30 Jul 2022 09:19 #248665 by xu
Thanks to scotta EC500 for adding encoding and QEI functionality that's great.
DIY CNC servo motors without coded feedback are a nightmare to tune
I can't buy MESA
NVEM & EC500 are readily available
The old one was about $60
04 Aug 2022 13:47 #249042 by eng
Could you tell me if it would be possible to use the firmware that is being used in the EC500 on the STM32F407VET6 board with the LAM8720A, if so, would I have to make any changes?
  • scotta
  • Platinum Member
  • Platinum Member
04 Aug 2022 21:47 #249070 by scotta
Hi eng, that is the basis of the EC500 firmware. One catch with the EC500 was the shared clock signal between the PHY and the MCU. I only figured that out when I had the board physically in my hands. If the board you are considering is different then the clock settings would need to be changed accordingly.
05 Aug 2022 00:19 #249091 by eng
I noticed exactly this, because I saw in your video that the ec500 had only a single crystal, I asked this question because from what I'm seeing, the plates with the stm32f407vet6 use as a clock, an 8mhz crystal, that was my biggest doubt and for this reason I asked this question.
  • scotta
  • Platinum Member
  • Platinum Member
05 Aug 2022 06:26 - 05 Aug 2022 22:19 #249097 by scotta
Some progress to share and getting closer. Below is a snip of a DDS synthsised 450 kHz step train on two pins on different ports generated by the DMAstepgen module and pushed to the two GPIO ports at 1Mhz via DMA using 1 single timer :-)
Still to do is double buffer and connect the stepgens to LinuxCNC command and feedback.
Last edit: 05 Aug 2022 22:19 by scotta. Reason: correction
The following user(s) said Thank You: Bari, MX_Master, tuzki, Murphy
11 Aug 2022 02:10 #249486 by Murphy
I'm finding it hard to order one of these. The first order never shipped so I got a refund. So I asked another seller. He said the manufacturer has pulled the current stock due to something been wrong with that batch. maybe they don't want people messing with them. ?
11 Aug 2022 02:16 #249487 by Bari
Maybe this is why: www.ebay.com/itm/154044311817
Price: 3-axis US $359.14
6-axis US $553.28
STM32's are getting hard to come by, and they are charging extra for each axis :)
11 Aug 2022 02:19 - 11 Aug 2022 03:32 #249488 by Murphy
No one is going to buy them at that price. It's ridiculous. That 3 axis in AliExpress are 75 euro plus 20 for shipping. They have all been pulled now. Looks like they will still sell the 6 axis. They may be recalling them to lock the availability to the axis ?
Just got confirmation from the manufacturer of the board. they are changing the design and locking the outputs. I take it that's the axis.
They are competing with Mesa boards. I think they are shooting themselves in the foot now. Bad move.
Last edit: 11 Aug 2022 03:32 by Murphy.
11 Aug 2022 04:47 #249489 by Aanvragen0903
Replied by Aanvragen0903 on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
I orded the controller at alieexpres, www.aliexpress.com/item/1005002253809296...t.0.0.31811802QuAgBe, Its on its way to Belgium.
Good luck
11 Aug 2022 04:49 #249490 by Murphy
When did you order ?
Time to create page: 0.252 seconds
