- Thank you received: 489
- scotta
4 years 6 months ago #240499
by scotta
I've had a quick look at your INI file and I think I've found why you would be getting a following error with these settings and Remora-NVEM. The Remora step generator logic is split into two halves. One part on the LinuxCNC side and the other in the module that's running on the board. Both of these halves need to have the same servo period setting, and your INI file is setting this different.
Change your line SERVO_PERIOD = 1500000to
SERVO_PERIOD = 1000000
(ie 1000hz) as per the example configuration should fix your problem. You probably should have started to use the example config file that is known to work rather than using one generated with stepconf.
Hi Roy,@scotta Here is my config. Probably not ideal, however it does work fine with the lpt port.
btw I think the link in your post should be [url] github.com/scottalford75/Remora-NVEM/tre...json_config/Firmware [/url]
- royka
- Thank you received: 135
4 years 6 months ago #240500
by royka
Replied by royka on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
I did that at first, but that didn't work either, that was why I then tried make a working config with the lpt port and use that with the nvem
- scotta
4 years 6 months ago #240501
by scotta
Did you upload the new firmware from this location? [I'll correct the earlier post]Uploading doesn't work I'm getting time-outs and now after a single movement I'm getting a following error:
Valid JSON config file, uploading to NVEM board
Config file length (words) = 1652
Config file length (bytes) = 6607
Remainder = 3
Padding added = [0]
Config file length with padding (bytes) = 6608
CRC-32 = 0xc1997785
Timeout waiting for traffic, retrying...
Timed-out waiting for traffic
resending last packet
Resending packet WRQ packet: filename = config mode = octet on sessions <tftpy.TftpStates.TftpStateSentWRQ object at 0x7f931391c6a0>
File "/usr/local/lib/python3.7/dist-packages/tftpy/TftpContexts.py", line 171, in cycle
(buffer, (raddress, rport)) = self.sock.recvfrom(MAX_BLKSIZE)
socket.timeout: timed out
During handling of the above exception, another exception occurred:
File "upload_config.py", line 72, in <module>
client.upload("config", "/tmp/config.txt", timeout=60)
File "/usr/local/lib/python3.7/dist-packages/tftpy/TftpClient.py", line 101, in upload
self.context.start()
File "/usr/local/lib/python3.7/dist-packages/tftpy/TftpContexts.py", line 325, in start
self.cycle()
File "/usr/local/lib/python3.7/dist-packages/tftpy/TftpContexts.py", line 174, in cycle
raise TftpTimeout("Timed-out waiting for traffic")
tftpy.TftpShared.TftpTimeout: Timed-out waiting for traffic
- Domi
4 years 6 months ago #240502
by Domi
Replied by Domi on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Need to change the address from 10.10.10.11 to 10.10.10.10? Or is it a card address?
- scotta
4 years 6 months ago #240503
by scotta
The NVEM board IP address is hard coded to be 10.10.10.10 , Your computer can have any IP address on the same subnet.Need to change the address from 10.10.10.11 to 10.10.10.10? Or is it a card address?
The following user(s) said Thank You: Domi
- scotta
4 years 6 months ago #240504
by scotta
You need to be in the same directory as the python file and the config file before running the command.I downloaded it in windows. He then put it in Linuxcnc and then edited config.txt
python3: cannot open file 'upload_config.py': [Errno 2] No such file or directory
Time to create page: 1.364 seconds
