Remora - Does Analog input syntax exist?
- Murphy
- Thank you received: 5
30 Jul 2025 19:12 #332570
by Murphy
Replied by Murphy on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
It's in the image you downloaded. Look for the components folder I think it was called. Open that, you should see the Eth files. Open the terminal(command line) from here and run the halcomplie command that's in step 8 of the instructions.
- Mars
01 Aug 2025 14:55 #332628
by Mars
Replied by Mars on topic Remora - Can it host analog inputs?
Scott. Please forgive me if I am using the forum improperly. I have a project that I would like to base on RPI5 and Remora on a Bigtreetech board. I have read all the Remora documentation and studied all the config.txt files in your github. The question: can Remora support a general analog input (say to an ADC pin on the supporting processor)? In the limit, can I repurpose one of the thermistor inputs or are they dedicated to thermistor processing? TIA.
- Mars
01 Aug 2025 15:33 #332629
by Mars
Replied by Mars on topic Remora - Does Analog input syntax exist?
I have poured over the Remora documentation but can't find the syntax (if it exists?) for the config.txt to set up an input on a Remora supported controller board as an analog input. Is there a way? I have gone over all the config.txt files that I can find and they all seem to be variants of 3d printers and they have thermistor specific inputs (which are analog I realize but the only general signal inputs seem to be digital. Any help/hints/links other appreciated. TIA
- scotta
- Thank you received: 480
01 Aug 2025 22:01 #332647
by scotta
Replied by scotta on topic Remora - Does Analog input syntax exist?
You're correct. In the currently available modules there is no basic analog input. But the underlying code is there and used in the thermistor module.
- unknown
- Thank you received: 176
02 Aug 2025 04:36 #332658
by unknown
Replied by unknown on topic Remora - Does Analog input syntax exist?
Dear new Member please don't change the Subject when posting it renames the thread in the Index and makes it hard to find
- Mars
02 Aug 2025 11:10 #332661
by Mars
Thanx and I sorry about changing subject line...didn't realize it created problems.
The following user(s) said Thank You: unknown
Time to create page: 0.150 seconds
