- fintech
- Thank you received: 5
10 Feb 2023 22:12 - 10 Feb 2023 22:13 #264254
by fintech
Replied by fintech on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Thanks, Scott. I kind of cheated. I used the step config generator to create a working config for a parallel port. I wanted to see what a working config looks like. I compared the parallel config against your sample config. The spindle stuff I got from another post on here. You sent my the input and output numbers. I verified everything with my multimeter. I think most people on here probably have a technical background. This isn't for your average sane person.
Last edit: 10 Feb 2023 22:13 by fintech.
- Thank you received: 7488
10 Feb 2023 22:27 #264256
A bit of reading and patience and following directions goes a long way to the target.
Analyzing stuff as you did is the best way to a working machine and a wealth of knowledge.
Replied by tommylight on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
You would be amazed at how many people come here claiming to know nothing about electronic/electric/cnc and end up with a working machine in a very short period of time.I think most people on here probably have a technical background.
- dec0077
10 Feb 2023 22:33 #264257
by dec0077
Replied by dec0077 on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
10 Feb 2023 22:38 #264259
STM32F207, that is the micro controller, so probably should use the firmware for it.
Also might want to wait for the more experienced members to reply as i had no time to play with Remora, yet.
- scotta
- Thank you received: 489
11 Feb 2023 03:17 #264265
by scotta
Yes, an earlier version which uses an op amp circuit to convert the PWM into analogue. The PWM frequency used to drive the PWM to analogue chip on the new boards is quite slow. Maybe a higher frequency is need.Here are the pictures of my board, I hope they can give all the info needed.
- dec0077
11 Feb 2023 06:17 #264272
by dec0077
What kind of frequency are we talking about here? Because if it is between 1 and 3 KHz I could try to intercept the PWM signal before the op-amp and send it to something like this:
www.amazon.it/stronerliou-Signal-Voltage...+%2Caps%2C96&sr=8-23
(of course I would have to know where on the board to attach a lead... I'm guessing to one of the inputs of the LM358?)
Thank you
Thank you
- Domi
11 Feb 2023 08:46 #264277
by Domi
Replied by Domi on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Hello. I have it like this in the hal file and I get an error.
remora-nvem.hal:114: PIN remora.SP.0 was already linked to signal spindle-speed-DAC.
What should I assign net spindle-corrected lincurve.0.out to?
loadrt lincurve personality=3
addf lincurve.0 servo-thread
net spindle-cw remora.output.2
loadrt pwmgen output_type=1
loadrt scale count=1
loadrt lowpass count=1
loadrt abs count=1
addf scale.0 servo-thread
addf lowpass.0 servo-thread
addf abs.0 servo-thread
setp scale.0.gain 0.00416666667
net spindle-cmd-rpm spindle.0.speed-out => scale.0.in
net spindle-cmd-rpm-abs scale.0.out => abs.0.in
net spindle-speed-DAC abs.0.out => remora.SP.0
net spindle-cw <= spindle.0.forward
net spindle-speed-DAC abs.0.out => lincurve.0.in
#Lincurve compensation
setp lincurve.0.x-val-00 10
setp lincurve.0.y-val-00 100
setp lincurve.0.x-val-01 9000
setp lincurve.0.y-val-01 50
setp lincurve.0.x-val-02 18000
setp lincurve.0.y-val-02 10
net spindle-corrected lincurve.0.out => remora.SP.0
loadrt abs count=1
- dec0077
11 Feb 2023 08:48 #264278
by dec0077
I would say you have to remove this line:
- Domi
11 Feb 2023 11:48 #264287
by Domi
Thank you very much. Everything works. I still need to set the x and y values for lincurve
- JAMSys
11 Feb 2023 19:36 #264306
by JAMSys
Replied by JAMSys on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Last week I ordered a Novusum NVEM V2 board (Amazon) but I received a version 5 board.
Following the instructions, I was able to install the firmware with:
pyocd flash ./remora-rt1052.bin --target mimxrt1050_quadspi
I got the following response:
0001244 I Loading /Users/jameelberg/Desktop/Remora-RT1052-main/firmware/remora-rt1052.bin [load_cmd]
[==================================================] 100%
0032928 I Erased 131072 bytes (2 sectors), programmed 117760 bytes (460 pages), skipped 0 bytes (0 pages) at 3.63 kB/s [loader]
Its seems to be OK.
when I power up the board the RS232 output looks like this:
.Initializing PHY...
Remora RT1052 firmware for Digital Dream / Novusun CNC controllers starting
## Entering SETUP state
## Entering START state
Starting the BASE thread
Starting the SERVO thread
## Entering IDLE state
LinuxCNC comes to a ready state and the demo is running.
When I try to install a configuration file with the command:linuxcnc@linuxcnc400:~/linuxcnc/Remora/LinuxCNC/ConfigSamples/remora-nvem-basic $ python3 upload_config.py nvem-full-config.txt
I get following response:Valid JSON config file, uploading to Novusun board
Config file length (words) = 1775
Config file length (bytes) = 7099
Remainder = 3
Padding added = [0]
Config file length with padding (bytes) = 7100
CRC-32 = 0x95ee3542
Timeout waiting for traffic, retrying...
Timed-out waiting for traffic
resending last packet
Resending packet WRQ packet: filename = config mode = octet on sessions <tftpy.TftpStates.TftpStateSentWRQ object at 0x7fa28e96a0>
File "/home/linuxcnc/.local/lib/python3.9/site-packages/tftpy/TftpContexts.py", line 171, in cycle
(buffer, (raddress, rport)) = self.sock.recvfrom(MAX_BLKSIZE)
socket.timeout: timed out
During handling of the above exception, another exception occurred:
File "/home/linuxcnc/linuxcnc/Remora/LinuxCNC/ConfigSamples/remora-nvem-basic/upload_config.py", line 72, in <module>
client.upload("config", "/tmp/config.txt", timeout=30)
File "/home/linuxcnc/.local/lib/python3.9/site-packages/tftpy/TftpClient.py", line 101, in upload
self.context.start()
File "/home/linuxcnc/.local/lib/python3.9/site-packages/tftpy/TftpContexts.py", line 325, in start
self.cycle()
File "/home/linuxcnc/.local/lib/python3.9/site-packages/tftpy/TftpContexts.py", line 174, in cycle
raise TftpTimeout("Timed-out waiting for traffic")
tftpy.TftpShared.TftpTimeout: Timed-out waiting for traffic
I hope some knows why tftpy is not able to connect to the board.
Its seems to be OK.
Remainder = 3
Padding added = [0]
CRC-32 = 0x95ee3542
self.cycle()
Time to create page: 1.296 seconds
