- Thank you received: 135
- royka
4 years 6 months ago #240505
by royka
Replied by royka on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Yes I did upload that firmware and checked if it uploaded correctly
- scotta
- Thank you received: 489
4 years 6 months ago #240506
by scotta
Hmm... ensure the ST-Link is disconnected and try pinging the NVEM at 10.10.10.10
- royka
4 years 6 months ago #240507
by royka
Yes I could ping it, was thinking the same. Will try to upload the bin from the Release folder
- scotta
4 years 6 months ago #240508
by scotta
I'll look to merge the feature branch into main later today. Until then this is the firmware for testing
github.com/scottalford75/Remora-NVEM/tre...json_config/Firmware
- royka
4 years 6 months ago #240509
by royka
Downloaded the whole folder so it has a new name so it could not be from the cahce or something, uploaded the firmware again, but still the same result. Time out when I try to upload the config and directly a following error after each movement. Ping is 0.090ms
- scotta
4 years 6 months ago - 4 years 6 months ago #240510
by scotta
I've got a thought. Not sure why the upload is not working but when loading a fresh firmware there is no JSON config file in the Flash either, so when the board boots it's loading nothing, not even a stepgen. I'll need to include a default configuration in the firmware image somehow.
Really appreciate the testing guys. We'll get there.
Last edit: 4 years 6 months ago by scotta.
The following user(s) said Thank You: royka, Domi
Time to create page: 1.387 seconds
