- rbobey1989
- Thank you received: 33
04 Dec 2023 23:10 #287225
by rbobey1989
Replied by rbobey1989 on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Hi Murphy, that was my first option until I spent a lot of time searching and I couldn't find high speed optocouplers with equivalent packaging. We also have another problem and that is that I want to use the differential outputs of the encoder and the inputs of the ec300/ ec500 are single ended, I am designing a board with differential inputs +A/-A, +B/-B, +I/-I (AM26C32) for 4 encoders, I also added some digital isolators (ISO7740) which reach up to 100Mbps since the possibility of implementing a closed loop in a spindle would be great (here the pulse frequency increases considerably), another detail is that we must power the encoders and in all the closed circuit motors that I have seen the power supply to the encoders is 5V, this voltage is not, let's say, easy to obtain on the EC300/EC500 boards, so I have added a regulator uA78M05 and another regulator uA78M33 for the 3V3 levels for the signals that go to the pins of the uC rt1052, after this we would have to solder 12 cables to the board and we would leave the optocouplers slow in case one day we need the slow 24V digital input we have it too, I will give you progress soon, greetings
The following user(s) said Thank You: Murphy
- Aravind
09 Dec 2023 16:23 #287685
by Aravind
Replied by Aravind on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Hi all,
I have just found this thread and I am going through it.
I had posted a new topic on the feasibility of NVEM for a special purpose machine.
Link : forum.linuxcnc.org/38-general-linuxcnc-q...for-linux-cnc#287655
As this thread is long enough, I might take much time to complete this.
Could anyone confirm the feasibility of using NVEM for my application. I will be a great help for me.
- Aravind
- Aravind
- cakeslob
- Thank you received: 278
09 Dec 2023 17:08 #287691
by cakeslob
You say 18 outputs, but it looks like you actually mean 4x steppers (9-12 outputs) and the remainder is reqular outputs?
- Aravind
09 Dec 2023 17:23 #287696
by Aravind
Yes. A total of 8 output pins will be used for controlling the stepper motors (Step and Dir) and the remaining outputs will be used for some relays.
- frayja2002
- Thank you received: 13
11 Dec 2023 11:02 #287842
by frayja2002
Replied by frayja2002 on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Hi all
I have updated to the latest cpp v3.1.2 & am now getting joint following errors when I increase the speed.
I have played around with the pgain value but it doesn't appear to be helping to much.
Is there some other way of getting rid of joint following errors.
Alex
Alex
- cakeslob
12 Dec 2023 00:52 #287896
by cakeslob
try this?
loadrt remora-eth-3.0 PRU_base_freq=500000Please Log in or Create an account to join the conversation.
- BrysonW
12 Dec 2023 05:21 - 12 Dec 2023 05:32 #287907
by BrysonW
Replied by BrysonW on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Hello again,First off I want to say thank you for the work that has been done here, and for help that has been given in the past. One of these days I want to put together a post explaining and documenting the whole process of getting this machine running. I'm working on a cnc plasma table and at this point it's around 95 percent operational running on a ec500. One of the last hiccups I'm having is getting the THC running. I think I'm correct in thinking that the ec500 doesn't have any analog inputs. We have a standalone proma sd thc, but it doesn't want to work with our everlast plasma cutter. I've checked the divided voltage coming from the machine while running and it was around 2v /-. I know there are some really smart and helpful people here, I'm trying to figure out what my best options may be for sending the 50:1 divided voltage into linuxcnc so I can use the THC functions there. I'm mainly just looking for some direction of where to go here. If i need to add a arduino or such into the controls to make this work, i may have a couple of those on hand. Thanks again, Bryson
Last edit: 12 Dec 2023 05:32 by BrysonW.
- Murphy
- Thank you received: 5
12 Dec 2023 17:17 #287960
by Murphy
Replied by Murphy on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Thread": "Base",
"Type": "QDC",
"Comment": "QDC Encoder A-IN12 B-IN14 I-IN13",
"PV": 1,
"Data Bit": 17,
"ChA Pin": "P3_23",
"ChB Pin": "P4_15",
"Index Pin": "P4_28",
"ENC No": 2,
"Filter PER": 10,
"Filter CNT": 4
Only getting round to this now, What do I need to change above to get a single channel A and index working?
The spindle is 100ppr and one index.
"Type": "QDC",
"PV": 1,
"Data Bit": 17,
"ChA Pin": "P3_23",
"ChB Pin": "P4_15",
"ENC No": 2,
"Filter PER": 10,
"Filter CNT": 4
- rbobey1989
12 Dec 2023 18:36 - 12 Dec 2023 18:37 #287961
by rbobey1989
Hi Murphy, at this time the QDC module works only in quadrature, the accumulator mode has not been developed but I think it would not be too complicated to add this feature to the module.
The reference manual explains the accumulator mode, the counting signal "A" and the signal "INDEX" which can be set to reset the QDC counter or not. I have some ideas for this development, but my time is finite hehe, if I have some time on the weekend I'll take a look at the topic, greetings.
Last edit: 12 Dec 2023 18:37 by rbobey1989.
- Murphy
12 Dec 2023 19:33 #287966
by Murphy
Thanks rbobey1989
Time to create page: 0.364 seconds
