- Thank you received: 7488
17 Dec 2023 15:50 #288420
Replied by tommylight on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
70 is a good price.
- beauxnez
- Thank you received: 10
17 Dec 2023 16:03 #288421
by beauxnez
Replied by beauxnez on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
I think this project can become a good one, it will evolve
- rbobey1989
- Thank you received: 33
17 Dec 2023 16:14 #288424
by rbobey1989
Replied by rbobey1989 on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Hello tommyligth, I see that you have a lot of experience with MESA boards, just out of curiosity what optocouplers a 7i96 mesa board has for encoder input, greetings
- rbobey1989
17 Dec 2023 16:40 #288426
by rbobey1989
At this point, Remora for NVEM/EC300/EC500 from my point of view is much better than the original Digital Dreams firmware. As Scott said, 6-axis DMAStepgen 500 kHz, 4 HW QDC encoder modules, all this for free, it is important to say, in my humble opinion Digital Dreams has used a great processor to not exploit it to the maximum and use cheap optocouplers in its design of PCB, having said that I think that Remora is a great project and offers possibilities that the original firmware of these boards for Mach3 does not have, greetings
- Thank you received: 5330
17 Dec 2023 17:31 #288431
Replied by PCW on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
The 7I96 does not use optocouplers for encoder input but rather a differential receiver.
Optocouplers are problematic for this use as they are poor differential receivers especially
if properly terminated. In addition the interface normally needs to supply 5V to the encoder
which defeats the advantage of the isolation.
- rbobey1989
17 Dec 2023 17:55 - 17 Dec 2023 17:57 #288433
by rbobey1989
Hello PCW, I have never had a MESA board in my hands and I was curious, thank you, I have made a design for a connection board for encoders where I have used some quadruple differential line receiver AM26c32 and some quadruple digital isolator ISO7700, it also incorporates some DC-DC converters 5V and 3V3 for powering the encoders and logic, it would be good to have your opinion about this design, I leave you a link to the post where I shared this
design
here in the forum, thank you
Last edit: 17 Dec 2023 17:57 by rbobey1989.
17 Dec 2023 18:08 - 17 Dec 2023 18:11 #288434
Looks OK, You can also use the 26LS32s for single ended by
providing a reference voltage and a jumper. The old
LSTTL 26LS32s tend to be more rugged than the newer CMOS
versions as they will accept +-25V common mode spikes
without damage and the CMOS versions are damaged by
>14V or so.
>14V or so.
Last edit: 17 Dec 2023 18:11 by PCW.
The following user(s) said Thank You: rbobey1989
- rbobey1989
17 Dec 2023 20:13 #288436
by rbobey1989
Thanks PCW, it is good to have your opinion on the design, I will replace the C series with the LS series for the differential receivers, I plan to have some boards manufactured by jlcpcb, greetings
18 Dec 2023 02:08 #288446
To late...
- Murphy
18 Dec 2023 17:55 - 19 Dec 2023 07:56 #288499
by Murphy
Replied by Murphy on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Is there isolation on the Mesa boards between the differential driver signals and MCU ?
Last edit: 19 Dec 2023 07:56 by Murphy.
Time to create page: 0.346 seconds
