example. I'm assuming (dangerous) the commented out ' //#define ARDUINO_ARCH_ESP32 1' is superfluous.
Also curious about the 'using' vs 'typedef' - I originally had 'typedef' but at some point moved to 'using' but can't remember why...image missing /media/kunena/emoticons/wassat.png
In the words of those awful gameshows my Grandparents used to watch: Here's wat you could've won!Couple of quick questions:
1. Is there any value in adding an (optional) joystick? I've seen lot of positive views on non-standard pendants but can't recall seeing one on a commercial pendant.
2. I'm looking at making a PCB - anyone interested if I make a few extras?
