- Thank you received: 72
I would be interested in casting these cases for this pendant design, in fiber reinforced epoxy resin, stuff is strong like bull, could make buttons in silicone rubber etc, are the CAD files around ?
Can I use esp32 s3? Teensy is too expensive
Hi - the project is based around the Teensy 4.1 to ensure responsiveness from both inputs and the display. Technically you could use a Teensy 4.0 on the PCB (ir I created a common footprint) but I have not tested this and you would not be able to use the 5 physical buttons below the display.just found this manual matic pendant, but teensy 4.1 is too expensive ower price board, can i use teensy 2.0 this ? lot lot cheapen, and what need dong encoder or other library, ?not understand english good, need change arduino ide encoder library to new and were have ? i come old teensy 2.0 USB pendant all time only errorrs whit encoder.h
no declare scope etc. i not know what this all mean. not need diplay , only encoder and rotary SW change acis and scale. can move XYZ remote controll. were i found code teensy 2.0 can use. this.
