Remora - ethernet NVEM cnc board
Not true.converting an ST-Link is a pain.
There is many versions of ST-Link clones with different processors and different schematics...
The more important problem of many projects is that the authors work very hard, but most important information hold in secret...
The conversion to DAPLink is a good example.
I don't know which "ST-Link" clone you used.
I have few in green plastic case, marked "www.betemcu.cn" with processor marked "Geehy APM32F103C8T6".
Will it work with your firmware?
What will be pinout of dongle socket?
Without these informations the conversion is not easy.
Can you please check my configurations in attachment?
Only three commands run, factory settings ST-Link. FW version V2.J29.S7sudo apt install python-pipsudo python -m pip install -U pyocd(run this last command from folder with firmware file, make sure highlighted text matches your file name)sudo pyocd flash ./[color=
not yet zmrdko maybe tomorrowGood to hear Murphy. Did you already try some jogging?
I installed tftp. But it's getting an error when I check the status of it
When you said you installed tftp, what did you do as you should not need a daemon running. You should only need to install TFTPy using pip.Could someone help me with this attribute error. I have flashed the board with the firmware. I can ping the board at 10.10.10.10. when I go and upload the config I get this error below.
pip install tftpy
ok so i installed with pip tftpy.Still the same error when I try and upload the config
