  • scotta
  • Platinum Member
  • Platinum Member
17 Apr 2022 21:57 #240501 by scotta
Uploading doesn't work I'm getting time-outs and now after a single movement I'm getting a following error:
Valid JSON config file, uploading to NVEM board
Config file length (words) = 1652
Config file length (bytes) = 6607
Remainder = 3
Padding added =  [0]
Config file length with padding (bytes) = 6608
CRC-32 = 0xc1997785
Timeout waiting for traffic, retrying...
Timed-out waiting for traffic
resending last packet
Resending packet WRQ packet: filename = config mode = octet on sessions <tftpy.TftpStates.TftpStateSentWRQ object at 0x7f931391c6a0>
  File "/usr/local/lib/python3.7/dist-packages/tftpy/TftpContexts.py", line 171, in cycle
    (buffer, (raddress, rport)) = self.sock.recvfrom(MAX_BLKSIZE)
socket.timeout: timed out
During handling of the above exception, another exception occurred:
  File "upload_config.py", line 72, in <module>
    client.upload("config", "/tmp/config.txt", timeout=60)
  File "/usr/local/lib/python3.7/dist-packages/tftpy/TftpClient.py", line 101, in upload
    self.context.start()
  File "/usr/local/lib/python3.7/dist-packages/tftpy/TftpContexts.py", line 325, in start
    self.cycle()
  File "/usr/local/lib/python3.7/dist-packages/tftpy/TftpContexts.py", line 174, in cycle
    raise TftpTimeout("Timed-out waiting for traffic")
tftpy.TftpShared.TftpTimeout: Timed-out waiting for traffic
Did you upload the new firmware from this location? [I'll correct the earlier post]
github.com/scottalford75/Remora-NVEM/tre...json_config/Firmware
17 Apr 2022 21:57 #240502 by Domi
Need to change the address from 10.10.10.11 to 10.10.10.10? Or is it a card address?
  • scotta
  • Platinum Member
  • Platinum Member
17 Apr 2022 22:00 #240503 by scotta
The NVEM board IP address is hard coded to be 10.10.10.10 , Your computer can have any IP address on the same subnet.
The following user(s) said Thank You: Domi
  • scotta
  • Platinum Member
  • Platinum Member
17 Apr 2022 22:03 #240504 by scotta
I downloaded it in windows. He then put it in Linuxcnc and then edited config.txt
python3: cannot open file 'upload_config.py': [Errno 2] No such file or directory
You need to be in the same directory as the python file and the config file before running the command.
17 Apr 2022 22:04 #240505 by royka
Yes I did upload that firmware and checked if it uploaded correctly
  • scotta
  • Platinum Member
  • Platinum Member
17 Apr 2022 22:06 #240506 by scotta
Hmm... ensure the ST-Link is disconnected and try pinging the NVEM at 10.10.10.10
17 Apr 2022 22:08 #240507 by royka
Yes I could ping it, was thinking the same. Will try to upload the bin from the Release folder
  • scotta
  • Platinum Member
  • Platinum Member
17 Apr 2022 22:14 #240508 by scotta
I'll look to merge the feature branch into main later today. Until then this is the firmware for testing
17 Apr 2022 22:18 #240509 by royka
Downloaded the whole folder so it has a new name so it could not be from the cahce or something, uploaded the firmware again, but still the same result. Time out when I try to upload the config and directly a following error after each movement. Ping is 0.090ms
  • scotta
  • Platinum Member
  • Platinum Member
17 Apr 2022 22:23 - 17 Apr 2022 22:24 #240510 by scotta
I've got a thought. Not sure why the upload is not working but when loading a fresh firmware there is no JSON config file in the Flash either, so when the board boots it's loading nothing, not even a stepgen. I'll need to include a default configuration in the firmware image somehow.
Really appreciate the testing guys. We'll get there.
Last edit: 17 Apr 2022 22:24 by scotta.
The following user(s) said Thank You: royka, Domi
Time to create page: 0.987 seconds
