4 years 6 months ago - 4 years 6 months ago #240435 by scotta
Some great news to share. Configuring the NVEM with a custom config file is now possible! I have updated the firmware and the example configuration.
github.com/scottalford75/Remora-NVEM/tre...json_config/Firmware
github.com/scottalford75/Remora/tree/fea...gSamples/remora-nvem
The config.txt file in the config sample enables all features on the board including the NVMPG. To customise, simply remove the unused step generators, IO, spindle or NVMPG as required. You can also change the IO mapping and naming just like the SPI version of Remora.
I've done limited testing but it all seams to be working ok.
To upload a new config file to the board use the python script from within the config directory. The config file can be a text file called anything.
pi@remora:~/linuxcnc/configs/remora-nvem $ python3 upload_config.py config.txt
The file will only be uploaded if it is a correctly formatted JSON file, the NVEM board will check the CRC-32 and if ok will move the uploaded config file into the storage location and reboot the board by forcing a watch dog timeout.
Last edit: 4 years 6 months ago by scotta.
The following user(s) said Thank You: tommylight, cakeslob, royka, Domi, spdbmp927
4 years 6 months ago - 4 years 6 months ago #240455 by Domi
pi @ remora: ~ / linuxcnc / configs / remora-nvem $ python3 upload_config.py config.txt
The file or directory does not exist :(
which means : The file will only be uploaded if it is a correctly formatted JSON file ?
bash: /: is a directory
Last edit: 4 years 6 months ago by Domi.
4 years 6 months ago - 4 years 6 months ago #240484 by royka
@scotta Here is my config. Probably not ideal, however it does work fine with the lpt port.
btw I think the link in your post should be [url] github.com/scottalford75/Remora-NVEM/tre...json_config/Firmware [/url]
Last edit: 4 years 6 months ago by royka.
4 years 6 months ago - 4 years 6 months ago #240490 by royka
Open Terminal
sudo apt-get install python3-pip && pip3 install tftpy
Then If you've downloaded the directory before with git:
cd Remora && git pull cd LinuxCNC/ConfigSamples/remora-nvem
[code][code]Edit the config.txt as you wish.
[/code][/code]
[code][code]Else:
[/code][/code]
sudo apt-get install git && git clone -b feature/ethernet https://github.com/scottalford75/Remora.git && cd Remora/LinuxCNC/ConfigSamples/remora-nvem
[/code][/code]
4 years 6 months ago - 4 years 6 months ago #240496 by royka
Uploading doesn't work I'm getting time-outs and now after a single movement I'm getting a following error:
Valid JSON config file, uploading to NVEM board
Config file length (words) = 1652
Config file length (bytes) = 6607
Remainder = 3
Padding added =  [0]
Config file length with padding (bytes) = 6608
CRC-32 = 0xc1997785
Timeout waiting for traffic, retrying...
Timed-out waiting for traffic
resending last packet
Resending packet WRQ packet: filename = config mode = octet on sessions <tftpy.TftpStates.TftpStateSentWRQ object at 0x7f931391c6a0>
  File "/usr/local/lib/python3.7/dist-packages/tftpy/TftpContexts.py", line 171, in cycle
    (buffer, (raddress, rport)) = self.sock.recvfrom(MAX_BLKSIZE)
socket.timeout: timed out
During handling of the above exception, another exception occurred:
  File "upload_config.py", line 72, in <module>
    client.upload("config", "/tmp/config.txt", timeout=60)
  File "/usr/local/lib/python3.7/dist-packages/tftpy/TftpClient.py", line 101, in upload
    self.context.start()
  File "/usr/local/lib/python3.7/dist-packages/tftpy/TftpContexts.py", line 325, in start
    self.cycle()
  File "/usr/local/lib/python3.7/dist-packages/tftpy/TftpContexts.py", line 174, in cycle
    raise TftpTimeout("Timed-out waiting for traffic")
tftpy.TftpShared.TftpTimeout: Timed-out waiting for traffic
4 years 6 months ago #240497 by Domi
I downloaded it in windows. He then put it in Linuxcnc and then edited config.txt
python3: cannot open file 'upload_config.py': [Errno 2] No such file or directory
Time to create page: 1.293 seconds
